subarubrat
Joined: 4/1/2005 From: Remington, VA, USA Status: offline
It still needs allot of trim and detail work, obviously. Although it looks good so far there is going to be a struggle in rigging this plane. BUSA $@&*# me again with their landing gear. When I did the original assembly and setup of the top section I used the BUSA gear (pre-assembled) and when I switched to the Sierra gear everything was 1/2 inch off as I was assembeling it after painting. The bottom right wingtip was just over 1/2 inch lower than the left. The top section was tilted as well. As you know, the box recepticle for the lower spar is a core part of the wing, to adjust it's position would mean tearing off the covering, and essentially rebuilding most of the wing. There is some play and I am hoping I can rig out enough on each side to get it square. Wondering how this goof could have happened I grabbed the BUSA professionally pre-assembled gear and measured it. Sure enough, one was built just over 1/4 longer than the other. It continues to baffle me how they can do some things so well then ship something so useless.
_____________________________
DUTY, HONOR, COUNTRY
