buddy box trim correction
Tower Hobbies
Logged in as Guest
  Printable Version
Spektrum DX7 - FULL SYSTEM!
Seller:  Erick Royer
Details:   $325.00   |  7/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> buddy box trim correction
Page: [1]
Login
buddy box trim correction - 5/17/2005 12:57:12 PM
f4uwarrior
Status: offline
Before I ask the question I want to give a little background. I'm using a buddy box setup like this: I have a Hitech analog focus 6 transmitter with receiver in airplane connected to a Futaba analog 6yf transmitter -which is the buddy box- by a Futaba cord. I'm not complaining about this setup because everything works fine...
...Except I have to set the trim way left on the buddy box for both the aileron and rudder so that it doesn't swerve crazy right when I switch over to the student. I still would like a bit more trim because it still tries to go a little right. Has anyone had this problem and is there a known solution to it? If there is, I can't think of it!
       Post #: 1
RE: buddy box trim correction - 5/17/2005 6:25:30 PM
Scar
Status: offline
quote:
ORIGINAL: f4uwarrior
The buddy box generates a signal with a 'Center', just like the instructor transmitter. If you want them adjusted to the same 'Center', so the trim tabs are in the same place, you'll have to have one or both adjusted. HiTec can do that, or Radio South, or a number of other transmitter service places.
Good luck,
Dave Olson
_____________________________
My spelling isn't good enough to post grafitti.
(in reply to f4uwarrior)
       Post #: 2
RE: buddy box trim correction - 5/19/2005 12:25:48 AM
f4uwarrior
Status: offline
Hi guys, Thanks for the tips. I talked to Radio South and they said the radios should be close by default. Anyway, it's given me something to think about and I believe I'll try to manually enter some additional left trim to the airplane's rudder and aileron so that the master trans. trim needs to swing a tad right. Then I can have more "left" to play with hopefully on both trans.
(in reply to Scar)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.281RCU1
