Compressor reg and moisture trap?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Painting, Detailing & Bodies >> Compressor reg and moisture trap? Page: [1]
Login
Compressor reg and moisture trap? - 5/21/2005 4:25:34 AM
zalmaxiss
Status: offline
Hello,
I received a Badger airbrush as a gift for my birthday and wanted to get things rolling so I can use it. I bought a small air compressor from Wal-Mart that should do the trick. I need to get a regulator for it and possibly a moisture trap? If both are recommended, what is everyone using? Lots of versions out there , I want to get something decent.
       Post #: 1
RE: Compressor reg and moisture trap? - 5/26/2005 4:42:11 AM
TikiKustoms
Status: offline
does the compressor have a storage tank on it? hopefully it does, you need this to help regulate the airpressure consistancy. if you get the air straight from the motor you could get pulsations in the air flow even with a regulator. but if you do have the storage tank, and it doesnt have a regulator, you need to get one. and if you are to be airbrushing from it, you should get a moisture trap too. you can get one that plugs in directly from the regulator or you can get one that can be put inline on the airbrush hose itself. hope that helps. and good luck on spraying!!
drew
_____________________________
Tiki Kustoms - RC Car Painting and Graphic Design
www.tikikustoms.com
(in reply to zalmaxiss)
       Post #: 2
RE: Compressor reg and moisture trap? - 5/26/2005 5:25:01 AM
zalmaxiss
Status: offline
Yep, it has a little 1 gallon reservoir tank. I guess I will look at Lowes or something . Thanks for the reply.
(in reply to TikiKustoms)
       Post #: 3
RE: Compressor reg and moisture trap? - 5/26/2005 1:50:38 PM
esutek
Status: offline
Home Depot carries a HUSKY regulator for around $20 and a separate moisture trap for around $12. I use a small compressor that feeds a Husky 11 Gallon storage tank running the above regulator and moisture trap.
WWW.RKSPaintworks.Com
Large Scale Custom Paintwork
       Post #: 4
RE: Compressor reg and moisture trap? - 5/26/2005 3:55:18 PM
Nightwolf
Status: offline
How do I know my compressor already has a "moisture trap"?
(in reply to esutek)
       Post #: 5
RE: Compressor reg and moisture trap? - 5/26/2005 4:06:04 PM
esutek
Status: offline
Most of the smaller ones don't have one. It will be a clear glass or nowadays plastic bulb with a drain on the bottom and a ceramic filter in the middle of the bulb.
(in reply to Nightwolf)
       Post #: 6
RE: Compressor reg and moisture trap? - 5/26/2005 4:57:59 PM
Nightwolf
Status: offline
Great so I have a moisture trap!
It's a different term from what we use here, so I wasn't sure what a "moisture trap" was or how it looked, thanks...
       Post #: 7
RE: Compressor reg and moisture trap? - 5/26/2005 5:12:22 PM
esutek
Status: offline
That's It! Nice little setup there. Should work out fine. What brush are you using?
       Post #: 8
RE: Compressor reg and moisture trap? - 5/26/2005 8:34:16 PM
Nightwolf
Status: offline
I'm using a Revell Vario but I'm getting a Iwata HP when I got the $ . For now this airbrush works just fine...
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.578RCU1
