markmeijer
Well... You seem to be far more experienced than I, so I am not sure how much help I will be. With the Thunder Tiger .91 on mine I have plenty of vertical. My decath weighs in at a little over 8lbs (sorry no sophisticated scales, just my digital bathroom scale). It looks that you will be saving quite a bit of weight by using your existing servos and battery. I have Futaba s3004 servos, a 1400mah nimh battery. I have also swapped the fuel tank for a larger dubro 14oz square tank. I should add that this fuse has plenty of room for a smoke system! This plane is great as it is, but with smoke it would just top the cake!!! I am pretty sure someone else has a saito .72 mounted on theirs, I hope they see this and chime in. My decath flew somewhat scale like with a TT .54 4 stroke, it now flys with authority with the TT.91 mounted. I have not been disappointed yet, this plane has done just about every maneuver that I know how to do, It literally falls into a knife edge as if it wants to fly that way, snap rolls are impressive, and I LOVE how smooth this plane fly’s around at 1/4 throttle. As I slow it down it just holds steady, no stalls yet. I have been able to hover it for about 5 seconds, but it is not built for this kind of flight so I was impressed! I should add that I use 10% Omega fuel. I am confident that with the .72 this plane will fly quite well! Let me know if you have specific questions or need pictures or anything. Hope this helps! -Mark
