RE: Calling all Stars Wars aficionados
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Unusual R/C >> RE: Calling all Stars Wars aficionados
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: Calling all Stars Wars aficionados - 6/9/2005 4:27:06 AM
txaggie08
Status: offline
yeah it would work to
_____________________________
Proudest member of the Fightin Texas Aggie class of 08 Beat the h*** outa TU A- WHOOP!!!!!.
(in reply to sparow89)
       Post #: 26
RE: Calling all Stars Wars aficionados - 6/9/2005 4:16:05 PM
cwrr5
Status: offline
I can't wait to see what happens - sounds like some really neat planes (spaceships?) in the design process...
I'll have to wait for my tie fighter until October when I get home though. Probably small and electric. Roll stability might be a challenge, but should be possible. I LIKE the "rolling" landing idea, might be really fun.(away from the pits of course)
(in reply to txaggie08)
       Post #: 27
RE: Calling all Stars Wars aficionados - 6/9/2005 10:52:25 PM
The PIPE
Status: offline
The late Bill Evans' ASTRON comes to mind...
Dear Gravityisnotmyfriend:
The PIPE Here once more...and way back in the April 1979 issue of the AMA magazine, on pages 34 through 37, there's an article on the late Bill Evans' OWN take on a Star Wars X-Wing...his small [for 20 size engines] ASTRON RC plane!
Checking on the price of the planset, at http://www.modelaircraft.org/plans79.asp , the planset for the Astron is only $7.50 before postage...it's plan set number 257...and the AMA Digital Archive has the article available, for online printing...it MIGHT be what you're looking for, for "starters", at least...!
Hope this helps...
Yours Sincerely,
The PIPE!
"Pipe smoking contributes to a calm and objective judgment in all human affairs"...Albert Einstein, 1950
(in reply to Gravityisnotmyfriend)
       Post #: 28
RE: Calling all Stars Wars aficionados - 9/26/2005 5:53:20 AM
Status: offline
I had pretty much given up on the Star Wars plane. I made a couple of gliders to see how the tie fighter would work. I found that if it had enough wing to fly, it lost most of the scale appearance. I would've ended up with a wierd looking plane, but not exactly a tie fighter. I recently made a discovery that might put life back in this project. A friend of mine has a model of Vader's TIE. Did any of you guys know that there is a full body between the solar panels on Vader's TIE? I guess I alway just assumed that there were just pylons out to the panels like on the rest of the TIEs. The body of Vader's TIE looks alot like a wing. It's just begging to be airworthy. I have a Norvel .061, that I plan to use for power. I'm still working on the dimesions, but I'll start a new thread when I start making some progress on it.
The mathematician sees the glass as twice as big as it needs to be. The engineer sees it as full with a Safety Factor of 2.
(in reply to The PIPE)
       Post #: 29
RE: Calling all Stars Wars aficionados - 9/27/2005 10:23:30 PM
Status: offline
Here's some pics of the model that I will attempt to make airworthy. I'll have to take some artistic license with the leading edge of the "wing" but everything else should be able to stay scale. Any suggestions on the what size this should be? I was thinking about making it small enough to be powered with an .061, but I could make it 40 sized as well. I think the smaller vesion would be easier, but I'm open to suggestions.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 30
RE: Calling all Stars Wars aficionados - 9/28/2005 12:02:26 AM
ptulmer
Status: offline
Do both! Start with the 1/2a size. Build it with a sheet wing carved from 1/4 sheet balsa. Just round the front and slope the rear. It's very lightweight and most of all...FAST off the board. Think of it as a proof-of-concept model.
HomeMachinist.net!
Ulmer-RC.com
       Post #: 31
RE: Calling all Stars Wars aficionados - 9/28/2005 4:14:17 AM
cwrr5
Status: offline
Why not carve it from foam? I'm not usually a fan of "foamies", but this would be perfect. Lightweight, cheap, easy to work with...
I'm thinking deli trays(free if you ask nicely), stacked with a spar inside the airfoil. Can't wait to see this!
(in reply to ptulmer)
       Post #: 32
RE: Calling all Stars Wars aficionados - 9/28/2005 5:34:01 AM
txaggie08
Status: offline
ever thought about thrust vectoring off ducted fans? maybe a vertical lifting fan and a pushing/moveable nozzel. VERY consealable anyway
(in reply to cwrr5)
       Post #: 33
RE: Calling all Stars Wars aficionados - 9/28/2005 2:05:57 PM
Status: offline
If I make it 1/2A, it'll probably be made out of foam. If I make it .40 sized, it'll probably be mostly coro with some foam. This will just be for the prototype. Depending how it flys, I might build one out of balsa. I"m getting ahead of myself, I need to start cutting foam....
txaggie08, the thrust vectoring ducted fan sounds great, buy I'm gonna keep the first one simple and go from there.
       Post #: 34
RE: Calling all Stars Wars aficionados - 9/28/2005 4:09:16 PM
biteme
Status: offline
Hey guys! Sorry to jump in late, but I have seen a Hoth snow speeder, done as a hover/WIG(Wing In Ground effect)craft. I think I saw it on on of the WIG or Hovercraft sites, Maybe through Verners.com I am not sure. The modeler did a crack job,looked good, said it was made from cardboard and plastic tubing (straws?) it was maybe 10 in long, and ran off a standard craft motor. I honestly don't remeber if it was R/C, or just let it go type, but it was sweet. I'll see if I can find it, and post the link if I do. Sean
Whoops! My bad; it was more complex than I remembered. It is R/C and a hovercraft, although the original looksa like it was supposed to be WIG. Here it is http://www.rcgroups.com/forums/showthread.php?t=355287 The guy says he still has the templates for construction. Sean
< Message edited by dogmoat -- 9/28/2005 4:25:38 PM >
       Post #: 35
RE: Calling all Stars Wars aficionados - 9/29/2005 4:22:51 AM
Status: offline
Yeah, I saw that model when I was origionally doing research for this project. I was under the impression that it flew like a plane. It makes more sense as a hovercraft though. I found that x-wings, the jedi starfighter and even the Mil Falcon have been built and flown as RC aircraft. I really like the snow speeder, but I think Vader's TIE hasn't been done and would look very cool when I get it built.
(in reply to biteme)
       Post #: 36
RE: Calling all Stars Wars aficionados - 9/29/2005 4:00:05 PM
biteme
Status: offline
Yes Vaders' tie would be nice. don't punch the snow speeder just cuz it's a hovercraft, I 've seen hovercraft that also WIG, both full size and model. this snow speeder was slated, I believe, to be a WIG flyer but was toned down to a hover for ease of build. I bet It could be done as WIG. In any case, this should be interesting. If you haven't already, check out I think it's flyingthingz.com they have some wierd ones, might give ideas. Also, look under submarines. Quite a few subs are spaceships, built to 'fly' underwater, again, might give you some ideas. Sean
       Post #: 37
RE: Calling all Stars Wars aficionados - 10/1/2005 2:28:59 PM
nstaller
Status: offline
The Y-Wing is being done.Here is a link to it http://www.rcgroups.com/forums/showthread.php?t=373593&page=24&pp=15
Here is my MF.It draws a crowd everytime I fly it
Click for fullsize
Click for fullsize
< Message edited by nstaller -- 10/1/2005 2:30:56 PM >
       Post #: 38
RE: Calling all Stars Wars aficionados - 10/3/2005 9:41:51 PM
SJMILLER
Status: offline
nstaller,
Please provide more info on your falcon. This is a ship I have dreamed of modeling and I would love to hear how you worked it out.
Stan
Stan
(in reply to nstaller)
       Post #: 39
RE: Calling all Stars Wars aficionados - 10/5/2005 11:53:15 PM
50+AirYears
Status: offline
Several of my club members built the ASTRON when it first came out. Great performance. Some of the others were brought out as control line ARFs by cox. There have been many R2D2 clones flown as rockets. May even have been a kit or two in diffeerent sizes.
(in reply to SJMILLER)
