Cutting Boards
Tower Hobbies
Logged in as Guest
  Printable Version
Airworld BAe Hawk - RTF
Seller:  rambat1
Details:   $23,000.00   |  8/17/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Questions and Answers >> Cutting Boards
Page: [1]
Login
Cutting Boards - 12/31/2001 11:29:27 PM
James Goss
Status: offline
What type of cutting board do you use to cut balsa, light ply, and film covering. I thought it would be interesting to know what everybody else is using. I have tried several over the years, but I am now using the best of all I have tried. I placed a 1/4 inch thick, 6 feet 8 inch by 3 ft. wide plate glass sheet on my cutting table. You would just have to try it to believe how well it works. Knife blades stay sharp much longer and you will get some of the cleanest cuts in your film coverings that you have ever had. James Goss
_____________________________
Visit my website at [url]http://nav.to/jgosscacc[/url]
       Post #: 1
Cutting Boards - 1/1/2002 4:14:59 AM
TopShelf
Status: offline
Use the glass (well actually an old mirror) for cutting film and one of those self healing mats for balsa and other stuff.
Kent
He Who is a Slave to the Compass has the Freedom of the Sky.
www.TopShelfRC.com
(in reply to James Goss)
       Post #: 2
Cutting Boards - 1/1/2002 5:13:49 AM
depfife
Status: offline
I have an interior door on top of my building table that works good. It is flat and smooth and T pins go in it fairly easy. I have thought about using glass, but what do you do when you need to pin something down? (That bottle of thin CA I had run out on the table would have been easier to clean up on the glass.) I guess I could get one of those magnet boards, just never tried one.
Eric
       Post #: 3
Cutting Boards - 1/1/2002 5:24:00 AM
depfife
Status: offline
< Message edited by depfife -- Jan 1 2002 5:00AM >
       Post #: 4
Cutting Boards - 1/1/2002 8:59:48 AM
Walt-RCU
Status: offline
Eric:
This will get me in trouble but doors are great to work on and glass is great to cut on, don't mix the two, they are just tools to use to build on.
They're just jigs used to build on.
Walt
       Post #: 5
I use ceiling tiles on a table. - 1/9/2002 7:21:59 AM
PT40
Status: offline
       Post #: 6
Self Healing Mats - 1/9/2002 11:10:10 PM
OldRookie
Status: offline
How are the self healing mats for cutting covering material?
Top Shelf mentioned that he used the mirror for cutting film, and a mat for cutting other material. I thought that the self healing mat was made for cutting covering. What are the drawbacks of the mat?
Greg
       Post #: 7
Cutting Boards - 1/10/2002 1:13:47 AM
James Goss
Status: offline
I think some of you are confusing cutting boards with building boards. These are two separate subjects; you do not use a building board as a cutting board. A good building board such as ceiling tile can be used over and over to build maybe 25 or 30 planes on if it is prepared in the right way. If you use it as a cutting board it will be destroyed in no time at all. I have found that cutting film on a cutting mat will allow the film to be pulled into the cut and not be as clean of a cut as you will get on glass. James Goss
       Post #: 8
Cutting Boards - 1/10/2002 1:49:41 AM
Nathan
Status: offline
I use a cutting table made of glass, and a razor wheel for cutting.
Click to see fullsize image.
Click for fullsize
< Message edited by Plane Insane-RCU -- Jan 9 2002 8:57PM >
Nathan M.
Administrator
RCUniverse.com | Wattflyer.com | RCUvideos.com | Kaango.com
       Post #: 9
Cutting Boards - 1/11/2002 8:43:27 AM
tailskid
Status: offline
OldRookie,
I love those cutting mats sold through Great Planes - have a couple of them. Great for cutting both wood and coverings - just have to clean it up before cutting MoneyKote...
Jerry
# 93 in Club Saito
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
