JetJoe OWNERS thread
Tower Hobbies
Logged in as Guest
  Printable Version
BVM Bobcat - RTF
Seller:  Gordito Volador
Details:   $4,750.00   |  10/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> JetJoe OWNERS thread
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
JetJoe OWNERS thread - 5/5/2005 3:34:32 AM
EASYTIGER
Status: offline
I thought it would be nice to have a new thread sans politics where JJ owners could trade info and experiences. This was suggested by some a while back.
If you just want to slam jetjoe, please start your own thread. If you are a factory rep(as listed in the jetjoe website) your input is welcome.
I did five starts on my JJ yesterday, no problems at all, except the ramp up seems slow, and it would not get past 140k at full bore. Last week when I ran it, 160k was no problem. Ideas?
Jetjoe #563, full autostart, original JJ pump. Single piece tailcone.
       Post #: 1
RE: JetJoe OWNERS thread - 5/5/2005 4:30:37 AM
Shok
Status: offline
I thought about buying one, does that count?
I got so see one up close last week. It looked good, but it wouldn't run. Lots of fire.
I think alot of the problem was the autostart though.
_____________________________
Ronnie
Jetmach, Flyeagle, JetCat Sales
www.laser-design-services.com
(in reply to EASYTIGER)
       Post #: 2
RE: JetJoe OWNERS thread - 5/5/2005 4:37:38 AM
angturbines
Status: offline
Sounds like the pump or the battery pack, the original JJ pumps have been known to give problems,Have a look at the power reading on the FADEC,
       Post #: 3
RE: JetJoe OWNERS thread - 5/5/2005 4:45:12 AM
B1Driver
Status: offline
It was my JJ-1400 at that you saw Shok. Soon as I know what exactly it was I'll post it on the this board. Most likely a failed RPM sensor or the Fadec.
Luis
MORS AB ALTO
(in reply to angturbines )
       Post #: 4
RE: JetJoe OWNERS thread - 5/5/2005 6:28:32 AM
Johnny Isaiah Woods
Status: offline
Hello all,
After all of the posts on the jetjoe, negative and positive, I went to the
JJ site and saw the price for the assembled engines and decided to
buy the JJ1400 (engine only). I have a Ram 500 now that is going
on my Boomerang intro and when the JJ1400 comes in I will replace
the Ram 500 and compare the operation and performance. I will use
the Ram pump, solenoids, rpm sensor, thermocouple and ECU. to
run the JJ1400. I will let everyone know the results, good or bad.
The factory is on holliday this week so the engine will not ship until
next monday. Currently my ECU will only go to 150,000 rpms so
the Jetjoe will not put out max thrust. Hopefully I will be able to
get Bob Price to adjust the max rpms at a later date.
(in reply to B1Driver)
       Post #: 5
RE: JetJoe OWNERS thread - 5/5/2005 9:27:55 AM
MNModels
Status: offline
Hi all JJ owners,
Ok last weekend i flew my Draco with the JJ1400. Start and run was no problem. It flew the beast so there is a lot of power. Had 2 flame outs about 4 min into flight. Think it is the filter trapping bubbles. It flew at high altitude (above sea level) as well. No vertical performance as exspected. I am impressed. I will order another 1 to put in my F86. I will take out my homebuilt KJ66 and give you people a review.
I will now fit the JJ in RCARF new turbine trainer the A10X. It is much smaller and lighter. Will be great fun to have an arf jet and turbine motor all for under 2G's and with an added bonus it can be flown of a normal club size runway!!
Regards
MNModels
Exclusive distributor for Skymaster, YAI & JJoe in RSA. XtremeJets customer service
(in reply to Johnny Isaiah Woods)
       Post #: 6
RE: JetJoe OWNERS thread - 5/5/2005 1:13:59 PM
Skymac
Status: offline
Luis, Talked to Sean last night, your motor is just now getting shipped because he forgot that he didn't have my address.
ET - Yeah either your Battery is discharged or your pump is junk, the chinese pump just dosen't have what it takes, also try putting your pump ramp value around 10.
Justin Tidwell
(in reply to MNModels)
       Post #: 7
RE: JetJoe OWNERS thread - 5/5/2005 1:37:44 PM
EASYTIGER
Status: offline
quote:
ORIGINAL: B1Driver
Luis
So you got one!
The RPM sensor is easy enough to diagnose. Spin the turbine with the ECU on and see if it reads RPM.
What exactly is happening? Beware of some of the advice given out, don't do anything just yet.
       Post #: 8
RE: JetJoe OWNERS thread - 5/5/2005 1:41:09 PM
EASYTIGER
Status: offline
quote:
ORIGINAL: Johnny Isaiah Woods
Hello all,
Sounds like fun. And you will be flying for a lousy $599.
       Post #: 9
RE: JetJoe OWNERS thread - 5/5/2005 1:45:48 PM
EASYTIGER
Status: offline
quote:
ORIGINAL: andymw54
New pack, and the pump was working up to 160k just last week. Natch, though, the pump is most suspect. I did not check the parameters, maybe today I will have some time to play. The pump voltage is a user adjustable parameter on the Espeill ECU, I take it?
       Post #: 10
RE: JetJoe OWNERS thread - 5/5/2005 1:48:00 PM
EASYTIGER
Status: offline
quote:
ORIGINAL: MNModels
Hi all JJ owners,
Regards
I have the "reaper" version of the draco, and was expecting about the same performance. Don't know what I will put it in next, I don't expect to keep the JJ1200 in that airplane.
       Post #: 11
RE: JetJoe OWNERS thread - 5/5/2005 1:54:48 PM
Skymac
Status: offline
No you can't adjust pump voltage past the start ramp proceedure. If it more than likey the FADEC on Luis's motor with eratic RPM readouts which will quickly be diagnosed and repaired. With the Stock pump you may have to run a pump ramp as high as 15 for fast startups where the FW pump is around 5.
Justin Tidwell
       Post #: 12
RE: JetJoe OWNERS thread - 5/5/2005 2:21:58 PM
unknown
Status: offline
< Message edited by unknown -- 5/5/2005 4:00:46 PM >
Love this hobby
       Post #: 13
RE: JetJoe OWNERS thread - 5/5/2005 3:20:53 PM
seanreit
Status: offline
Hey guys, sorry to just get into the thread but I wasn't going to go public unless someone brought it out first.
Here are my thoughts on the Jet Joe engine I had in Austin.
In my opinion, the engine is good thus far. I think the upgraded fliteworks pump that was sent is good. I'm fairly certain that the RPM sensor that was in the one I ran is NOT GOOD. Easy enough to replace I suppose, but certainly something that I was su
