how do you make after run oil?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> how do you make after run oil?
Page: [1] 2   next >   >>
Login
how do you make after run oil? - 9/30/2002 2:18:40 PM
99GrandTouring
Status: offline
I was told that you can use Automatic transmission fluid as after run oil?
Should I just use pure ATF??
Also the ATF I have is mobil one SYNTHETIC....
does it matter?
       Post #: 1
atf - 9/30/2002 7:45:24 PM
lurch
Status: offline
I've also heard about using atf but not too sure about synth. I don't see how it would hurt though.
(in reply to 99GrandTouring)
       Post #: 2
how do you make after run oil? - 9/30/2002 8:02:31 PM
quint-rcu
Status: offline
I make a trip to the local car parts store and buy Marvel Mystery Oil. Looks, smells and feels just like commercial after-run. - Hmmm?
quint
_____________________________
Not 53 years modeling, one year 53 times
       Post #: 3
how do you make after run oil? - 9/30/2002 9:40:01 PM
CaptKAOS
Status: offline
Get the Marvel Mystery Oil for Air Tools......contains a rust inhibitor.....better than the regular Marvel Mystery Oil.....
My 1.675 cents worth.....
Ya gotta watch out for......[size=18][b]THEM.......[/size][/b]
       Post #: 4
how do you make after run oil? - 9/30/2002 10:04:22 PM
wingnutII
Status: offline
"Get the Marvel Mystery Oil for Air Tools......contains a rust inhibitor"
More Importantly it has an affinity for water, due to the fact that airtools have alot of condensation if not set up right, ie. no water traps or dryers.
Marvel Mystery Oil for Air Tools, is the best you can get for an after run.
Have fun go fly something!
       Post #: 5
how do you make after run oil? - 9/30/2002 10:09:41 PM
hauckf
Status: online
I was taught to use Marvel Mystery Oil for after run oil, and ATF for long term storage of engines. I've been using the regular MMO for years (a quart last forever!) and have never had any rust problems. When its gone, I'll buy the airtool oil. Burning all the fuel out of the engine at the end of the day before adding the after run oil is also very important.
       Post #: 6
After run oil - 9/30/2002 11:16:51 PM
DLT
Status: offline
I mix 1 part air tool oil to 4 parts MMO......seems to work for me.
       Post #: 7
how do you make after run oil? - 10/1/2002 5:31:44 AM
rsieminski
Status: offline
How about good old castor, for between sessions?
Tons of new content on my site:
[link]http://mywebpages.comcast.net/webmaster01/[/link]
       Post #: 8
WD-40 - 10/2/2002 10:18:22 PM
bigbadbowtie
Status: offline
Im not sure on the airplain engines but I have been using wd-40 in my stadium truck for after run oil for quite sometime. Traxxas actually says to use WD-40 in the manual for the new T-maxx.
Works for me.I have 3 gallons through my current
ABC motor and it has great compression still. I have been told not to use it but why change if it works!
Just adding my .02 cents.
Ray
Ray in Bama
       Post #: 9
OS SAID... - 10/2/2002 10:27:38 PM
redxfred
Status: offline
A buddy recommended a 50-50 mix of Marvel mystery oil and ATF. Being an untrusting soul, I asked the tech reps at O.S. Engines about this and they said this formula makes an excellent after run oil.
Be sure to use enough! I put 2 cc (4 eyedroppers' worth) in the carb and hold the plane left, right, up and down to slosh it around in there. Spin the prop a few times to coat the bearings but use caution. I'm advised that this stuff may diesel-fire in a warm engine.
Fred
... now, why did it do that?
       Post #: 10
WD-40 - 10/2/2002 10:39:26 PM
RedStickFlyer
Status: offline
Did you know that WD-40 was originally formulated for the military as a rust inhibitor. WD stands for Water Displacer. I would expect it to be an excellent rust inhibitor. I would suggest the best way to put it in is to spray it in the carb and preferably while the engine is turning with the electric starter. I killed the engine with a shot of WD-40 into the carb.
The high vapro pressure of the WD-40 allows it to atomize and coat more evenly than normal oil. The after run oil is only going to protect what it contacts.
By the same token, the high vapor pressure of WD-40 also lets it evaporate. Therefore, I would not use it for winter sorage but as a rust inhibitor between flights it should work well.
The key in after run oil is to get everything coated. A couple of drops in the carb might make you feel good about having used it but you have to put enough in to coat the bearings. Keep in mind on most model engines the crank shaft of over hung meaning that both the bearings are on the propeller side of the piston so after you get the oil in the crank case you need to get it up to the front of the plane.
I suspect most people get little bennifit from after run oil because they only get it on the aluminum parts that already are not going to corrode.
I have not done any studies or testing to prove this. Its just my opinion as a chemical engineer who runs a petro chem plant.
I hope this helps
       Post #: 11
how do you make after run oil? - 10/4/2002 4:17:35 AM
Dave Harmon
Status: offline
Redstick....You are right...it works great on my sport engines. What I do is to stick the red plastic tube into the carb ad open the throttle 2 or 3 clicks, give it a couple of good shots and start the engine (with the fuel line off) Then, I keep the engine running on the WD by giving more shots as the propellant is burned. This will distribute the WD and it really does help a lot and the engine is real loose next time out. I used to mix a 50/50 mix of castor and alky as an after run and then run the engine on that. That will completely stop all corrosion and rust but it can get a little messy. Oh..the castor/alky mix was in a small external fuel tank so you don't have to put any in the airplane tank.
If your engine has any silicone rubber internal parts, dont use WD40 or any petroleum product because the silicone will swell.
Mix Your Own Fuel....It's Easy!
       Post #: 12
how do you make after run oil? - 10/14/2002 8:52:06 PM
GMPheli
Status: offline
The problem you can run into using WD-40 is that it is designed to loosen rust. If you have any rust inside the engine and the WD-40 breaks it free, the rust (iron oxide) makes a wonderful abrasive. This is per Clarence Lee.
Alan Angus
       Post #: 13
how do you make after run oil? - 10/25/2002 6:50:50 PM
bdtsr
Status: online
Go to a marine supply store (or auto parts) and get the CRC Engine Fogging Oil or similar. This is designed for long term storage of engines (both aluminium and iron blocks). It is cheap, lasts along time (large can) and will prevent rust. I live very near the water on the east coast and take every precaution to keep moisture out of my engines. I have been using this since I started flying (6yrs ago) and only have replaced bearing in engines I bought from other people. I spray this into the carb and the cylinder and work it around. When the engine is fired up this oil will burn right out.
       Post #: 14
how do you make after run oil? - 11/8/2002 6:39:36 PM
Graxafone
Status: offline
What do you think of Hobbico's After Run Oil? And just to let you know, the 40 in WD-40 means that it is the 40th attempt at a good formula of oil and chemicals.
< Message edited by Graxafone -- Nov 9 2002 9:50PM >
"The only thing fair in life is a travelling carnival."
       Post #: 15
how do you make after run oil? - 11/9/2002 9:43:06 PM
adrian-RCU
Status: offline
80% parrafien 20% any engine oil. costs nothing and a liter lasts for ever
