ben flyn
Joined: 11/12/2003 From: Windsor, CO, USA Status: offline
quote:
ORIGINAL: Spacey quote:
ORIGINAL: ben flyn OK I downloaded it, tried it, and I went back to the older version because I want the higher resolution opitions back and they're not there. How do I go back to the REAL older version? Thanks Not sure what you mean with that one? I tried to find any faults in the patch last night and everything is there like it is supposed to be? The high res settings and everything stayed from the previous patches and versions? I also checked all the channel assignments etc and seems that really the only thing which was added is the PPS. Everything else stayed the way it was although you have to go do your settings again to get it the way you had it. I used to have a list of all the different resolutions AND different refresh rates, now I only have 4 resolutions and one refresh rate 60HZ. I did add a second monitor so I wonder if that has anything to do wih it?
_____________________________
If Nixon would have had a banjo everything would have been OK! Steve Martin
