AFFORDABLEPARTY
Joined: 8/13/2005 From: hamilton, UNITED KINGDOM Status: offline
well got rid of the flames on start up. tried turning down the propane, but it didn't correct the problem. we then delayed the pump start up time and reduced the pump ramp time. no more flames or kerosene spitting out the engine. unfortunately, that was only one of our problems. Truthfully. about ready to throw the engine in the trash. the other problem that we have is the inconsistancy of the engine. this morning we started the engine three times in a row and this is what happened: 1. The first time it ran and and spooled up to maximum rpms no problem. thought all was ok. 2. The second startxt start. engine fires up idles no problem. But shuts down as i advanced the throttle (about 3/4) Puff of white smoke. 3.The third time it starts accelerates to full throttle was cycled twice between idle and 100% then the engine started to burn funny- throwing out a 3 -4 foot blue and yellow flame,. the rpms were fluctuating between 24 and 34 thousand rpms. I shut the engine down when i saw the end cone start to glow red. One of the problems is that so much is happending it is difficult to keep track of all the rapidly fluctuating numbers. Therefore, it is somewhat difficult to give the techs all the correct info so that they can help with the diagnosis. just a though perhaps i will try and remove the data box from the plane once it says running. perhaps it giving off some interference. Hey, willing to try anythig at this point. This engine is about three bad starts from the hammer an trash. NO JOKE For the record, the engine starts up and idles lovely. if we could just get the plane to take off and land at idle i wouldn't be so angry. P.S. the techs are great, in that, they are extemely helpful and have offered tons of advice. by the way, we operate at sea level. (the highest point in bermuda is 375 feet above sea level) todays weather hi - 71 degrees F lo - 62 degrees F barometric pressure 1013mb (29.94" humidity 94 percent perhaps this will help
< Message edited by AFFORDABLEPARTY -- 12/12/2005 1:00:16 AM >
