raap5l
Joined: 5/29/2005 From: sydneynsw, AUSTRALIA Status: offline
the pulleys were both fine, and they were the correct ones from the factory, and they only go on one way. since last post i stripped a 3rd belt, with belt tension very light, then i replaced the pulleys, as im running out of ideas, and them, with a new belt, no change, stripped in 2 tanks. ive given up. i made my own drive system for the side belt using hpi pulleys and belt. runs a thrid pulley inplace of the tensioner to remove slack and to guide belt aswell. see how it goes the next time i run it. i am also going to try and get a longer belt to use for the side belt, with the use of 2 25t pulleys instead of the standard 17t's. last belt driven car i ever get...
