RE: Wild Hare Extra 260 Pictures
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> RE: Wild Hare Extra 260 Pictures
Page: <<   < prev  26 27 28 29 30 31 32 [33] 34 35   next >   >>
Login
RE: Wild Hare Extra 260 ... - 7/23/2006 12:35:59 AM
mstroh3961
Status: offline
According to bill the wing bolt vibrated out in flight, or was not installed preflight.
_____________________________
Regards
Mark
(in reply to rbuhrman)
       Post #: 801
RE: Wild Hare Extra 260 ... - 7/24/2006 1:43:03 PM
Scoubidou
Status: offline
Hello
i move the CG 3/4'' back of recommended and i was surprised to see how the plane flies.
I do not need rudder-elevator mix and rudder to aileron mix.
I can fly inverted (horizontal or 45 degres up) with hand off the transmitter
Daniel
Seneca Engineering
http://www.seneca.ca/
(in reply to mstroh3961)
       Post #: 802
RE: Wild Hare Extra 260... - 7/24/2006 10:42:20 PM
Rocky V.
Status: offline
Hey dntmn,
How's that Graphtec 3d weave gear holding up ? Was it the one for the Carden 35% extra ? Did you get it from TBM ?
Victim of Gravity...
(in reply to Scoubidou)
       Post #: 803
RE: Wild Hare Extra 260... - 7/24/2006 10:59:33 PM
Dangerous Dan
Status: offline
Rocky Keep the aluminum on I switched back after the third flight. I will be sending it back to graftech for replacement gear. I had a moderatly hard landing and it delaminated. Aluminum will be staying on my 260.
when inverted down=up and up=$$
(in reply to Rocky V.)
       Post #: 804
RE: Wild Hare Extra 260... - 7/25/2006 2:41:35 AM
Bobby Folsom
Status: offline
Rocky V and Dan: I ended up putting a "not needed anymore for a 35% Carden Edge" landing gear on my WH 260 and have not had any further gear bending problems. The original WH Al gear was just like tin foil - even on a relatively soft landing it would bend back and ruin my flying day. I tried one of Tom's fiberglass gear but it delaminated. Sooo, that's why the 35% Carden Al gear. All it took was to drill out the mounting holes (fuse mount) and bolt it on. It's about the same weight (who worries about weight??) and looks good.
Bobby
(in reply to Dangerous Dan)
       Post #: 805
RE: Wild Hare Extra 260... - 7/25/2006 7:18:52 AM
Rocky V.
Status: offline
Yea Bobby, that's where I'm at now. Yesterday, after landing, made a turn at the end of the run-way that did'nt feel too fast but when the plane was comming back toward me one leg was bent up, or in, depending on how you look at it. I bent it back, but now it makes me a little nervous. Also cracked the wheel pant on that side. I took them off and flew more on it yesterday, but set it down very gingerly.
(in reply to Bobby Folsom)
       Post #: 806
RE: Wild Hare Extra 260... - 7/25/2006 1:27:03 PM
rctom
Status: offline
May I suggest two options for a stronger gear.
The gear from our G202 will fit with a little drilling, and it's much stronger. I think this is because of the straight legs.
Also we sell a glass-filled nylon gear made by Tetherite. It's about the same size and weight as stock and it seems to be very strong. Also a straight leg gear.
TF
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 807
RE: Wild Hare Extra 260... - 7/25/2006 1:40:10 PM
Scoubidou
Status: offline
Hi Tom
Do you still have the white painted FG gear with rounded (scale look) legs? I would not recommend it. It's the same weight of your aluminium gear but mine begins to delaminate and cracks after only 20 flights and not hard landings?
I plan to switch to stock aluminium soon.
Daniel
Seneca Engineering
(in reply to rctom)
       Post #: 808
RE: Wild Hare Extra 260... - 7/25/2006 4:10:31 PM
rctom
Status: offline
We quit selling it because of all the problems.
TF
       Post #: 809
RE: Wild Hare Extra 260... - 10/11/2006 3:00:22 PM
Scoubidou
Status: offline
Is there something that i can do to lock the wings in upright harrier?
Seneca Engineering
(in reply to rctom)
       Post #: 810
RE: Wild Hare Extra 260... - 10/11/2006 3:19:18 PM
Dangerous Dan
Status: offline
quote:
ORIGINAL: Scoubidou
Mine don't rock unless I enter it with a wing low.
       Post #: 811
RE: Wild Hare Extra 260... - 10/11/2006 4:18:49 PM
Scoubidou
Status: offline
Did you connect elevator servos with a matchbox or mixed together in the receiver?
Seneca Engineering
       Post #: 812
RE: Wild Hare Extra 260... - 10/11/2006 4:20:19 PM
Jecarte
Status: offline
Move your CG aft
       Post #: 813
RE: Wild Hare Extra 260... - 10/11/2006 5:45:46 PM
Scoubidou
Status: offline
My CG is set like this:
-fly the plane 45 degres upline
-1/2 roll inverted
-hands off on the TX, the plane continue to climb at 45 degree without touching elevator.
Is my CG to much forward?
Seneca Engineering
(in reply to Jecarte)
       Post #: 814
RE: Wild Hare Extra 260... - 10/11/2006 5:59:41 PM
