After Run Oils
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> After Run Oils
Page: <<   < prev  1 [2]
Login
After Run Oils - 12/8/2002 6:18:23 PM
bluefronted
Status: offline
The guys that I know uses any thin machine oil , such as 3in1 or any sewing machine oil , some use PS 23 2 stroke oil , yes ATF is used world wide,
U could also use lubricating sprays ( Q20 , WDF ,etc , that displaces water and lubricates.
Just my advice , not gospel ,
(in reply to 99GrandTouring)
       Post #: 26
how do you make after run oil? - 12/8/2002 6:43:54 PM
coomarlin
Status: offline
When I got into the hobby and placed my first big order form tower I just bought the Hibbico stuff. Was later told by some buddies to use Marvel for air tools and it is great.
I do have a question though. I've got a Saito 100 that will be mounted in a UCD3D with a cowl. How can I get oil into the engine or into the carb easily? This is my first 4 stroke and I'm not familiar with what I should do. Would putting oil in the pressure nipple on the back plate work? Help me please
       Post #: 27
how do you make after run oil? - 12/9/2002 12:31:55 AM
bdtsr
Status: offline
Yes that would help. Put the piston at BDC and inject oil into the nipple on the backplate, the by moving the piston to TDC it will suck the oil in. Then make several turns to distribute the oil. You can also inject some into the exhaust then slowly turn the engine over allowing it to run in through the exhaust valve.
       Post #: 28
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.406RCU1
