RE: New Kyosho Oxalys 50 ?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> RC Pattern Flying >> RE: New Kyosho Oxalys 50 ? Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: New Kyosho Oxalys 50 ? - 8/18/2005 6:59 PM
ERDEL
Score: 100
Last Login: 6/13/2013
Status: offline
ATHOS:
You in particular with this airplane, which propeller are you using?
Which one would be better? APC 11x8, 11x9 or 12x8?
Thanks!
P.D. Please i would ppreciate the info regarding the mini-tune pipe for the YS 63
Hide Signatures
(in reply to hayate)
       Post #: 51
RE: New Kyosho Oxalys 50 ? - 8/18/2005 10:04 PM
PatternFlyer
Score: 100
Last Login: 6/17/2013
Status: offline
Erdel,
I think you should be ok with the 13x6. It looks like the plane has enough ground clearance.
By the way, my Kyosho Sales rep is a Japanese from Kyosho Headquarter, so I will ask him about the covering and maybe something else that you guys want to know.
Ihncheol Park
< Message edited by PatternFlyer -- 8/18/2005 10:14 PM >
_____________________________
Hide Signatures
(in reply to ERDEL)
       Post #: 52
RE: New Kyosho Oxalys 50 ? - 8/19/2005 5:15 AM
PatternFlyer
Score: 100
Status: offline
Ok, got reply from the Kyosho. The covering on Oxalys 50 will not have problems like the Majestic 1400. It's Kyosho's own covering for their ARFs.
One of the recommended prop was 13x7. Not sure if it is Kyosho prop or APC. (waiting on answers).
I will have 62mm Tru Turn spinners to go with the Oxalys 50.
Ihncheol Park
P & A Hobbies
Hide Signatures
(in reply to PatternFlyer)
       Post #: 53
RE: New Kyosho Oxalys 50 ? - 8/19/2005 11:13 PM
pattern pilot
Score: 100
Last Login: 11/22/2009
Status: offline
My kyosho oxalys flies with an 12/9 APC but the 12/7 is good too, I will try the 13/6 (always APC) and will let you know if it will have more power
Hide Signatures
       Post #: 54
RE: New Kyosho Oxalys 50 ? - 8/20/2005 3:31 AM
FullSpeedAhead
Score: 100
Last Login: 6/22/2009
Status: offline
quote:
ORIGINAL: PatternFlyer
Ihncheol Park
P & A Hobbies
62mm tru turn spinners? they dont come in that size right.. i am looking for a spinner at 62mm as well, but only managed to find a 63mm one so far...
athos7, what size spinner r u using on the oxalys?
thx
< Message edited by MontBlanc -- 8/20/2005 3:34 AM >
Hide Signatures
       Post #: 55
RE: New Kyosho Oxalys 50 ? - 8/20/2005 8:15 AM
FullSpeedAhead
Score: 100
Status: offline
checked my oxalys kit box.. it says a 57mm to be used... funny eh?
Hide Signatures
(in reply to FullSpeedAhead)
       Post #: 56
RE: New Kyosho Oxalys 50 ? - 8/20/2005 11:51 AM
ERDEL
Score: 100
Status: offline
MontBlank:
Could you please tel us if the OXALYS came with the prepartion for using a mini-tune pipe?
By the way, which engine are you going to use?
THNKS
Hide Signatures
       Post #: 57
RE: New Kyosho Oxalys 50 ? - 8/20/2005 5:07 PM
FullSpeedAhead
Score: 100
Status: offline
Hi Erdel,
i will using the YS 63 S with an APC 12X6 prop to go along. in fact, i am going to use the hatori mini pipe as well and the rigid header from hatori as well. the length is okay, as the pipe is 129mm long, which seats comfortably at the lg area as the area is "sunken" in. as for the header, i have an issue and i posted it on a previous post:
quote:
ORIGINAL: MontBlanc
great that should do. thanks!
will be using the new hatori short pipe hatori #640 and header hatori #643 for this plane, since the header is not in stock at my LHS, i needa get some clarifications. the firewall has a built in right thrust, so since the #643 is a rigid header and with the given right thrust, is it necessary to have the engine mounted at a slight angle so that the header will be aligned together with the center of the fuselage?
btw, athos7, did u use the supplied 260 cc tank or did u use a bigger one? thx
anyway, my LBS will be bringing in both the rigid and the flexible (#643 and #642) headers from hatori which is both used for pipe no. #640. as for now, i need to wait for the header to arrive and do some calculations to see if it would fit.
jeff
Hide Signatures
       Post #: 58
RE: New Kyosho Oxalys 50 ? - 8/20/2005 11:53 PM
ERDEL
Score: 100
Status: offline
MontBlanck(Jeff):
Thanks very much for your info. I think that everybody in this forum would appreciate more pictures once you start building or assembling your plane. Does the mini-tune pipe in YS 63 does it really is for gaining more power? what is the advantage of using tune pipe in the YS engines?, i ask this quiestion because i am going to buy one for my plane but i am doing this because alot of people install tuned pipes in their YS`s engines.
Thanks again!
Hide Signatures
       Post #: 59
RE: New Kyosho Oxalys 50 ? - 8/22/2005 4:08 AM
ArayRC
Score: 100
Last Login: 8/15/2011
Status: offline
how does this airplane compare to the Cermark Javelin? The javelin has a longer fuse and the wing on the javelin is larger. 61.5" (fuse) 58" for the wing.
I think the Kysho Oxalys 50 has a 53 3/4" wing and a 57" fuse.
And does anybody know the wing area of the Oxalys 50? they don't list it anywhere?
Hide Signatures
(in reply to ERDEL)
       Post #: 60
RE: New Kyosho Oxalys 50 ? - 8/27/2005 8:42 AM
PatternFlyer
Score: 100
Status: offline
It is 32.9 decimeter square dm^2 that is equivalent to approximately 510 sq.in.
It looks like the spinner size is incorrectly shown in the manual page 2. if it is a 57mm, it is 2.25". Well, I am going to have to call the Tru-Turn & Kyosho again.
I had to dremel out the 2.25" TT standard spinner to use the YS engine. Otherwise, Ultimate spinner is necessary to use Tru Turn spinner/adapter.
Erdel,
there isn't much of power gain on 4-stroke using a larger muffler (my YS 91AC gained about 100 rpm using ES carbon muffler for 120). Also, no manufacturers call them as tuned pipe. They are called just muffler. Benefit of the larger muffler is the quietness. None of my YS 4-stroke use the standard muffler that YS provided. However, I tried YS 53, 63, 91AC & FZ, 140L etc with stock muffler. Then used Asano, ES design, Bluebird, Hatori, etc mufflers to reduce the noise.
Anyway, I will probably have the Oxalys in stock next week.
Ihncheol Park
P & A Hobbies
< Message edited by PatternFlyer -- 8/27/2005 9:02 AM >
Hide Signatures
(in reply to ArayRC)
       Post #: 61
RE: New Kyosho Oxalys 50 ? - 8/28/2005 7:02 AM
FullSpeedAhead
Score: 100
Status: offline
quote:
ORIGINAL: ERDEL
MontBlanck(Jeff):
Thanks again!
just got back from my trip to perth WA, so will be working on e oxalys today, although i wont be taking much pics about the building process, i will be posting some postings on my online journal so u could view some over there, maybe posting here as well.
jeff
< Message edited by MontBlanc -- 8/29/2005 11:38 AM >
Hide Signatures
(in reply to ERDEL)
       Post #: 62
RE: New Kyosho Oxalys 50 ? - 8/29/2005 2:32 AM
fishunter
Score: 100
Last Login: 10/3/2012
Status: offline
Is anyone running a 4 stroke other than the YS 63 ? also with the YS 63 and the hatori pipe and muffler setup ,will it fit inside the cowl without making a cutout for it? and will it exit out the bottom with it?
Hide Signatures
       Post #: 63
RE: New Kyosho Oxalys 50 ? - 8/29/2005 3:30 AM
PatternFlyer
Score: 100
Status: offline
MontBlanc,
So, what is the correct diameter of the spinner? Since it is Sunday here, Kyosho is closed and the Tru Turn is waiting for my call.
Ihncheol Park
P & A Hobbies
Hide Signatures
       Post #: 64
RE: New Kyosho Oxalys 50 ? - 8/29/2005 6:49 AM
nhisato
Score: 100
Last Login: 4/26/2008
Status: offline
57mm (2-1/4") size is correct diameter
Hide Signatures
       Post #: 65
RE: New Kyosho Oxalys 50 ? - 8/29/2005 11:37 AM
FullSpeedAhead
Score: 100
Status: offline
yes, 57mm is the right diameter, written on the manual. getting the tru turn or dave brown one for mine.
< Message edited by MontBlanc -- 9/10/2005 5:20 PM >
Hide Signatures
(in reply to nhisato)
       Post #: 66
RE: New Kyosho Oxalys 50 ? - 9/1/2005 11:21 PM
Joeri
Score: 100
Last Login: 1/6/2009
Status: offline
Hi Montblanc,
I am about to order a oxalys, I'm just waiting for engine and muffler setup pics?
Hide Signatures
       Post #: 67
RE: New Kyosho Oxalys 50 ? - 9/2/2005 2:13 PM
FullSpeedAhead
Score: 100
Status: offline
quote:
ORIGINAL: amusement
Hi Montblanc,
Hi,
i am almost done, but the tuned pipe and header is not yet in stock at my local hobby shop, and engine is not mounted as much yet as i need to see if a slight rotation is needed to accomodate the header, so juz gotta wait.... waiting "patiently" over here as well! just want to get her up asap.
Jeff
Hide Signatures
(in reply to Joeri)
       Post #: 68
RE: New Kyosho Oxalys 50 ? - 9/2/2005 11:57 PM
Joeri
Score: 100
Status: offline
Does anyone know where the oxalys kit with engine is available in Europe?
Hide Signatures
       Post #: 69
RE: New Kyosho Oxalys 50 ? - 9/5/2005 1:32 PM
Kurt P
Score: 100
Last Login: 12/3/2009
Status: offline
http://shop.pigs-airlines.be/catalog/product_info.php?cPath=541_717_748&products_id=32266
Deurne, Brabant?
Bart, zijde gij da? Of is't Joeri?
Hide Signatures
(in reply to Joeri)
       Post #: 70
RE: New Kyosho Oxalys 50 ? - 9/5/2005 9:09 PM
Joeri
Score: 100
Status: offline
Ja, Joeri hier
Bij Pigs hebben ze alleen de kit zonder motor, en ik denk dat de prijs beter is als je de kit met motor kunt kopen.Ze wisten me daar ook te vertellen dat de kit met motor niet in België, Duitsland en Frankrijk ingevoerd werd.
Bij albatros kunnen ze alleen krijgen wat te koop is bij kyosho in Duistland.
Bij TAM is de kit zonder motor besteld, maar nog niet binnen.
Bij shamrock gingen ze erachter horen, maar heb nog geen reactie gekregen.
Ik hoop dat er bij shamrock iets uit de bus komt, van auto's hebben ze daar toch veel kyosho stuff, dus zal het wel lukken zeker.
Van waar kennen wij elkaar, help me eens even?
Hide Signatures
(in reply to Kurt P)
       Post #: 71
RE: New Kyosho Oxalys 50 ? - 9/6/2005 11:16 AM
Kurt P
Score: 100
Status: offline
hallo Joeri,
ik ken je niet maar mijn maatje wel, die vliegt bij jullie in Schaffen. Kurt, misschien ken je hem.
We posten hier al eens van bij mij thuis, dus gebruikt hij mijn log-in al eens. Ik zou je wel eens willen zien vliegen, want Kurt heeft al zoveel over u liggen stoefen, dat ge een natuurtalent zijt en de pannen van het dak vliegt, samen met ne naamgenoot van me naar het schijnt. Ik zal eens ne keer moeten afkomen. Gelijk de Kukke geraak ik nie veel verder dan een rolleke en een loopingske en nog een kroeme meskant wil ook nog lukken. We zouden ons beter specialiseren in cesna's en pipers. Da kunnen we nog aan.
Da's wel mijn laatste post in 't Nederlands want ik ben als eens op de vingers getikt hiervoor.
Sorry the rest of my be posts will be back in Engish.
Hide Signatures
(in reply to Joeri)
       Post #: 72
RE: New Kyosho Oxalys 50 ? - 9/7/2005 8:01 AM
PatternFlyer
Score: 100
Status: offline
I've shipped couple of the Oxalys 50.
After first look of the contents, Kyosho did a wonderful job packaging. None of those Chinese built plane was packaged this nice.
Looks like I may have to build one instead of selling.
It looks like the 57mm (2.25") spinner is still a little small for the plane.
Ihncheol Park
P & A Hobbies
Hide Signatures
       Post #: 73
RE: New Kyosho Oxalys 50 ? - 9/7/2005 3:34 PM
Frisko
Score: 100
Last Login: 8/8/2008
Status: offline
Will an OS 46FX be enough for this plane. Now I'm flying with the majestic and the .46 is just sufficient. Do you you think the oxalis will have the same performance with this engine, or do I have to look for a more powerful motor?
Dag Joeri
< Message edited by Frisko -- 9/7/2005 3:37 PM >
Hide Signatures
       Post #: 74
RE: New Kyosho Oxalys 50 ? - 9/8/2005 7:43 AM
PatternFlyer
Score: 100
Status: offline
Frisko,
what is the all up weight of the Majestic 1400?
Based on my limited experience with some of the small planes (OK model planes) OS 46 w/ stock muffler was not enough beside the ugliness.
So far, Oxalys 50 looks larger than the Majestic. If the 46 is just enough to fly Majestic, you may want to use tuned pipe.
The test setup of production version of Oxalys 50 weighed 2500 grams (5 pounds 4 oz) dry. That is with 4 of 9252, 1x 9001, 136HP receiver, NR-4RB battery pack, OS 70 Ultimate. Yes, the Oxalys 50 was designed around YS 63, but test model used OS because of weight.
I am going to build one with YS 63 (electric setup costs way too much).
Ihncheol Park
P & A Hobbies
Hide Signatures
(in reply to Frisko)
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.906RCU1
