credence
ON, CANADA Status: offline
nmacwarbirds, thanks for the kind words. I could not tell you which is better since I do not personally own either of them. At anyrate, the #36 is basically a Shogun V2, so it will fly more like that if anything. If I had to put my money on what flies better, i'm obviously going to say a Trex or X400 simply because they're very different machines that have alot of support behind them and quality manufacturing. Along these lines, flies "better" is relative to ones opinion. A t-rex is a very agressive machine, whereas (from what i've read) the #36 is more docile at the controls, so in this regard, depending on your flight preference, one may be better than the other. Walkera very much does have a cult following, which they created themselves through their lack of consistent and proper assembly and product testing. People who have had no problems with Walkera are usually the ones saying they're great, never had any problems, etc. Then you have a clear division, with people on the other side saying they produce nothing but junk, the electronics aren't worth a damn, and so on. Know that saying always make a good first impression? I think it applies here. Only in Walkeras case, they won't likely get a second chance with alot of folks .
_____________________________
Daniel True Northern Hobbies, Inc.
