redxfred
Joined: 9/28/2002 From: Strasburg, VA, USA Status: offline
A buddy recommended a 50-50 mix of Marvel mystery oil and ATF. Being an untrusting soul, I asked the tech reps at O.S. Engines about this and they said this formula makes an excellent after run oil. Be sure to use enough! I put 2 cc (4 eyedroppers' worth) in the carb and hold the plane left, right, up and down to slosh it around in there. Spin the prop a few times to coat the bearings but use caution. I'm advised that this stuff may diesel-fire in a warm engine. Fred
_____________________________
... now, why did it do that?
