RE: Wildhare Ultimate Build Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> RE: Wildhare Ultimate Build Thread
Page: <<   < prev  3 4 5 6 7 8 9 [10] 11 12   next >   >>
Login
RE: Wildhare Ultimate Build Thread - 1/18/2006 4:15:35 PM
BULL-RCU
Status: offline
quote:
ORIGINAL: Silversurfer
Bull-RCU,
If you have the Taurus, run it. The Brison works extremely well, but there's nothing like having more power!! You WILL have more power! There won't be any weight penalties at all. The reliability factor will be at least equal to the Brison. There would be no hesitation on my part to use the Taurus over the Brison.
Pat
Pat
"No" I don't have the Taurus, I have the Brison 3.2... Just after ready about the Taurus it made want one. I would probably sell the 3.2 Brison add some cash to get the Taurus. I'm not some extreme 3D guy, but I do want to be able to pull out of a Hover and do flat spins Rolling circles. I just don't want it to be underpowered. The reason I went with the Brison is I have the 2.4s and it has been a great motor. I just want to make sure it's not underpowered.
_____________________________
Visit my WEB Site www.nobullsales.com Check out my gallery!
(in reply to Tired Old Man)
       Post #: 226
RE: Wildhare Ultimate Build Thread - 1/18/2006 8:35:20 PM
Tired Old Man
Status: offline
Okay, the clarity helped.
The Brison 3.2, which I have in mine, will leave you with no limitations either. If you don't have a burning need to spend the cash, then don't. With my Ultimate and the Brison 3.2 acceleration out of the hover is excellent. So is holding the hover. There is AMPLE power for ANY maneuver you want to do, including rolling harriers, waterfalls, elevators with change overs into other maneuvers.
Back to the Taurus. If you already had it, then I would say to install it. But if you have the Brison and the Taurus would be a new purchase I don't see the point. What many (if not most) fail to understand is that the differences between the DA50, the Brison 3.2, and the Taurus 52 are relatively minor. Most of those are in the engine weights, with the Taurus having a slight actual power advantage over both, IMO. Definatel not enough of a difference to run out and spend several hundreds of dollars extra for, or to sacrifice any value in a sale of the Brison to make the change. You'd be far better off managing the weight of the aircraft and making good prop selections.
I feel no need whatsoever for a larger or different engine from that which I already have in the Ultimate. That 3.2 Brison will not leave you wanting for more power.
Pat
If you can''''t fix it with a hammer, you have an electrical problem.
(in reply to BULL-RCU)
       Post #: 227
RE: Wildhare Ultimate Build Thread - 1/18/2006 8:43:20 PM
BULL-RCU
Status: offline
Thanks for the reply Pat. What did you end up using for a prop on your Brison?
       Post #: 228
RE: Wildhare Ultimate Build Thread - 1/19/2006 7:13:09 AM
Tired Old Man
Status: offline
I'm currently using a Mejzlik 22-8. I would have used a Menz in the same size but the nose was light enough already. Normally I would have used an MSC 22-8, but the weight of the Ultimate (light!) and the additional drag of the second wing pushed me more towards speed over thrust. The choice worked out really well. It's not fast unless you want it to be and pulls vertical out a hover, as some would say, "with authority".
Pat
       Post #: 229
RE: Wildhare Ultimate Build Thread - 1/19/2006 2:49:23 PM
airborneSGT
Status: offline
I think any good 3.2 is all you need. Here is a somewhat low hover shot with the 3.2. I think the only way you could go better is a small twin like the 3W 56 or 48. Twins just have more torque.
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 230
RE: Wildhare Ultimate Build Thread - 1/19/2006 4:20:58 PM
RTK
Status: offline
Posting for Pat (Silversurfer)
For those that want to do the struts, here's some pics to work with. Shaft distance from the aileron trailing edge is 15mm. Harden or fill the inside of the aileron so not to crush. That's really important. The separation of the horn from the aileron surface is not important, as long as both sides are the same.
Pat
Click for fullsize
Click for fullsize
(in reply to airborneSGT)
       Post #: 231
RE: Wildhare Ultimate Build Thread - 1/19/2006 6:07:24 PM
crhammond
Status: offline
I'm just getting to the point of hooking up the ailerons on mine... that linkage seems like it might be a good idea... saves a bunch of weight and I already have 5945 servos which have plenty of juice... I just happen to have some extra MK clevices, control horns and some 1/8 cf rod around too... hmmm...
You are right... as long as the linkage connects at the same distance from each aileron the control throw should be identical. Might take a little longer to set up at the field but it's just an extra 4 screws to remove the connecing rod between the ailerons... hmmm... light is good, 2 less servos to power Are you getting any extra flex with this setup? How did you install hard points for the linkages int he trailing edge - did you just insert dowels?
So far I have my wings built, struts aligned, incidence set and tail feathers installed. Just waiting on my new Cowl so I can mount the DA50... probably another 10 hrs work and she'll be done. The build has been very smooth and uneventful so far... about the hardest part was making new aircraft-ply tabs - and that was darn easy LOL.
Chris.
Wings Level.
(in reply to RTK)
       Post #: 232
RE: Wildhare Ultimate Build Thread - 1/20/2006 1:00:19 AM
Tired Old Man
Status: offline
First, thanks to RTK for posting the pics for me. The server I'm using at the moment won't interface with RCU all that well, and pics just don't seem possible from this end.
Regarding the aileron stiffeners, I was in a hurry so all I did was to drill a hole just large enough to fit the tip if the Gorilla glue into. Squeezed in a bunch and taped it over until it dried. Seems to work so far, but installing an actual hard point would be a lot better.
Flex, what flex?? There ain't no stinking flex!! Really, there's no noticable flex, and control motion will be the same top and bottom if the angles of the horns equal the angle of the ailerons. Even if it ends up off a tad due to a miscalculation in the screw angles you will have far more than you need for maximum performance in anything. If you have more than 30 degrees of aileron travel with this plane you are going to get into trouble very quickly. Those that are used to setting up 3D aileron travels at 35 degrees and up need to re-think the issue for a biplane.
It does take a few minutes longer to set up at the field, but that just gives you more of a chance for a better pre-flight, and the time needed to answer all the questions from the other people at the field about how great it flys! I leave the struts connected to the bottom aileron during dissasembly, and use a small piece of velcro to secure the strut to the aileron control rod to keep them from flopping around during trqansport and storage. Then again, it will fit fully assembled in the back of a standard pick up.
Pat
< Message edited by Silversurfer -- 1/22/2006 6:25:22 PM >
(in reply to crhammond)
       Post #: 233
RE: Wildhare Ultimate Build Thread - 1/27/2006 8:17:59 PM
BULL-RCU
Status: offline
Just got back to work on mine... Winter here in NY, but spring is approching fast. Decided to use the 3.2 Brison I have. Thinkit will be fine...
       Post #: 234
RE: Wildhare Ultimate Build Thread - 2/15/2006 8:43:54 PM
tomriddle
Status: offline
p51flyby,
Could you do me a favor? Would you post a couple of pictures of your radio and battery set-up if you get the chance? I'd like to see how you arranged your electronics so as to maximize access to the "innards"
Spoke with Tom at Wildhare today and he said he would probably ship my Ultimate this afternoon! What a nice gentlemen to work with. He was extremely helpful and made sure I was comfortable with the hardware selection I was making.
"Life is tough;
but its tougher when you're stupid!"
(in reply to p51flyby)
       Post #: 235
RE: Wildhare Ultimate Build Thread - 2/21/2006 1:20:40 PM
tomriddle
Status: offline
Tom,
My Ultimate arrived a day ahead of schedule and the packaging was very effective - despite obvious rough handling in transit, the airframe was totally untouched. The hardware kit and servos arrived at the same time. Thanks again for such great service!!
v/r
tom
"Life is tough;
(in reply to rctom)
       Post #: 236
RE: Wildhare Ultimate Build Thread - 2/21/2006 1:27:46 PM
p51flyby
Status: offline
Tom,
I have a different way to mount the receiver, that I hadn't seen mentioned on this thread. Unfortunately, I'm on my way out the door to the airport, and will be gone all week. I'll post pics this weekend, hopefully on Saturday. You'll definitely enjoy your ultimate.
(in reply to tomriddle)
       Post #: 237
RE: Wildhare Ultimate Build Thread - 2/21/2006 1:32:00 PM
tomriddle
Status: offline
Gary,
Thanks for the reply - whenever you can get to it would be fine; have a safe trip!
tom
"Life is tough;
       Post #: 238
RE: Wildhare Ultimate Build Thread - 2/21/2006 5:21:34 PM
Tired Old Man
Status: offline
I have a few inner pics. Perhaps I can get them to upload this time. I'll edit this a few times for notes.
The first pic is where I placed a Matchbox. Only used the one since I made slave struts for the ailerons. Just behind the wing saddle. The open space to the left of the throttle servo is where the receiver is located.
The second pic is a view of how the wires and extensions are secured coming from the tail. That was done in three locations to support the wires. Yes, the covering was removed to do this, but for me it's not a big deal to gain the extra life in the wiring. With the same photo you'll see a shadow from the carbon rod on the canopy floor. That's exactly where a new tray for the flight and ignition batteries is located. I'll be moving one of the two batteries forward for a 6-3/4" C/G. Currently it's at about 7-1/8". Don't go there!
Third pic is where you can remove some weight from each "I" strut. Not a lot, I agree, but it's weight just the same.
Fourth and fifth pics are pretty much self explanatory.
Sixth pic shows the second (lower) shelf installed with the regulators. It's easily removable to access the receiver and servo under it. The large hardwood block included with the parts kit was not used. Aluminum angle is lighter.
The only items mounted forward of the bottom wing leading edge is the engine, ignition, and spinner. Both switches are mounted aft of the wing saddle in the ply sides. I used pin switches (Fromeco) so I'm not sure if enough space is available in the same places for standard switches. You can just see one in pic number 6 to the far lower right. There's another one that's not visible at the same relative location at the top of the pic.
I have three other pics that are too large to send from this location that I sent to Tom with the hope they can get uploaded by someone with a lot more computer skills than I have.
One is of the tail wheel linkage using wire to connect at the tail wheel tiller. Different springs were used 'cuz I liked them better. The other two are completed pics that show the slave struts. Whoops, looks like the tail wheel linkage is going to take. The reason for the wire at the tiller bar is because the metal edges in the bar are too sharp and cut standard fishing line and the Dacron line I used at the other end. Using left over wire from the tail flying wires works out just fine.
Pat
Click for fullsize
