RE: ParkZone P-51 Mustang RTF
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
P-51D Mustang
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> Electric Aircraft Universe >> Park Flyers & Backyard Flyers >> RE: ParkZone P-51 Mustang RTF
    Page: <<   < prev  116 117 118 [119] 120 121 122 123 124 125   next >   >>
    Login
    RE: ParkZone P-51 Mustang RTF - 4/15/2008 2:45:58 PM
    LICobra
    Status: offline
    Whiz...Who does your graphics and group lettering ??, I guess the stars and bars can be had from Horizon...
    LICobra
    (in reply to Whiznr)
           Post #: 2951
    RE: ParkZone P-51 Mustang RTF - 4/15/2008 7:44:46 PM
    Whiznr
    Status: offline
    Thanks LICobra!!
    I did everything except for the stars & bars, fuel caps, & D-Day stripes. The decals were made from a high resolution scan of a 1/32 scale Cripes A Mighty the 4th decal sheet. Thanks to Sam Sox, one of the 352nd FG historians.
    I resized everything in Adobe Photoshop and printed them on clear &/or white label paper from Office Depot. Some of them came out too faint, so I ended up painting on the decal to improve it. I ended up painting "Cripes A Mighty", the pilot name on canopy rail, the barbers pole, the red & white on the guns and trim tabs, and under the exhaust stacks.
    The rest were, print-peel-put on.
    < Message edited by Whiznr -- 4/15/2008 7:45:14 PM >
    (in reply to LICobra)
           Post #: 2952
    RE: ParkZone P-51 Mustang RTF - 4/17/2008 1:56:48 AM
    vzuelke
    Status: offline
    I was wondering if someone could help me with this. I put a lipo battery in the stock Parkzone P-51-D, as the instructions say. I did this after removing the J3 jumper as per the instructions. I am using an 18c 2100 mah 3S1P 11.1v lipo battery. I ran the stock P-51 with the stock motor for 3 minutes at 3/4 throttle with this lipo battery. If I understand the instructions, this is OK, but I smelled something hot and shut everything down. The motor was so hot, it took 10 minutes to cool down enough so it could be touched. I am afraid if I ran it any longer, it would have burst into flames. I am curious if this is what the designers of this plane had in mind when they said in the instructions that a lipo battery could be used? I am thinking not. Has anyone had any experience with this before?
           Post #: 2953
    RE: ParkZone P-51 Mustang RTF - 4/17/2008 3:45:21 PM
    vzuelke
    Status: offline
    Yes, I did run it as a static test. (Oops!) I won't do that again! I suppose the thing would have burst into flames had I continued! Good thing I stopped when I did! I was trying to see how much time I had before I would have to land. Let me know how your follow up flight goes. I am interested in knowing if your motor is so hot you can't touch it. I hope I did not cook mine too badly. Can you recommend a better brushed replacement motor that will fit with the stock motor mount?
    (in reply to vzuelke)
           Post #: 2954
    RE: ParkZone P-51 Mustang RTF - 4/18/2008 1:44:40 AM
    The_Mongrel
    Status: online
    quote:
    ORIGINAL: vzuelke
    There is a much simpler way of seeing how long you have in your battery. The only thing it requires is a Battery Charger that will display the number of mAh that has been put into the battery, such as a Swallow or B5 charger.
    So... time your flight (make it a short one if you are worried) say 5 minutes. Then, charge the battery and take note of the mAh that was put back in. If it took say 1000mAh and it is a 2200 mAh battery, then you could fly safely for 10 minutes. if it took 500mAh, then you could fly for 15 to 20 minutes etc etc.
    I do this with all my aircraft to be sure that I don't run out of power in the air. I never run my batteries to the cutoff point.
    I hope this helps.
    Cheers
    -J
    _____________________________
    Crashing is such sweet sorrow!
           Post #: 2955
    RE: ParkZone P-51 Mustang RTF - 4/18/2008 4:45:58 AM
    Whiznr
    Status: offline
    Yeah a static run like that can kill a motor quick!
    Did another flight today to test the issue, it was fine. Put about a 6 minute flight on her before the wind started bouncing me around, and decided it was time to bring her in. That's the 6th flight on this one and still a streak of great landings! It's really awesome to have a plane I don't have to worry about anything weird happening to, just fly it and have fun!
    < Message edited by Whiznr -- 4/21/2008 12:20:54 AM >
    (in reply to The_Mongrel)
           Post #: 2956
    RE: ParkZone P-51 Mustang RTF - 4/21/2008 10:02:31 PM
    Whiznr
    Status: offline
    Today was probably the most fun I've had at a flying field.
    Even though I only got 1 flight each on my F-15 and P-51, I made the most of it.
    I started with the F-15 doing loops, rolls, low passes and verticals. As usual, the wind didn't do a thing until I was plugged in and ready to launch. So I had to wait about 5 minutes for it to die back down, then it was FUN time!! The wind still knocked me a around a little but not too bad while flying the F-15, and made my BEST landing ever with it too!
    P-51 time.... well what can I say? Lt. Smash was flying his Sukoi, and we had the coolest dogfight!!! I've never really tried dogfighting with the pony, but it's about the most exciting thing to do with it!! I had a bit of a crummy launch, (no crash) but got it up there to chase him around, looping, rolling, diving and climbing turns, you name it. Then on one low pass I did a shallow climbing turn, and the wind nailed the ole girl causing it to stall and roll straight down!! I recovered it at about, oh 4ft off the ground. Cleaned out my shorts, and did one more pattern. After that I was ready to land. I don't wanna kill this thing before S.E.F.F.!! Another perfect landing for a streak of 7 with the P-51. Man, I'm loving this bird!!!
           Post #: 2957
    RE: ParkZone P-51 Mustang RTF - 4/21/2008 10:41:22 PM
    LICobra
    Status: offline
    Whiz
    There definately fun when you land (with no misshaps) to fly again, at least to me it is !!!. I fly in a small park, but I am by myself, my only dog fighting is with the sea gulls. I've only been flying since last Sept, I don't know what it's like to share the airspace.
    Since my PZ P-51 upgrade to brushless, I just bought a PZ Spitfire replacement airframe and started the same upgrade. I'd like to fly both warbirds but im limited to one plane because of trunk space.
    If anyone needs a stock 480 motor with a metal pinion gear, let me know I have 2.
    LICobra
           Post #: 2958
    RE: ParkZone P-51 Mustang RTF - 4/22/2008 5:05:28 PM
    tubamike78
    Status: offline
    what do you want for them? i burned up my motor in my spitfire the other day, running it a bit to lont wot using lipo.
           Post #: 2959
    RE: ParkZone P-51 Mustang RTF - 4/22/2008 8:43:29 PM
    Showtime100
    Status: offline
    What is the average flight duration the stock setup yields? I had a SuperCub and ended up getting 3 battery packs to get a satisfactory amount of flying time each night. I assume the P-51 or Spit would be similar.
    My problem with the Supercub is the battery packs quit working after about 10 flights. They stopped charging.
    (in reply to tubamike78)
           Post #: 2960
    RE: ParkZone P-51 Mustang RTF - 4/22/2008 8:50:06 PM
    LICobra
    Status: offline
    quote:
    ORIGINAL: tubamike78
    Tuba..I might already have a buyer, but 10 bucs if he bows out..
    LICobra
           Post #: 2961
    RE: ParkZone P-51 Mustang RTF - 4/25/2008 3:30:02 PM
    Whiznr
    Status: offline
    Showtime100,
    As far as flight duration time, I haven't really timed the 51, but we put a 2200mAp 25c in my friends 190 and got a 14 minute flight out of it. I'm hoping to give the P-51 a duration test today, as well as test a mod to the aileron servo connection. I'll let ya know when I get back.
           Post #: 2962
    RE: ParkZone P-51 Mustang RTF - 4/27/2008 4:16:04 PM
    Rudys Pilot
