2 (two) props...same engine?
Tower Hobbies
Logged in as Guest
  Printable Version
TurboHeader Muffler
Seller:  RC Specialties
Details:   $69.95   |  8/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> 2 (two) props...same engine?
Page: [1]
Login
2 (two) props...same engine? - 1/1/2002 8:41:15 AM
ifly-RCU
Status: offline
i ran my .10 with 2 7x6 props on but im not sure if it put out more thrust or not
the rpms did go down(just by hearing it...no tach)
would this boost proformance or just ware the engine out faster?
any one did this??
       Post #: 1
Let me get this straight - 1/11/2002 1:56:38 AM
Chris 540
Status: offline
So you put both props on at the same time?? And ran the engine?? Why???:p
(in reply to ifly-RCU)
       Post #: 2
2 (two) props...same engine? - 1/12/2002 5:08:47 AM
gubbs3
Status: offline
It would be a lot better just to get a four bladed prop. As a rule of thumb, take one inch off for each extra blade.
Ex.- 10 x 6 2 blade
go to 9 x 6 3 blade and 8 x 6 four blade.
       Post #: 3
2 (two) props...same engine? - 1/12/2002 6:46:46 AM
Mr. Wildcat
Status: offline
Increasing the number of props decreases its efficiency. The most efficient props are one bladed followed by the more common 2 blade props we use. Multiblade props are normally used to obtain ground/fuse clearances, not extra power.
       Post #: 4
2 (two) props...same engine? - 1/12/2002 10:03:26 PM
Elwood
Status: offline
Stacking props will decrease the second props ability to produce thrust. There are not many aircraft that have stacked props, but when they do, they counter-rotate. Check out the Topolev Bear Bomber.
Click to see fullsize image.
Click for fullsize
< Message edited by Elwood -- Jan 12 2002 5:07PM >
_____________________________
Born in the U.S.A.......Not quite as long ago as Art!!!!!!!
       Post #: 5
2 (two) props...same engine? - 1/12/2002 10:06:27 PM
Elwood
Status: offline
Could not resist this pic. It shows just how they were dealt with, and by who!
Click for fullsize
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
4.610RCU1
