CK1
NC, USA Status: offline
It is apparent that the manual hasn't been updated , several steps to be performed in the manual are already done on the latest kits , ie hinges are flat type not as depicted in the manual and are ready for gluing , the cowl is already fit to the fuse and blind nuts installed as well as blind nuts installed in the canopy hatch The firewall is left undone for custom fit to your engine set up . You have to figure engine box length , adjust it to your needs and set the firewall. The firewall ply appears to be thin but is very hard . You may want to go with thicker firewall ply to suit your needs . Once you have measured and dry fitted firewall and boxing, reinforce with tri stock in all corners ,apply 30 or 60 min epoxy to all joints and assemble , clamping until dry . No different than setting up any other firewall , engine box .. Ohh ! dont forget to pin the firewall ..
_____________________________
"Aint this great !!" Chris
