Tired Old Man
Joined: 2/25/2002 From: Central, CA, USA Status: offline
Tom and I discussed this at length over the phone the other day and he brought up a point that I had failed to note. The slave struts will work just fine but some things have to be kept in mind. Number 1, and this is the one Tom caught, is that there will be unequal travels between the top and bottom ailerons if you use a strut that surface mounts to the ailerons. The best way is to have the slave control rod exiting from the center of the aileron to a point inside the wing ala full scale. Experience to date has shown that a small difference in travels between the top and bottom aileron has an insignificant impact. Number 2 is that the strut itself can't be prone to a lot of flex. Really screws up the performance of the upper aileron and doesn't do the servo much good. I've been doing bipes for many years and found a long time ago that carbon fiber rods seem to work the best for the weight involved. Number 3 is the attach point of the carbon fiber rod to the ailerons and the pivot point. Done incorrectly and you can bind up a control rod and servo in a big hurry. Been through that before and found that the Nelson Hobbies pivot clevises will work fine in a vertical to vertical arrangement. Number 4 is the lack of a econdary hard point in easch aileron for slave strut attachment. That one is pretty easy to get by using the existing hard points with the right connectors. basically just another 6-32 screw. As I said before, I will complete the installation and full performance test flights, then post performance info. I will post pics and methods as they are performed. Without being over confident, I'm certain that it will work out well. Tom is absolutely correct in providing this plane with a 4 aileron servo installation. Done incorrectly, slave struts would be a major stumbling point, to the dissapointment of the buyer. Tom has gone to great lengths on every product he has marketed in the attempt to assure a quality product that all can enjoy.
_____________________________
If you can''''t fix it with a hammer, you have an electrical problem.
