RE: New Kyosho Oxalys 50 ?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> RC Pattern Flying >> RE: New Kyosho Oxalys 50 ? Page: <<   < prev  13 14 15 16 17 18 19 [20] 21 22   next >   >>
Login
RE: New Kyosho Oxalys 50 ? - 12/15/2007 5:47 AM
Shadetreeflyer
Score: 100
Last Login: 1/18/2012
Status: offline
Can anyone tell me what the differences in the Oxalys 50 nitro version and the electric version are? I would like to know if there are really any significant difference? Such as in weight or hatches for battery access ect.. The reason I ask is the electric version is considerably more expensive than the nitro version.
I will be using an electric motor for power. If there are no major differences I would just buy the nitro version and convert it to electric power. I know the electric version comes with a different motor mount but I want to know of any significant differences to justify the cost difference Thanks
Hide Signatures
(in reply to lee101)
       Post #: 476
RE: New Kyosho Oxalys 50 ? - 2/19/2008 7:37 AM
ctsh
Score: 100
Last Login: 2/28/2008
Status: offline
I just had to take off my Oxalys 260cc tank because there was a fuel leak and I found that there was some consumed parts in the structure.
First question: is there a original 260cc tank for sale?
Has someone tried to install a bigger tank, like a 300 or 320cc? If yes could please put some photo or schema to help me? Im using a Saito 82 without pump then it must be behing the firewall.
Thanks.
Hide Signatures
(in reply to Shadetreeflyer)
       Post #: 477
RE: New Kyosho Oxalys 50 ? - 2/28/2008 7:59 AM
ctsh
Score: 100
Status: offline
No one?!
Hide Signatures
(in reply to ctsh)
       Post #: 478
RE: New Kyosho Oxalys 50 ? - 2/28/2008 8:31 AM
Super D
Score: 100
Last Login: 2/4/2013
Status: offline
I believe I used a 320cc tank. Cant remember which brand probably sullivan or dubro. I also think it was a slim. I'll try to check mine out over the weekend.
Dylan
_____________________________
Keep working, the millions on welfare depend on you!
Hide Signatures
(in reply to ctsh)
       Post #: 479
RE: New Kyosho Oxalys 50 ? - 3/19/2008 2:00 PM
rolyjr
Score: 100
Last Login: 6/20/2011
Status: offline
Hi all,
I finished my Oxalys 50 a week ago. It has a OS55AX in it with pipe – took a while to modify for the pipe, but came out well. I am currently flying Sportsman class, and my previous plane was the Showtime 50 with the same setup. The Showtime is 400gr heavier with the Oxalys weighing in at 2.56kg. This includes two coats of clear coat on the fuzz – came out brilliantly. Did this to prevent the covering issues that a lot of people seem to have had.
The power on with this set up is unbelievable. Half to two thirds throttle on vertical and even then it carries on going. Currently running a 12x6, but need to go to maybe 13x5/4 to slow the plane down. Flying at 5,700 feet above sea level – any suggestions on props?
Regarding the tank, I have put a 320cc in mine. It is a World Models product. Had to grind out the existing formers used to strap the 260cc tank in. Put in a lot of foam to surround the tank, and a screwed in a piece of ply at the back to hold the tank forward. works well.
Roly
Hide Signatures
(in reply to Super D)
       Post #: 480
RE: New Kyosho Oxalys 50 ? - 3/19/2008 3:31 PM
piroflip2
Score: 100
Last Login: 4/3/2013
Status: offline
quote:
ORIGINAL: rolyjr
Hi all,
Roly
Hi there
I only fly in the lower F3A class in England but it seems to me that you need a coarser pitch prop.
A 13 x 4/5 would be more a 3D type prop.
btw, I have a little Oxalys and it goes very well on a Saito 82.
The ghost of aviation, she was swallowed by the sky.
Or by the sea, like me she had a dream to fly.
Hide Signatures
(in reply to rolyjr)
       Post #: 481
RE: New Kyosho Oxalys 50 ? - 3/25/2008 10:06 AM
rolyjr
Score: 100
Status: offline
Hi all,
Haven't tried any other props yet, but have adjusted the throttle curve drastically which pretty much allows for only up to 60% available at 3/4 stick position. Has made a vast improvement on the throttle management. maybe i will just leave it as is.
Roly
Hide Signatures
(in reply to piroflip2)
       Post #: 482
RE: New Kyosho Oxalys 50 ? - 4/25/2008 9:43 PM
danmix
Score: 100
Last Login: 5/19/2013
Status: offline
have anyone tried the oxalys with the t-canalizer yet ??
and plz tell somthing about how the plane react with t-canalizer ?
can you fell different between it with or without ?
< Message edited by danmix -- 4/26/2008 6:41 PM >
Hide Signatures
       Post #: 483
RE: New Kyosho Oxalys 50 ? - 4/27/2008 2:16 AM
hezik
Score: 109
Last Login: 10/28/2012
Status: offline
I have flown it with and without and didn't notice a large difference. It might need a little less rudder with the canalizer and possible it'll tend to pitch down slithly on allied rudder without the canalizer, but the ony reason I know this is because I heard other people (who typically don't own the .50 oxalys) told me so.
If i were to buy another one now, i'd leave it off. The difference in flight is marginal and groundhandling becomes more easy. I cannot begin to count the times I had to re-glue the canalizer back on after flipping the aircraft over to remove the wing and incidentally hitting the canalizer..
Hide Signatures
(in reply to danmix)
       Post #: 484
RE: New Kyosho Oxalys 50 ? - 7/9/2008 2:18 PM
MJ-MERLIN
Score: 100
Last Login: 7/6/2009
Status: offline
quote:
ORIGINAL: ctsh
Thanks.
im building one with a saito 82 in it and would like to fit a bigger tank as the 260cc one looks too small
ant one whith a sugestion of a larger tank and how it would fit ?
pictures would be great .
merlin
Jam the sticks in the corners, sort it out when its done
my kinda flying
Hide Signatures
(in reply to ctsh)
       Post #: 485
RE: New Kyosho Oxalys 50 ? - 7/11/2008 8:30 PM
MJ-MERLIN
Score: 100
Status: offline
I have been building my Oxalys this week with a saito 82 and thought I would share my progress
This kit is the EP version with a GP conversion kit (kyosho)
This means that I have some extra hatches in the underside for the lipos that I aint using !
Mod I have done
I have changed the tank to a Hanger 9 one from my crashed funtana 50x (320cc)
This fitted fine with only minor mod to the internal timber
I fitted captive nuts in for the cowling fixings
Used a remote glow connected using a 3.5mm headphone jack
I balanced it last night and found I will have to mount the 5 cell 1400mah pack behind the wing but I should be able to get in without having to cut another hatch in the tail.
Other than that I have used all that stock linkages ant hardware.
Just a few more little bits to fit and it should maiden this bird Sunday
Sorry about the fuzzy picks but it was taken on my phone
my kinda flying
Hide Signatures
(in reply to MJ-MERLIN)
       Post #: 486
RE: New Kyosho Oxalys 50 ? - 7/13/2008 5:02 AM
maukaonyx
Score: 133
Status: offline
Where is the best price on the Oxalys 50 now? Thanks. Jon
Carl Goldberg Ultimate 10-300 Brotherhood #01
Club Saito #707
Hide Signatures
       Post #: 487
RE: New Kyosho Oxalys 50 ? - 7/13/2008 5:15 AM
onewasp
Score: 115
Last Login: 4/15/2013
Status: offline
I think you mean the ONLY place in the US_____as well as the best (only) price.
PnAHobbies@sbcglobal.net
He deserves the business as he has stayed with it for three years now___from July 2005 through July, 2008.
That ought to tell you something !!!!!
< Message edited by onewasp -- 7/13/2008 5:19 AM >
The ground reached up and smote my airplane
Hide Signatures
(in reply to maukaonyx)
       Post #: 488
RE: New Kyosho Oxalys 50 ? - 7/17/2008 6:58 PM
MJ-MERLIN
Score: 100
Status: offline
i have maiden this bird and its fly great
i have had about 6 flights on it and about to start fine trimming it
but before i do that i have a question
the caniliser thingy on its spine,
is it worth putting it on as i have left it off at the mo
knife edge requires less than 1% elevator and it ever so slightly rolls out
nothing i cant handle tho
will the cantiliser thingy help ????
merlin
my kinda flying
Hide Signatures
(in reply to onewasp)
       Post #: 489
RE: New Kyosho Oxalys 50 ? - 7/22/2008 7:27 AM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: MJ-MERLIN
merlin
Leave it off. If you got the dihedral correct, it shouldn't need any roll mix. Knife edge flight pitches very slightly to canopy on mine, but very manageable with no elevator mixing. Up and down lines are very close. A really good little model that has full capability to perform F3A schedules. Mine knife edge loops easily (YS63, 12x8) so there's ample power for practically anything. And BTW, this little model performs truly flat rudder turns in either direction. Very sporty.
However, the nice table manners of the small model don't translate well to the larger brother. The larger brother definitely needs the T thingy help. Actually it only needs the dorsal fin without the horizontal surface. That goes for most of the current 2 meter designs. A small dorsal, about 10 to 15 sq inches, at mid ships around the wing's TE eliminates most of the dreaded pitch to belly with top rudder. FWIW
MattK
Regards,
MattK
Hide Signatures
       Post #: 490
RE: New Kyosho Oxalys 50 ? - 7/22/2008 8:12 AM
tclaridge
Score: 100
Last Login: 5/15/2013
Status: offline
Does anyone have any tips on installing the wheel pants? I am having a hard time getting the double-nut next to the wheel to tighten at just the same time the outside nut tightens on the LG. I go back and forth, one tightens, other becomes too loose. . .
Any ideas?
AMA 896196
Hide Signatures
(in reply to MTK)
       Post #: 491
RE: New Kyosho Oxalys 50 ? - 7/22/2008 12:42 PM
MJ-MERLIN
Score: 100
Status: offline
Thanks MTK
think I'm still a little undecided as I don’t really think it needs it but I like the look of it, I think it looks “wizzy†but on the other hand I know I'm goanna snap the dam thing off when transporting it or when I flip it over to fit the wing.
Tclaridge
It’s simple don’t fit them, my ones were junk !
I fitted mine and they only lasted a dozen flights.
I had them nice and tight and on a bed of hot glue to stop them rotating and to spread the load.
They still cracked and fell apart the ones in my kit were very light and flimsy so I have replaced them with a set from a crashed plane and also added an extra screw to fix them in place rather than just relying on the axle.
< Message edited by MJ-MERLIN -- 7/22/2008 12:43 PM >
my kinda flying
Hide Signatures
(in reply to tclaridge)
       Post #: 492
RE: New Kyosho Oxalys 50 ? - 8/14/2008 7:38 AM
tclaridge
Score: 100
Status: offline
I finished my Oxalys 50EP and it flew great! The precision exceeded my expectations. My AUW was 5.3 lbs with a Power 46 and a TP 4S5000. This gives a wing load of 24 oz/sq ft, so I was worried it would fly a little hotter than I am use to. This was not the case and it was amazing how well it did slow flight. Glide was very good too. Power was just right with this motor, but it does not have unlimited vertical.
It basically handled like a full size pattern, and looked very very good in the air. Landings and TOs were easy.
The only complaint I have is the battery compartment was too small for a 4S5000. A 4S 3300 or 3850 would fit. However, I like the longer flight time with a 5000 mah and the wing load is perfect, so I mounted the bigger battery above the wing. I think this also helps to move the weight and CG closer to the thrust line, as now the battery is directly in line with the motor.
Click to see fullsize image.
Click for fullsize
Click for fullsize
AMA 896196
Hide Signatures
       Post #: 493
RE: New Kyosho Oxalys 50 ? - 8/14/2008 5:45 PM
MTK
Score: 203
Status: offline
I have decided to sell my Oxalis 50. Just engine (YS63, 12x8apc and TT spinner), plumbing and plane. No radio equipment. 399$ US or BO
Also have a Brio 10 I need to sell. Hacker motor (16M and 40A controller). Again no radio. 199$ US or BO
Anyone interested, please contact me in a PM.
Matt Kebabjian
Regards,
MattK
Hide Signatures
(in reply to MTK)
       Post #: 494
RE: New Kyosho Oxalys 50 ? - 8/14/2008 7:22 PM
hezik
Score: 109
Status: offline
quote:
Leave it off.
Indeed. It's not needed and if you put it on you're bound to break it off sooner or later when you turn the plane upside down on the field or something. It's just a hassle and not worth it.
Mine didn't pitch, you might consider slightly lowering both ailerons to get rid of this behaviour.
This is not true. The dorsal fin part of the canaliser, is not the effective part. The whole idea of the canalizer is that the turbulent air behind the canopy is 'canalized' towards the horizontal stab/rudder, hence the name. Without the horizontal surface, the canalizer is pretty useless, though it might slightly improve knife edge behaviour simply because it enlarges the area that carries the plane when flying knife edge.
The big Oxalys really needs the canalizer WITH horizontal part, and set with the correct incidence.
Hide Signatures
(in reply to MTK)
       Post #: 495
RE: New Kyosho Oxalys 50 ? - 8/14/2008 8:45 PM
MTK
Score: 203
Status: offline
Hezik,
Have you tried using the dorsal without the horizontal? I think you will be surprised. The dorsal at midships adds very little area to the overall side area of the fuse but adds enough as a pivot of sorts, just like a shark's dorsal, to makes the model more agile in yaw (just like a shark). Take the dorsal away from the shark and the animal's fearsome reputation as a top predator could be compromised. The dorsal also adds some effective vertical area to top side of the fin and rudder, eventhough it is found at midships. This raises the CP of the fin and rudder which increases the down moment on the tail when rudder is applied.
Every model we have added a small dorsal to, either at midships or further back in front of the fin, has required much much less elevator mixing to fly a straight knife edge. BTW, some of the guys use a piece of 1/4" Depron as dorsal. Simple to do and tune the shape
What we all seek (the holy grail for pattern models) is a model that needs no electronic mixing to fly true under all attitudes. If the horizontal adds trueness to your plane, great. I am saying it isn't necessary
Matt Kebabjian
Regards,
MattK
Hide Signatures
(in reply to hezik)
       Post #: 496
RE: New Kyosho Oxalys 50 ? - 8/15/2008 2:37 AM
hezik
Score: 109
Status: offline
Ah well, in the end it's a matter of personal preference, everyone trims his or her plane the way he or she likes it, what works for one doesnt work for the other and vice versa.
All I know that the whole design idea behind the canalizer is solely based on the horizontal part. It is ment to give you the benefits of a biplane without the hassle of an extra wing. The dorsal fin part was merely placed because.. well, you need something to keep the horizontal part in it's place
Wether or not it does that in real life, I haven't checked, nor am I going to, since I don't own a full size Oxalys (before we get into that discussion, I do know people with this airplane and I have had lengthy discussions about the canalizer with more than one pilot). One point everyone in these discussion agreed on, is that on the big Oxalys the canalizer IS effective and that the incidence of the Canalizer DOES matter. Another thing all pilots seem to agree on, is that there is no such thing as 'the perfect plane' which works for everyone.. each pilot has his or her own flying style. For instance; do you set all surfaces to 0 incidence and no down thrust on yer engine so that you always need to give some up while flying a straight line (makes the easy stuf somewhat harder but the difficult stuf much easier) or do you set an incidence and downthrust.. and so on and so on.. millions of things to experiment with and form your own opinion
However, this thread is about the small Oxalys, which I do own and we do both agree on that one; leave it of, it's not needed.
Hide Signatures
(in reply to MTK)
       Post #: 497
RE: New Kyosho Oxalys 50 ? - 8/26/2008 11:36 PM
fabianomoser
Score: 100
Last Login: 12/18/2009
Status: offline
Hello,
Please I want to know if this engine is enough to do F3A flight at OXALYS 50 ?
The weight on aircraft especifications are ~2400g weight. This are only airplane (empty) or with an class 50 engine, servos, and batteries together?
I want to find a good eletrical setting to this model.
Spec.
TR50-55B
Working Voltage: 8~30
Kv: 600
Weight: 300g
Shaft: 8mm
Dimensions: Length: 55mm
Thrust: 2200 ~ 4600g
Stator Size (AXi Measurement): 40-20
Recomended ESC: 80A
Suggested Prop: 5cell:14x9 / 6cell: 14x8
Shaft: 8mm
Power equivalent : .40 to .60 glow engine
Similar to AXi Gold 4120/14, E-Flite Power 46. Roughly equivalent to .46 2-stroke or .65 4-stroke glow engines.
Use this motor with 4-6 cell Li-Poly packs and 11-12 inch props on planes up to 8 lbs flying weight.
Manufacturer suggests a 12 x 8 prop on 6 cells or 13 x 10 on 4 cells.
Thanks for help.
Best regards,
Fabiano Moser
Lisbon/Portugal
Click for fullsize
< Message edited by fabianomoser -- 8/27/2008 11:52 AM >
Hide Signatures
(in reply to hezik)
       Post #: 498
RE: New Kyosho Oxalys 50 ? - 9/12/2008 7:18 PM
hezik
Score: 109
Status: offline
Sorry for starting this discussion again, but did you see the new CPLR model (Axiome) ? Did you notice it has NO dorsal fin, but it DOES have the horizontal part.
Makes you wonder, doesn't it?
Hide Signatures
(in reply to MTK)
       Post #: 499
RE: New Kyosho Oxalys 50 ? - 9/12/2008 8:00 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: hezik
No it doesn't and yes you should be
Regards,
MattK
Hide Signatures
(in reply to hezik)
       Post #: 500
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.566RCU1
