Panzlflyer
NC, USA Status: offline
The last few I have dealt with had all run too hot with poor cooling and to lean mixes, I think it softenes the carb block and in the ones I looked at had allowed the gasket to pull in which again made it worse because that leaned it still more due to air leaking in. Be carefull about how tight you crank the carb bolts, the plastic block deforms easily. Not saying you leaned it but poor cooling is a common problem on Yaks because of the cowl (happened to me as well). As long as it transitions then a little burble is fine, dont know why eveyone is obsessed with trying to get rid of it.
