RE: Wildhare Ultimate Build Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> RE: Wildhare Ultimate Build Thread
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: Wildhare Ultimate Build Thread - 5/16/2005 3:50:17 AM
Ken Bryant
Status: offline
First I had to set the incedence on bottom wing to match the horiz stab. Mine was off by a -1/2 degree. I spaced it and got it to zero.
Next I sset the upper wing in, it's incendence is set to -1 degree off the lower wing.
I then glued in the strut tabs. I held it all together with the tape while it dried.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Ken Bryant -- 5/16/2005 4:01:13 AM >
_____________________________
Ken
(in reply to 85bipe)
       Post #: 26
RE: Wildhare Ultimate Build Thread - 5/16/2005 3:55:29 AM
Ken Bryant
Status: offline
The cabanes....
I had some that where misdrilled by the factory. So I redrilled and got them square on the center rib where I wanted them.
I also took off the excess center rib so mine blended smooth with the forward cabane strut.
These pictures show the center rib before and after. The slightly blurry picture showes where the stok struts would have ended up. THe sweep is top pointing forward. I didn't care much for this look.
Click for fullsize
Click for fullsize
Click for fullsize
Ken
(in reply to Ken Bryant)
       Post #: 27
RE: Wildhare Ultimate Build Thread - 5/16/2005 3:58:53 AM
Ken Bryant
Status: offline
I modified the struts to fit where the forward strut was more perpendicular to the fusalage. I also had to shorten the cross brace that was in my kit.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Ken
       Post #: 28
RE: Wildhare Ultimate Build Thread - 5/16/2005 4:03:53 AM
Ken Bryant
Status: offline
Here I am attaching the alerons to the wings. I chose to leave hte wings on the plane just because it gave me a place to work with.
Wife really doesn't mind me doing this in our living room either.
Click for fullsize
Click for fullsize
Ken
       Post #: 29
RE: Wildhare Ultimate Build Thread - 5/16/2005 4:05:40 AM
DENNIS C
Status: offline
Ken what do you mean you glued in the strut tab's do you have a picture of the tab you can post.
"Opinions are like Buttholes EveryBody has one "
       Post #: 30
RE: Wildhare Ultimate Build Thread - 5/16/2005 4:24:14 AM
Ken Bryant
Status: offline
I didn't get a picture of the tabs but I will get one tomorrow. In the mean time I will try to discribe.
The wing struts mount to 2 tabs on each wing. The strut slides down on the tabs and you bolt the strut through these tabs. If you look at this picture you can see the bolts in the struts. Just picture the tabs where those bolts are.
Actually I got around to getting the picture tonight.
Click for fullsize
Click for fullsize
< Message edited by Ken Bryant -- 5/16/2005 4:44:23 AM >
Ken
(in reply to DENNIS C)
       Post #: 31
RE: Wildhare Ultimate Build Thread - 5/16/2005 4:59:33 AM
SAL98
Status: offline
Heres a shot of my wings and linkage so far
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 32
RE: Wildhare Ultimate Build Thread - 5/16/2005 5:02:09 AM
SAL98
Status: offline
With wing done.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to SAL98)
       Post #: 33
RE: Wildhare Ultimate Build Thread - 5/16/2005 5:08:22 AM
SAL98
Status: offline
Hi Ken, I'm just getting around to wiring this bad boy up. Just looking for the right spot to put a few switches an things.
I might go with the front former since there is'nt that many choices.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to SAL98)
       Post #: 34
RE: Wildhare Ultimate Build Thread - 5/16/2005 10:41:04 AM
DENNIS C
Status: offline
quote:
ORIGINAL: Ken Bryant
I know how they attach i was asking if you had to glue in the tabs to the wings. thats the impression i got from your post.
       Post #: 35
RE: Wildhare Ultimate Build Thread - 5/16/2005 1:25:21 PM
rctom
Status: offline
Yes the tabs must be glued into the wings. This leaves a little flexibility in positioning things.
In case the user wants a little different incidence in the top wing, or if in manufacturing the alignment did not come out perfect this allows some adjustment during assembly to get everything exactly where you want it before finally gluing the tabs in.
TF
< Message edited by rctom -- 5/16/2005 1:35:05 PM >
       Post #: 36
RE: Wildhare Ultimate Build Thread - 5/16/2005 1:26:28 PM
Ken Bryant
Status: offline
Yes, I glued the tabs into the wing.
Bottom wing first. I applied some thick CA into the wing then inserted the strut with the tab attached to the strut.
When it was dry I positioned my top wing to get the correct incedence. Then I used thick CA on the top tabs that are already secured to the strut and put on the top wing. I rechecked my incedenece and taped it in place.
After I was sure the tabs where secure I disassembled the struts from the wings and poured thin CA into the tab slots to secure them further.
FWIW, this is also covered in the manual.
Ken
       Post #: 37
RE: Wildhare Ultimate Build Thread - 5/16/2005 2:09:09 PM
