zeng62
MI, USA Status: offline
Finally got my Ultimate in the air. First flights are allways nerve rackning, however it went perfect. My Ultimate is set-up this way: (I hope to answer a few concerns people have had) Engine: Stock Zenoah G-62 W/ a home made stainless steel pitts style muffler. (no battery ingition) Battery: 6 volt KR-1700AU 1700 mah (weight-6.5 oz.) set in the fuselage as far back as possible CG-about 1/4" - 1/2" behind the recomended location. (I will use this setting for a while as it required little down elevator when inverted. Servoes-Aileron- futaba S9402 x 2 (I used only 2 aileron servoes and connected the top and bottom with a pushrod) Elevator- tower TS-70 X 2 rudder- Hitech HS945MG X 1 (in tail location) Fuel tanks- 1- 4oz. header tank, 1- 24 oz. main tank located on the CG Incidence- as recomended Tail wires- 4-40 wires (metal solder clevis/ Dubro plastic - metal pin) Control throws- AS RECOMENDED WEIGHT- 20 LBS w/o fuel ****************************(corrected so to a scale error) First flight thoughts: it only required 3 clickes left and 1 click down to flyhands off pitches to the belly and rolls rt in a left knife edge (not much though) VERTICLE --- OUT OF SIGHT Hover- good (easier than my 1/4 scale Gene Saucy Exrta) Tracks- Very good through loops Inverted - Small amount of down Spins - Very nice Flat on high rate and very nice and predicable natural spin (elevator and rudder only) on low rate Snap rolls- good and clean More to come, maybe tomorrow. THANKS FOR THE GREAT BUILD THREAD, THE INFO WAS A VALUED HELP. The only thing I didn't like was the instructions and they weren't that bad
< Message edited by zeng62 -- 9/17/2005 4:00:12 AM >
