asp 160 twin vs asp 120
Tower Hobbies
Logged in as Guest
  Printable Version
Slimline Pitts Muffler for YS120 YS140
Seller:  Erick Royer
Details:   $75.00   |  9/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> asp 160 twin vs asp 120
Page: [1] 2 3 4   next >   >>
Login
asp 160 twin vs asp 120 - 5/23/2005 10:16:50 PM
Rupurt
Status: offline
I have a 72 inch laser 200, the specified engine for this plane is a 4 stroke 120, would the 160 twin be a worthy alternative to the 120 in this setup as far as power, weight and reliability is concerned?
Thank you.
_____________________________
Somethings are stranger than fishin
       Post #: 1
RE: asp 160 twin vs asp 120 - 5/23/2005 11:26:24 PM
William Robison
Status: offline
Rupurt:
Generally, people ignore the recommended maximum engine size. I'd think a 1.50 or 1.80 four stroke single would be a more popular engine in that plane.
On the other hand, if you think a 1.20 two stroke will fly it nicely, the ASP 1.60 twin will fly it.
A rough equivalent is q 1.60 twon equals a 1.20 single cylinder four stroke, the 1.20 4s single is equivalent to a 1.0 two stroke single.
remember, this is a ROUGH equivalent.
Bill.
Real Airplanes have Two Engines
AMA 25139 - More than 40 years.
(in reply to Rupurt)
       Post #: 2
RE: asp 160 twin vs asp 120 - 5/23/2005 11:34:51 PM
Rupurt
Status: offline
I am going for the coolness factor at the moment, besides the saito 150 I was thinking of putting in this plane is about the same price. I have also heard the saito 150 runs kinda rough(in terms of vibration) and the 160 twin runs quite smooth. Is this true?
(in reply to William Robison)
       Post #: 3
RE: asp 160 twin vs asp 120 - 5/23/2005 11:41:41 PM
William Robison
Status: offline
Rupurt:
Quite true. The Saito 1.50 and 1.80 can really shake things up if not adjusted correctly. The ASP/Magnum/OS 1.60 is an alternate firing twin, really a smooth running engine. And as you said, the "Coolness" factor enters.
For real down and dirty "Ultra Cool" you need to use the flat four OS 3.20, or a radial with five cylinders or more. For me, the three cylinder radials just "Don't make it."
Bill.
       Post #: 4
RE: asp 160 twin vs asp 120 - 5/24/2005 8:15:10 AM
Rupurt
Status: offline
Thanks bill, i think i will probably try the twin, if it doesn't work out on the plane, it's still a neat conversation piece.
       Post #: 5
RE: asp 160 twin vs asp 120 - 5/24/2005 9:06:47 AM
w8ye
Status: offline
The 160 twin seems to be a trouble free easy to tune engine but as Bill say's the power is not much stronger than the 120 single. But its got that cool looks and sound.
Enjoy,
Jim
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
       Post #: 6
RE: asp 160 twin vs asp 120 - 5/24/2005 11:13:59 AM
Rupurt
Status: offline
I have seen the os 320 flat 4 and it was very quiet(it was difficult to hear over other engines), I wonder if it is possible to make them a little louder.
(in reply to w8ye)
       Post #: 7
RE: asp 160 twin vs asp 120 - 5/24/2005 12:02:02 PM
w8ye
Status: offline
They come from the factory with four straight exhaust pipes on them.
Enjoy,
Jim
Original AMA #31261
       Post #: 8
RE: asp 160 twin vs asp 120 - 5/24/2005 1:35:39 PM
Rupurt
Status: offline
Oh, am I right in assuming this is a ringed engine, I am pretty sure it is but just wanna check. I have a vw 1600cc flat four but that is for another project I am working on, besides i probably couldn't afford the amount of lead required for balancing.
(in reply to w8ye)
       Post #: 9
RE: asp 160 twin vs asp 120 - 5/24/2005 1:45:50 PM
w8ye
Status: offline
Yes, it is ringed
Original AMA #31261
       Post #: 10
RE: asp 160 twin vs asp 120 - 5/24/2005 4:57:43 PM
Flyboy Dave
Status: offline
The magnum 1.60 is real cool....and not much more money than the Saito's.
FBD.
Click to see fullsize image.
Click for fullsize
Click for fullsize
An engineer says.... "That won''t work".
A mechanic says..."Oh yeah, watch this".
"Old Age, and Treachery will overcome youth and skill".
Revver Bro #4.
(in reply to w8ye)
       Post #: 11
RE: asp 160 twin vs asp 120 - 5/24/2005 5:40:31 PM
Rupurt
Status: offline
FBD what will the flying weight of that ultimate be? maybe be a little nose heavy with all the bean dip
(in reply to Flyboy Dave)
       Post #: 12
RE: asp 160 twin vs asp 120 - 5/24/2005 5:49:35 PM
Rupurt
Status: offline
What's the fuel consumption like? Will the 500ml tank be large enough for reasonable length flights, say 10-15 mins.
       Post #: 13
RE: asp 160 twin vs asp 120 - 5/24/2005 5:53:16 PM
Flyboy Dave
Status: offline
quote:
ORIGINAL: Rupurt
I guess I'll hafta eat the bean dip....got chips ??
Revver Bro #4.
       Post #: 14
RE: asp 160 twin vs asp 120 - 5/24/2005 7:21:11 PM
Flyboy Dave
