RE: Who is selling Seidel radial engines?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Who is selling Seidel radial engines?
Page: <<   < prev  1 2 3 4 5 6 [7]
Login
RE: Who is selling Seidel radial engines? - 6/23/2008 7:51:22 PM
baron-noir
Status: offline
Hi all,
I'm considering a Seidel 710 for 2 projects ; Savex Aero102 and possibly the Flair Stearman. I found a vendor in Switzerland who has the 710 on stock with a nice ring muffler installed. I contacted also Solo prop to have a quote on their 2 props hub assemblies, but they need to know the propeller size. Can any solo prop / Seidel 710 or 770 owner advise about their choosen setup ?
Thanks indeed
Sk
Click to see fullsize image.
Click for fullsize
< Message edited by baron-noir -- 6/23/2008 7:54:26 PM >
_____________________________
Back by Dope Demand - The King Bees
(in reply to chasrb)
       Post #: 151
RE: Who is selling Seidel radial engines? - 6/23/2008 8:53:33 PM
Spuetz
Status: offline
Hello SK,
my Savex Aero is ordered and will - hopefully - be finished in August. Haven't heard from them after two e-mails but I keep my hopes up!
I will put one of my spare 770ies in it. So lets definitely stay in contact to share our experience and ideas!
I will make my own ring muffler the same way as seen on the Savex page. (see picture below) I have contaced the builder of that Aero and he gave me advice. I like that solution much more, than a front ring - more scale. And temperature will be no problem I suppose - since it is not exactly a high performing engine... Imagine a 60 size four stroke running at 5000 rpm. Not much heat there. So here we have seven 60 size engines... Big deal...
As for the Solo-prop: Seems to be a problem with the 770 -cause of the hub. The 710 won't pose a problem there
I am running a wooden 24x10 on a Seidel 710 (Menz). However, that is a Biplane - supposed to be slow!
The Aero I would like to be a bit faster, given the shape and appearance of the plane - which reminds me of the golden age racers. Hence I would not go bigger than 22 inch on a two bladed prop. About 20 on three blades I suppose. Then fiddle around with the pitch to bring it up to about 4200 rpm on take off. That would get it to about 5500 in speed flight (hopefully,that is a rough guess!)! Should be rocking...
Anyhow - lets stay connected...
Cheers, Martin
Click for fullsize
(in reply to baron-noir)
       Post #: 152
RE: Who is selling Seidel radial engines? - 6/23/2008 9:43:05 PM
baron-noir
Status: offline
Hello Martin,
Funny before your post I just went to Savex website and have seen the same picture. It made me wonder about the prop size. I was also assuming that it was your model, or was it the Gnome's one ? I don't know anymore... About the ring muffler for the Aero102 you're absolutely right ; the rear one as shown in your picture is more scale and is quite a clean install. The original seemed to have it behind the engine as well (see original picture from Savex). So I will probably have the front ring muffler bought with the engine that will go for the Stearman and I will have another one done for the Aero102. Let us know when you receive your kit (lucky man ! ) Did you order it with a paintscheme ? Vaclav was not very clear about if he was offering paintschemes also.
PS
Notice the original had a 3 blades prop. Wonder if solo prop will have a solution for this, BTW thanks for your prop size advises, I will get back to them with a 22' 2 blades / 20'' 3 blades request
regards
Sk
Click for fullsize
< Message edited by baron-noir -- 6/23/2008 9:55:16 PM >
(in reply to Spuetz)
       Post #: 153
RE: Who is selling Seidel radial engines? - 8/7/2008 9:22:38 AM
Spuetz
Status: offline
Hello Charles and everyone,
it had to happen one day! Sh....
Engine stopped after a loop. And then - I still cannot believe it - I commited the ultimate pilot mistake. Learned about it intensly during my own flight training, and still: I tried to turn back to the field. NEVER DO THAT - especially not with a biplane, unless you have more than sufficient altitude.
So a sudden stall and down it went.. See the results below.
But it will fly again! will be a lot of work, but heck - gotta do it!
Click for fullsize
       Post #: 154
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.625RCU1
