C.R. Fowler
Hello again Hackmaster, Don't open up the back of your chute yet. First check the weight of your diver as compared to the size of your chute. Our chutes are 22"x49" and the entire unit weighs 2lbs. If your jumper is too light for the size of your chute it won't get up much forward speed. If your chute is too large for the weight it is carrying, try adding some lead to your jumper in a place that you can remove it without making a mess on your little dude. When you add weight of course this will make him come down quicker, and also move forward faster, so you will have to be sure and turn into the wind and flair on landing so you won't stob him in the ground if you have added too much weight. There is one more thing you should check. If the steering lines are too short it will have the back of the chute pulled down and the brakes will be on all the time, this will kill your forward speed big time. I don't know how your steering lines are hooked up but if they allow any room for lengthening them do so. I would suggest about 1/2" at a time, but if the brakes are really hard on you may have to go 1" at a time. Try these things one at a time so that if you cure the problem you will know what was the problem. I would suggest checking the brakes first then check the weight. If you do end up having to open the back of your chute it won't ruin it, you can simply sew it up again. Good Luck, C.R. R/C Skydive USA
_____________________________
C.R. Fowler
