vti-chris
Joined: 1/5/2005 From: Nicosia, CYPRUS Status: offline
You are correct,BUT for someone who doesn't know much it won't help much! When i first started in nitro buggies i had that idea in mind,but it's not much of a help. Yes higher nitro means higher pressures and temps insite the engine(not nesessarily higher temps engine).It can keep the plug glowing easier that's why you need a colder plug,so that it won't get THAT hot(advance timing-detonation).BUT you don't want to go the other way either.A TOO cold plug will need TOO lean settings to keep it glowing cause a richer mixture cools it down.As you lean it, temps go high(engine) and engine damage will occur. So start from a medium plug and go up by trying and see what keeps the temps low and idles well and lasts at least 1-2gallons. I used to use the OS A5 on my hyper and temps were at 270F in order for it to work right without bogging.I changed to a medium plug and it lowered the temps to 230F and it was easier to tune!
_____________________________
Xray 808 Sirio BX Sti
