First turbine jet engine
Tower Hobbies
Logged in as Guest
  Printable Version
EASYTIGER'S Mirage IIIC VERY HIGH PERFORMANCE ONLY $129!
Seller:  EASYTIGER
Details:   $129.00   |  11/28/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> First turbine jet engine
Page: [1]
Login
First turbine jet engine - 5/24/2005 2:05:44 PM
zlin50ls
Status: offline
I'm interested in getting into turbine jets. I have a Uravitch F-80 and was told by a turbine flyer that I'll need 12 lbs of thrust. Ths kit has a 64" wingspan and weighs between 10 to 13 lbs. Because of the choices of turbine power plants out there, can anyone steer me to a reliable manufacturer and somewhat economical in price. Thanks for any replies. Kurt.
       Post #: 1
RE: First turbine jet engine - 5/24/2005 2:34:55 PM
rcmigpilot
Status: offline
You'll get a lot more information if you move this post to the jets forum.
_____________________________
The two most useless things on Earth are altitude above you, and runway behind you.
(in reply to zlin50ls)
       Post #: 2
RE: First turbine jet engine - 5/24/2005 3:46:25 PM
tschuy
Status: offline
quote:
ORIGINAL: zlin50ls
I'm interested in getting into turbine jets. I have a Uravitch F-80 and was told by a turbine flyer that I'll need 12 lbs of thrust. Ths kit has a 64!QUOT! wingspan and weighs between 10 to 13 lbs. Because of the choices of turbine power plants out there, can anyone steer me to a reliable manufacturer and somewhat economical in price. Thanks for any replies. Kurt.
There a lot of opinions out there as to what engine is the best, but for the most point if you can afford it go with a Jetcat P60. The reputation and service is first rate. I personally have an FTE T-500 and I am very happy with it. Cost was a factor to me and I decided to go with the Chevy rather then the Cadillac.
Cheers,
Tim Schuy
tschuy@comcast.net
       Post #: 3
RE: First turbine jet engine - 5/24/2005 3:54:52 PM
Wayne22
Status: offline
Probably the most economical route, if you are handy with a ball driver, is to build a Wren.
http://www.wren-turbines.com/
Their support is legendary.
All I ask is for a chance to prove that money can't make me happy......
(in reply to tschuy)
       Post #: 4
RE: First turbine jet engine - 5/24/2005 4:39:59 PM
JetsRC
Status: offline
I agree, Wren makes great turbines, you can build it yourself or buy them allready build. Besides their support is excelent and they are allways there to help you.
JetsRC / Skymaster Jets / Jet Artes / Jet Central
www.jetsrc.com
(in reply to Wayne22)
       Post #: 5
RE: First turbine jet engine - 5/24/2005 7:11:19 PM
Aardvark
Status: offline
What is the general advise on the cheap Chinese jet engines that are mentioned on RCU ?
Are they the equivelent of the ASP's and other O.S. copies of two and four stroke's ?
(in reply to JetsRC)
       Post #: 6
RE: First turbine jet engine - 5/24/2005 8:33:12 PM
turn and burn
Status: offline
some people like them some dont i just put a 14lb straight from the factory in my boomerange on sunday and it flew great they are getting alot better now but lets not start the big jj argument on this thread
(in reply to Aardvark)
       Post #: 7
RE: First turbine jet engine - 5/24/2005 9:36:47 PM
SJN
Status: offline
Turn up the sound
http://bornholm.adsl.dk/modelfly/files/jet/Power.wmv
Sonnich Johannesen
(in reply to turn and burn)
       Post #: 8
RE: First turbine jet engine - 5/24/2005 9:42:09 PM
tschuy
Status: offline
quote:
ORIGINAL: SJN
Turn up the sound
You make me laugh Sonnich
Cheers,
Tim Schuy
tschuy@comcast.net
(in reply to SJN)
       Post #: 9
RE: First turbine jet engine - 5/25/2005 12:25:48 AM
EASYTIGER
Status: offline
quote:
ORIGINAL: SJN
Turn up the sound
You must have an early version...mine plays "HIGHWAY TO THE DANGER ZONE."
It also came with a vacuformed flight helmet and some cheap imitation ray-bans.
(in reply to SJN)
       Post #: 10
RE: First turbine jet engine - 5/25/2005 12:48:13 AM
Spartan Missile
Status: offline
SJN
You are not normal taking your turbine to bed.
(in reply to SJN)
       Post #: 11
RE: First turbine jet engine - 5/25/2005 12:59:59 AM
EASYTIGER
Status: offline
quote:
ORIGINAL: Spartan Missile
SJN
Totally.
Hey, are those KERO STAINS on the bed? Ewwww....
(in reply to Spartan Missile)
       Post #: 12
RE: First turbine jet engine - 5/25/2005 1:49:36 AM
Gordito Volador
Status: offline
Spend the money and go JetCat, you will never regret it.
"Let Me Hear Your Guns"
(in reply to EASYTIGER)
       Post #: 13
RE: First turbine jet engine - 5/25/2005 2:56:08 AM
sideshow
Status: offline
Kurt...the best advice I can give you is to see what the other local jet guys are flying....and get one of those. That way, you'll have a base of knowledge to draw on. I personally have Jetcats....but I have heard nothing but good thing about the ones already mentioned.
Bob Convery
(in reply to Gordito Volador)
       Post #: 14
RE: First turbine jet engine - 5/25/2005 4:33:46 AM
zlin50ls
Status: offline
Thank you for your replies. I also came across Modellbau-usa they have their own turbines and also sell the Jet Cat brand. The local guy I talked to flies a Jet Cat, but the sticker shock for a first timer isn't appealing. Modellbau-usa is saying that all of their equipment is serviced and parts replacement is done in Florida. It sounds as if most of these companies are operating through US retail outlets. I haven't heard from anyone operating this brand. I'd like to hear from someone before I buy. Thanks again.
(in reply to sideshow)
