automotive diesel??
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> automotive diesel??
Page: [1]
Login
automotive diesel?? - 10/3/2002 12:48:08 PM
nose_dragger
Status: offline
Dumb question here,,but will regular automotive diesel work in a glow engine?,,Does it have to be converted to run diesel?,,i once heard lighter fluid or coleman fuel would run a glow engine,,or a mixture of diesel, ether, and lighter fluid would work,,can someone help me out??,,its just an experiment im doing with a couple of retired model engines,,,any info would be greatly appreciated,,,thanks,,
       Post #: 1
automotive diesel?? - 10/7/2002 8:51:01 AM
markofthedark-RCU
Status: offline
i was wondering about that to has anyone tryed normal diesel
in a glow ? or what would you have to add?
(in reply to nose_dragger)
       Post #: 2
automotive diesel?? - 11/30/2002 10:18:32 AM
Krusty
Status: offline
Regular automotive/truck diesel fuel will NOT work in a model diesel engine. Model diesel fuel consists of kerosene, ether and oil (castor). It can be purchased or you can make it yourself. I have made it and it worked fine. Typically the mixture is about 40% ether, 30% kerosene or scented lamp oil and 30% castor. If you use kerosene, the fuel and the exhaust will have a very unpleasent odor. The use of scented lamp oil instead of kerosene will eliminate the umpleasent smell. Model diesel fuel is VERY flammable due to the ether. In addition, the ether tends evaporate and/or absorb moisture, thus diluting the mixture unless the fuel bottle is capped immediatly after use. This lower content of ether and dilution can cause difficulties with starting. I DO NOT recommend making it yourself as the ether is much more flammable than alcohol and is rather EXPLOSIVE. Now for some good news. A diesel engine will run aprox. twice as long on a tank of fuel as a glow motor with the same displacement. The diesel will tend to produce more low end torque than the same engine on glow. Therefore, you can run a larger propeller. The diesel will run much cooler than the glow motor. At an idle, the cylinder head will actually feel cool to the touch! Diesels don't require glowplugs or ni-starters. Once the carb and the compression are set properly, is not uncommon for a "primed" diesel to start on only a few "flips".
< Message edited by Krusty -- Dec 2 2002 4:26AM >
       Post #: 3
automotive diesel?? - 12/2/2002 4:33:48 AM
tdriver
Status: offline
[QUOTE]Originally posted by Krusty
Now for some good news. A diesel engine will run aprox. twice as long on a tank of fuel as a glow motor with the same displacement. The diesel will tend to produce more low end torque than the same engine on glow. Therefore, you can run a larger propeller. The diesel will run much cooler than the glow motor. At an idle, the cylinder head will actually feel cool to the touch! Diesels don't require glowplugs or ni-starters. Once the carb and the compression are set properly, is not uncommon for a "primed" diesel to start on only a few "flips". [/QUOTE]
what about mixing kerosene in methanol???
i've heard that 15% of it can give some power in the low to middle range.how much compression ratio is needed for pure kerosene or a mix of it??
       Post #: 4
automotive diesel?? - 12/2/2002 7:24:51 AM
Krusty
Status: offline
I don't know if methanol is "compatable" with kerosene. I've never mixed the two together. My best guess is that they are not, being kerosene is a petroleum based product and methanol isn't. I have never heard of producing more middle and low end power with the addition of kerosene to glowfuel. Maybe some of the fuel "experts" can help with that. As far as compression is concerned, a model diesel has a compression device (screw) attached to a contrapiston located in the head. It is variable and must be adjusted to achieve the correct compression for combustion. Ether in the diesel fuel is the main ingredient for combustion. The engine will never start and run with just kerosene and castor oil. Why not just increase the nitro content of your glowfuel to increase performance?
       Post #: 5
automotive diesel?? - 12/2/2002 12:47:40 PM
tdriver
Status: offline
Why not just increase the nitro content of your glowfuel to increase performance? [/QUOTE]
I'm living in Europe,and nitro is very expensive here.
       Post #: 6
automotive diesel?? - 12/2/2002 5:34:37 PM
downunder-RCU
Status: offline
Other than (expensive) nitro, there's nothing you can add to methanol to get more power. It's possible to add small amounts of petrol to get better fuel consumption but at the expense of some power and running a little hotter.
       Post #: 7
automotive diesel?? - 12/3/2002 12:22:04 AM
Joss Stick
Status: offline
As to the Coleman fuel question, it works fine alone in a gas engine but I would not put it or gas in a glow engine.
_____________________________
Mike in WV
       Post #: 8
automotive diesel?? - 12/3/2002 8:20:05 PM
Sport_Pilot
Status: offline
Gas and methanol will mix. Some of the deicers have methanol. The mixture will work with a spark ignition engine. Drag racers mix the two all the time. The alcohol improves performance of a gas engine.
       Post #: 9
automotive diesel?? - 12/10/2002 9:16:29 AM
john_89
Status: offline
How much more will a diesel model engine cost than a 4 stroke gasoline? Thinking of .61 size engine. Also how much for the fuel?
       Post #: 10
automotive diesel?? - 12/22/2002 1:49:06 PM
nose_dragger
Status: offline
Anyone ever tryed a colemanfuel\castor oil or any type of fuel and any type oil in a glow engine with results,,,,anyone ever ran a glow engine on anything other than glow fuel or any other non-methanol mixes?,,,,when i was a kid i had an old cox control line .049 plane that i received for a gift and had no access to glow fuel,,it just wasnt avaliable near where i lived,,well,,maybee 80 miles away but when youre 10,,that is like traveling to a different country when you only have a 20 inche bycle and parents that tell me you,ll cut youre fingers off,,and NO WAY,,lol,,anyways, i would turn the prop backwards and loosen the prop screw so the propeller would turn loosely and manually swing the plane around just to listen to the prop hum,,,finally,,i found an old can of paint thinner,,put the prop back where it belonged and tightened it put some in my plane hooked up a d cell battery for glow head and ran like unbeleivable,,wow,,for a whole 1 1\2 minutes,,then the engine kinda just burt up,,,oh well,,then i took the head off and reversed the prop and lubed it up with some 3 in 1 oil and went back to manually swinging it around,,i managed to still have some fun someway,,i didnt know what the term 2cycle or oil gas mix actually ment ,,never heard the word really,,but i will always remember that experiance,,it was my first,,,25 years later after i had given up any hope of gaining access of any kind, i was on a trip and went into my first hobby shop,least expecting that i would run into one,by accident,i was amazed at what i saw,,it was much more beyond a kid in a candy store deal,,i just went nuts,,i bought some rc modeler magazines,,2 of them one new and the previous issue,,and a 40 size trainer with everything i needed,,within 2 weeks i had a heli,,as a kid i wouldnt have ever dreamed this coming true,,
< Message edited by nose_dragger -- Dec 22 2002 9:43AM >
       Post #: 11
automotive diesel?? - 12/26/2002 8:03:54 AM
Diesel Dave-RCU
Status: offline
John,
I have a os 61 fx converted with a Davis Diesel head on an Ultrasport 40 arf. The thing will give you a whole new meaning of power to weight ratio.
The engine was about $150, the head was about 60 bucks, and the fuel runs about 15 bucks a gallon from Davis. The nice thing is, you will get about 15-20 minutes out of a 10 ounce tank flying very hard. I got a coulpe of os 40s changed over as well. They will do almost an Hour on 10 ounces.
If you choose to go this route, I think you will find it a very interesting way to power a model.
Few quick pointers. If you convert a glow engine with a Davis head, get the fuel directly from Davis, not from tower. The davis fuel from tower, is mixed with more oil, for use in european diesel engines with steel sleeves. You won't need all that extra oil in the converted glow engine. It will run in it, but you won't get all the performance you could.
You will have to assemble your fuel tank as if you where going to run gas. You have to use Tygon fuel line, and a neoprene clunk line. the Kerosene will swell the silicone line
Diesels can be messy, but since they don't care about muffeler back pressure, you can handle the mess, by just simply porting the exhaust away from the plane. I have ported exhaust as far as 2 feet down a brass tube, without "ANY PERFORMANCE PROBLEMS WHAT SO EVER"
Oh, you can also throw that baffle in the muffeler in the trash, you won't need it anymore. these guys are quiet.
Dave
       Post #: 12
automotive diesel?? - 12/26/2002 8:59:22 PM
john_89
Status: offline
Wow, Dave! Thats quite an endorsement. I love the idea of a diesel. I was told on another forum that diesels are like the next-worst-thing to putting a bomb in your model. They never had an airframe last past a year w/ a diesel in it. Apparently the ether softened the epoxy & the vibes kind of finished it all off. (Only paraphrasing,but thats the jist.) As well the fuel economy isn't that much better than glow according their info. I just couldn't believe that something could be all that bad! A friend of mine has diesel w/ a bunch of glows. He was uncertain whether diesel was worth going w/ over a glow but he didn't report any of the problems that I was told about somewhere else. The main thing he mentioned was the difficulty in getting the machine tuned to start & run. He only has a hex-head c/r adjust screw. I'm guessing that a better adjust screw would make things easier. This individual also mixes his own fuel. He mentioned using unscented lamp oil vs. kerosene. Any problem w/ that? The main reason I like the diesel is its fuel economy. Want to mount a cam in the plane. Will the diesel cause any problems for the cam that I should know about?
       Post #: 13
automotive diesel?? - 12/27/2002 12:58:06 AM
nose_dragger
Status: offline
Hey guys this web page may be of interest to you,,check it out,,,,WWW.PROGRESS.CHARITYDAYS.CO.UK/INSTRUCT.HTM,,,,,,,,,,,,,sorry but my computer will not let me drag the link down here,,you,ll have to type it in manually,,or drag it up to youre adress bar,if youre pc will let ya,,mines havin a bad day Its all in lower case,,,i just typed it in caps so it would be easier to read,,
N.D
       Post #: 14
automotive diesel?? - 12/27/2002 2:55:55 AM
Diesel Dave-RCU
Status: offline
ok guys here we go,
nose-dragger,
It looks like you have found the directions for the PAW diesels, Those are the ones that require the fuel from Tower, with the extra oil. All I have heard about them is good, but I don't have experience with them. "I have heard" they are hard to transition the throttle, they like to labor a lot. I don't know, I have never ran one.
John,
I have been flying with diesels exclusively since 1996. I had a trainer flying with one for 3 years till it got claimed by a radio hit at a float fly. I haven't seen any problem with structural integrity on any of my planes due to the fuel, residue, or torque. However reinforcing the firewall a bit, might not be a bad idea.
The fuel economy is almost double that of a glow engine. The reason is that a gallon of 10 percent glow, is worth about 10,000 BTU's, where a gallon of Diesel mix, is worth around 18,000 (my numbers might not be right, but they are ball park) Considering you have so much more power in the diesel fuel, over the glow, you will need less of it to do the same job. Matter of fact, in the directions for the Davis heads, they tell you to start with the needle valve set at HALF OF WHAT IT WAS SET AT TO RUN ON GLOW!
Starting them can be a challenge sometimes. An electric starter is a must. I don't usually prime the engines, because you could flood it out, and seriously damage it if it were to pull liquid fuel into the cylinder. I don't want to break a connecting rod. I just usually crank the snot out of them till they draw fuel and fire on their own. I have gave up on a field battery for this, and opted for a 55 cold crank amp tractor battery, and a high torque starter.
Your friend with the diesel. I am assuming he has a Davis conversion, by looking at what you wrote. Tell him to run the head screw all the way down, then back it out 1 1/8 turns. set the fuel mixture at half of what it was on glow, or start at about 1 turn out if he doesn't know the glow setting, open the air bleed, or idle air adjustment screw 2 full turns, and that should put him in the ballpark.
When he starts it, set the throttle on the radio to about 1/4 throttle, and crank the hell out of it. When it lights, it will miss, bang, clang, smoke, shake the plane, spit, sputter, and act like it is going to die, till, it warms up. This is normal, and usually draws very strange looks from people that don't know what is going on. (Told you these engines are fun.) Once it warms up, and smooths out, run the throttle up, and set the head first, with a tac, and listen very closely. as you turn it in you advance the engine timing, turn it out you retard it. Turn it in till peak rpm is reached, BUT DO NOT GO PAST IT, OR YOU WILL CAUSE A ROD KNOCK LIKE YOU GET IN A CAR, AND YOU WILL BREAK SOMETHING!!!
Then adjust the fuel mixture till you hit peak rpm, and slightly richen the mixture. Doing this is not like a glow engine. if it is missing it is too LEAN. if it is laboring it is too RICH. Be sure to use a tach. after you do all this, go back and reset the head as described earlier.
Slow the engine back to idle, wait 10 seconds, at slowest idle possible then slam the throttle open. If it labors, open the idle air bleed more, and try again.
Make sure you are using enough prop. I would prop a 25 with a 10x6 at least, 40s with 11x7, 61s with about 12,14x7,8. This all depends on the plane of course.
Your target rpms full throttle, just over 10,000, and making dark brown, or black oil at the exhaust, and around 2400 rpm at idle. If it is set just right, it should transition like a glow engine.
Now lets talk fuel. You said he is mixing his own. I would guess he has the mix from Davis, that you have to mix equally with kerosene. Using unscented lamp oil is quite ok, it "IS" the same thing. Matter of fact, you could use scented lamp oil, if they still made it. I have used lamp oil, scented, unscented, and citronella oil to literally "spray the field for insects". lets see what else, truck diesel fuel, but it didn't work too well. I haven't tried jet fuel yet, maybe someday. Now I just usually order the fuel mixed from Davis. the price is right when I order enough, usually 4 gallons at a time, and it is a consistent mix. Not to mention then I don't have to do it myself.
KEEP THE FUEL VERY AIR TIGHT!!! YOU LOOSE THE EITHER IN IT, THE ENGINE WON'T RUN WORTH A DAMN!!!
Cameras and diesels are not a problem, just port the exhaust away from the camera. The extra power will come in very handy for carrying it aloft.
Dave
< Message edited by Diesel Dave-RCU -- Dec 26 2002 10:25PM >
