Synthetic Oils
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Synthetic Oils
Page: [1]
Login
Synthetic Oils - 5/16/2005 9:35:03 PM
voodoodb
Status: offline
Could someone tell me the names of some of the Synthetic oils that can be used to make 100% synthetic fuels?
Voodoo
       Post #: 1
RE: Synthetic Oils - 5/17/2005 4:53:27 AM
platero
Status: offline
the most popular is Klotz, others are Micromotul and World wide racing fuels
_____________________________
my nick is my last name because i have not anything to hide
(in reply to voodoodb)
       Post #: 2
RE: Synthetic Oils - 5/20/2005 11:32:12 PM
voodoodb
Status: offline
Does anyone know if the Amsoil or Shell have a synthetic oil that will work in methanol as an oil?
Voodoo
       Post #: 3
RE: Synthetic Oils - 5/21/2005 1:34:54 AM
mentorman
Status: offline
Morgan fuels sells their Cool Power oil in bottles, some hobby shops have it and I just saw some at a go cart shop due to them using it in alcohol/methanol race fuel
BigStickSaito72,SuperstickSaito91,kaosOS40FX,sig kavalierOS40FP,
Ofna9.5C-hub Mach 28Mod. MGT LRP Spec 3 FOC CH4Mod
       Post #: 4
RE: Synthetic Oils - 5/25/2005 1:26:43 AM
terratorn
Status: offline
Along this same subject line, does anyone know if automotive oils (Syntec, Mobile One, Or such) could be used, as a fuel lubricant, if a suspension agent were added ? If so what might that agent be ? Thanx ahead of time, Terratornfont="Arial"]
(in reply to mentorman)
       Post #: 5
RE: Synthetic Oils - 5/25/2005 2:23:24 AM
boater
Status: offline
Automotive oils:: I believe Castrol R is castor (bean) oil and will blend with methanol, though not a synthetic oil but maybe of some use to those living far out. Another source for methanol oils may be Jet oils, I believe Mobil Jet II will work, but a test would surely be in order before buying bulk.
Rudy
(in reply to terratorn)
       Post #: 6
RE: Synthetic Oils - 5/25/2005 4:22:40 PM
downunder
Status: offline
Castrol M is pure castor but Castrol R is a blend of castor and (I think) a mineral oil. Synthetic car oils like Mobil 1 are only part synthetic so they won't mix with methanol. They probably would though if there was an additive that both methanol and mineral oils were soluble in. Ether would be perfect because that's one of its uses in model diesel fuel but I wouldn't even like to guess what the minimum % of ether would need to be.
Mobil Jet Oil II is very good but you need to be careful because it comes in two versions, generations 2 and 3, but generation 3 won't mix with methanol. Another jet oil that's almost as good is BP2380, it's biggest advantage is that it doesn't have the very heavy dark brown dye that's in the Mobil jet oil.
(in reply to boater)
       Post #: 7
RE: Synthetic Oils - 5/25/2005 11:32:26 PM
voodoodb
Status: offline
Just for everyones info, Shell Advance VSX will not blend with Methanol.
Voodoo
       Post #: 8
RE: Synthetic Oils - 6/25/2005 7:34:47 AM
iskandar taib
Status: offline
It's not whether an oil is "synthetic" or not that allows it to mix with methanol. Its whether the "oil" happens to be soluble in methanol or not. Most synthetic oils are not. What we use in glow fuel are known as Polyalkylene Glycols (PAGs), mainly made by Union Carbide (now part of Dow Chemicals). This family of chemicals is actually more related to antifreeze than to other oils. They are soluble in methanol because they have -OH groups in the molecule. Same thing is true of Castor Oil - it is the only vegetable oil (other than, I think, soybean oil) that has OH groups in the fatty acid chains.
Incidentally, years ago (in the 1970s) Castrol used to make something called "MSSR" which was a synthetic gear oil (probably PAG based) that was usable in glow fuel.
< Message edited by iskandar taib -- 6/25/2005 7:36:33 AM >
       Post #: 9
RE: Synthetic Oils - 6/25/2005 3:08:21 PM
downunder
Status: offline
Isky...the MSSR oil is still available in New Zealand and Europe as far as I can tell. Castrol seems to have a strange distribution system because some oils are readily available in some countries but not others. We don't have MSSR in Oz yet we could almost swim to NZ. Castrol M is widely available here in Oz but almost unknown in America.
(in reply to iskandar taib)
       Post #: 10
RE: Synthetic Oils - 2/25/2008 5:19:05 AM
jpjedi
Status: offline
Will the motul 800 factory line work ? (100% synthetic 2t oil)
Here in India I cannot get synthetic oils at all and do not want to use castor oil. I found this motul 800 on ebay.
If anybody knows somebody who wants to send me MSSR or micromotul...I would be very interested!
(in reply to downunder)
       Post #: 11
RE: Synthetic Oils - 2/29/2008 6:42:50 PM
mgoodwin
Status: offline
Hello All FHS supply in South Carolina has synthetic 62RM and Castor/Syn mixes That will work with methanol. Fuchs Silkolene has a Synthetic Super2SX that will mix also a Caster/Syn mix. Horizon Hobby has Morgan Oils Synthetics and mixes .I believe Blendzalls Synzall Synthetic Racing oil will mix. Also VP Racing fuels RS-7 is also suppossed to have been mixed with methanol. I would contact the manufacturers first. Maxima has a 927 Castor/Syn mix that will work. Amsoil and Redline will not.
Michael Goodwin
(in reply to jpjedi)
       Post #: 12
RE: Synthetic Oils - 3/1/2008 9:29:23 AM
balsaeater
Status: offline
quote:
ORIGINAL: downunder
Thanks for the good info
For Europe does anybody know all the "synthetic" oils and makes types etc that are available that mix with methanol
My bigger motors 90 15cc plus are generally running zero 0% or3% to 5% nitro with 10% "synthetic" oils and no castor with the smaller motors less than 90 15cc are similar mostly 5% nitro with 15% "synthetic"
The EDL "synthetic" is costing me E65.00 per gallon UK 1.2gallon USA (~$95 ~£50)
If I could reduce the price of the "synthetic" this would help lot
If the "synthetic" was even more superior to EDL and I could drop % oil to lower like 8% or even 6% that would help even more
So far all other sources which appear cheaper but add in the CRAZY HIGH shipping costs look to cost even more than the present solution but open to new information
Balsaeater
       Post #: 13
RE: Synthetic Oils - 3/1/2008 12:17:56 PM
jpjedi
Status: offline
yupz.
Just ordered morgan 100% synth and 10 liter of Motul micro synth oil which is designed for aeromodellers.
A friend of my sends me 5 liter Castrol MVVS which also mixes with methanol but it seems not in production anymore...
(in reply to balsaeater)
       Post #: 14
RE: Synthetic Oils - 3/1/2008 8:14:53 PM
XJet
Status: online
If you're going to use the Morgan synth, *don't* go below 17% by volume. It's not in the same league as the more advanced synthetics like the Motul Micro.
When I'm not here, I'm at RCModelReviews
       Post #: 15
