RE: OFFICIAL HPI RUSH / EVO THREAD
Tower Hobbies
Logged in as Guest
  Printable Version
AXIAL AX10 SCORPION CRAWLER 12MM HEX WHEEL EXTENSIONS - RTR
Seller:  wheelextensions
Details:   $20.00   |  8/25/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> RE: OFFICIAL HPI RUSH / EVO THREAD
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: OFFICIAL HPI RUSH / EVO THREAD - 5/24/2005 1:35:58 AM
46u
Status: offline
quote:
ORIGINAL: Nightwolf
Dirt-hawgs/works work well on both front and rear, although i'd prefer some Step-pins at the front in case of understeer. What shock set-up you running?
Stock shocks with 30 weight oil and yellow springs. I have the stock tires on the front. Keep in mind this is the original Rush not the Evo Rush.
_____________________________
Rebel Racing, Sponsored by, Byron Fuel Looking for a new engine sponsor!
(in reply to Nightwolf)
       Post #: 26
RE: OFFICIAL HPI RUSH / EVO THREAD - 5/24/2005 1:41:13 AM
samisnake
Status: offline
wots the difference between them. i have the original, and the only thing i can see better about the evo is the engine
Nitro Rush - Alu'd up
R40 - Novarossi nsr12s3, RD Logics Turbo II Legal, Mazda Rx7 shell
(in reply to 46u)
       Post #: 27
RE: OFFICIAL HPI RUSH / EVO THREAD - 5/24/2005 1:59:48 AM
46u
Status: offline
The frames is different and the motor plate which if you had problems with the original ones HPI replaced them. The Evo has the Roto Starter which I like my pull starter better. But I do think that is about it. I do not have the stock motor I have HPI .15 SS, which is much better, then the .15 FE! I know the front A arms are the same because I just broke my first one this week and the part numbers are the same for both. Cannot complaint being it is the first one I broke since it was new 4 or 5 years ago and I have about 5 gallons of fuel throw it. From what I have been told to help with under steer to put softer tires, softer shock springs and or bigger tires in the front. But it does not matter what you do to a 2 wheel drive it will never turn like 4 wheel drive which only makes sense.
(in reply to samisnake)
       Post #: 28
RE: OFFICIAL HPI RUSH / EVO THREAD - 5/24/2005 2:16:19 AM
samisnake
Status: offline
im gettin the motor plate soon, cos my old 1 is stuck to my old 2mm chassis which im ending back to hpi i noticed that the old plate bent with the chassis which defeats the purpose. i had to beat it into shape with a hammer. quality or wot
(in reply to 46u)
       Post #: 29
RE: OFFICIAL HPI RUSH / EVO THREAD - 5/24/2005 2:23:15 AM
46u
Status: offline
When I sent back my chassis they sent me a new motor plate as from what I understand the old one will not work with the new chassis. The new motor plate is cast. There has been several chassis up grades for the original Nitro Rush. What you get now is a black Evo chassis. I actually have the first up dated and the last up dated black Evo chassis. The first up graded was still purple but thicker with the same sorry flat motor plate.
       Post #: 30
RE: OFFICIAL HPI RUSH / EVO THREAD - 5/24/2005 2:25:20 AM
46u
Status: offline
Do the Evo come with tire inserts? My original Rush did not come with them. Not sure how long the Rush has been out but I think I have one of the very first ones.
< Message edited by 46u -- 5/24/2005 2:27:25 AM >
(in reply to 46u)
       Post #: 31
RE: OFFICIAL HPI RUSH / EVO THREAD - 5/24/2005 2:28:02 AM
samisnake
Status: offline
i had 2 2mm chassis. i sent back the first about 2weeks ago and go the thicker purple chassis. im gonna get the motor plate off of ebay, and send off the other 1 asap. dont really wot plate they send me tbh, cos the way i see it, im gettin a brand new chassis
(in reply to 46u)
       Post #: 32
RE: OFFICIAL HPI RUSH / EVO THREAD - 5/24/2005 8:30:57 AM
[WPA] Tommy
Status: offline
The only problem i have with my chasis tray is that the underside has got some serious gauges and scratches, i know thats its job but it would be cool if there was a CHEAP plastic undertray to protect it and stop so much rubbish getting in.....anybody know of any undertrays for the EVo rush?
Other wise i think i may have to have a go at making one, time to sharpen my drawing pencil i think.
       Post #: 33
RE: OFFICIAL HPI RUSH / EVO THREAD - 5/24/2005 12:30:21 PM
Nightwolf
Status: offline
I don't know of any undertrays for the Rush...
Well, none of those chassis' really work for me, when I first got my Rush (the original one) I sent in the 2mm after it bent, then I got the 2,5 mm, also bent that one after I put a Picco in there, so after that I built 2 4mm homemade T-6 chassis' which I'm still using, works fine for me...
I still wonder why HPI don't come with a heavy duty 7075 chassis like they do on the
MT(2).
< Message edited by Nightwolf -- 5/24/2005 12:37:01 PM >
(in reply to [WPA] Tommy)
       Post #: 34
RE: OFFICIAL HPI RUSH / EVO THREAD - 5/24/2005 2:51:04 PM
[WPA] Tommy
Status: offline
I've had a look round and can't find any undertrays myself, so think i'm going to have a go at making one and see how it goes, as i can't believe there isn't one out there!!
I'm thinking plastic undertray with sides that come up to protect the chasis sides and underneath from scratches etc. If i get anywhere with i'll try and post some photos if anyones interested ?
       Post #: 35
RE: OFFICIAL HPI RUSH / EVO THREAD - 5/25/2005 12:36:00 AM
46u
Status: offline
Team Associated makes a clear chassis protective sheet No. 6312 made or teflon. I have some but never took time to put it on so I do not know how well it works. All my frames are all ready beat up.
       Post #: 36
RE: OFFICIAL HPI RUSH / EVO THREAD - 5/26/2005 8:56:35 AM
[WPA] Tommy
Status: offline
Cheers for the info, going to have a look. However, i have already put pencil to paper to design the mould and am going to start making it soon, could be fun could be the death of me we shall see, would be cool if it works. Will let you all know how it goes !!!
(in reply to 46u)
       Post #: 37
RE: OFFICIAL HPI RUSH / EVO THREAD - 5/27/2005 5:59:21 AM
46u
Status: offline
Does the Evo Rush tiers come with inserts?
(in reply to 46u)
       Post #: 38
RE: OFFICIAL HPI RUSH / EVO THREAD - 5/27/2005 6:58:01 AM
samisnake
Status: offline
they do. it says so on the hpi site about the differences between the rush and rush evo
(in reply to 46u)
