RE: JetCat P60 Oring Replacement DIY    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Fly Eagle Jet F-16 Project, 1/5.5 Scale, includes turbine - ARF
Seller:  Screamin Eagle
Details:   $6,300.00   |  6/13/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: JetCat P60 Oring Replacement DIY
Page: <<   < prev  1 [2]
Login
RE: JetCat P60 Oring Replacement DIY - 9/15/2011 9:51 PM
rcguy!
Score: 108
Last Login: 6/18/2013
Status: offline
I'm betting the new JetCat FOD screen actually helps to minimize the "droop"?
Dave Rigotti
Hide Signatures
(in reply to ianober)
       Post #: 26
RE: JetCat P60 Oring Replacement DIY - 9/17/2011 6:23 PM
flyinfool1
Score: 100
Status: offline
quote:
ORIGINAL: ianober
McMaster has the O-ring size but only in a 75A durometer, not 90.
I tried the 75A durometer before I found a source for the 90. (I had to buy 100 )
The 75A lasted about 6 starts. You need the 90s.
_____________________________
Jeff Borowski
RAMS Club President
Hide Signatures
       Post #: 27
RE: JetCat P60 Oring Replacement DIY - 1/15/2013 6:08 AM
dbsonic
Score: 100
Status: online
thread is ancient but has good pics of the o-ring description and cavity you need to dig out for replacement.
One difference I find is the bell housing bolts look like hex/allen but after trying every size I found the new ones are actually torx t10.
Similar to the bolt holding the EGT thermocouple on the back of the engine.
may save someone looking at this some headache next time.
Hide Signatures
       Post #: 28
RE: JetCat P60 Oring Replacement DIY - 1/15/2013 4:48 PM
flyinfool1
Score: 100
Status: offline
The 6mm X 3mm 90 durometer O-rings are available from Rocket Seals as P/N 6mmX3mmB9 at $0.22 each, minimum quantity is 100. It is not a stock item so you have to call and there is a 7-10 day lead time.
They are also available from Motion Industries for $0.64 each in quantities of 100. Just order by description.
You can call most O-Ring suppliers and tell them what you need and they will get it for you.
< Message edited by flyinfool1 -- 1/15/2013 8:02 PM >
Jeff Borowski
RAMS Club President
Hide Signatures
(in reply to dbsonic)
       Post #: 29
RE: JetCat P60 Oring Replacement DIY - 1/15/2013 7:44 PM
john josey
Score: 110
Last Login: 6/17/2013
Status: offline
The biggest problem i had changing the 'O' ring was trying to stop the bendix from rotating while picking the old ring out. I wrapped masking tape sticky side out onto my thumb and index finger to try and hold it. Anyone have a better method ?
Hide Signatures
       Post #: 30
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.406RCU1
