Phoenix models Super Decathalon
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Sport Flying >> Phoenix models Super Decathalon Page: [1] 2 3   next >   >>
Login
Phoenix models Super Decathalon - 6/9/2005 2:59:53 AM
Gido_22
Status: offline
I just purchased one of those phoenix models super decathlon since it looked nice and the price wasn't too bad ($109 at tower hobbies) This first pictures is of the box it came in and the contents after i removed them from the box. It looked pretty good, and the packaging was really nice, and after I unwrapped it all i checked to see if I needed to touch up some areas with the iron but to my surprise it didn't need any touching up.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 1
RE: Phoenix models Super Decathalon - 6/9/2005 3:26:48 AM
Gido_22
Status: offline
Didn't encounter to many problems during the build. The wing didn't have any leads in them to help you guide the servo wire to the middle, so after a bit of messing around I find out the servo wire isn't long enough the reach the hole in the middle of the wing or should I say the servos mounts were to far out on the wing, so I had to attach some extensions on them. Other then that the build went pretty smooth. I decided to put a super tigre .75 in it.....slightly bigger then the recommended .46. So i had to replace the engine mount with a bigger one and add some weight to the tail to balance it after I was done building. The total build took me about a few hours. After i was done it looked pretty good. And yes i know the cowl isn't on straight.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Gido_22)
       Post #: 2
RE: Phoenix models Super Decathalon - 6/9/2005 3:38:17 AM
RCKen
Status: online
Gido_22,
Nice looking planes. Let us know how it flies.
I see that we're almost neighbors!!! well, at least neighbors in Texoma!!!
Ken
_____________________________
The take off is optional, but the landing is MANDATORY!!
AMA # 712539 www.gettingairborne.com
Moderator- Beginner''s, Sport Flying, Off-Topic, & AMA Discussions
RCU Community Moderator
       Post #: 3
RE: Phoenix models Super Decathalon - 6/9/2005 3:41:58 AM
Gido_22
Status: offline
I took the Decathlon up for the first time today, didn't need to trim it out much. I flies pretty good, very easy to handle and to everybody's surprise at the field will do aerobatics with ease. Did a couple of snap rolls, loops, hammerheads, and knife edges and did them with no problems at all, no tendency to snap at any point, of course this plane doesn't have unlimited vertical and wont do 3D since it wast build for that. Also this plane is very easy to land. This plane would be a nice airplane for a beginner wanting to learn aerobatics, I wouldn't recommend it to a beginner as a trainer. In the end I'm pleased with it and its a nice plane to fly any day and anyone will love it.
       Post #: 4
RE: Phoenix models Super Decathalon - 6/9/2005 4:38:30 AM
Pilot Chad
Status: online
It looks great.
AMA #837611
Joined a club and am happy as can be.
       Post #: 5
RE: Phoenix models Super Decathalon - 7/11/2005 1:01:19 AM
dolsen
Status: offline
Does it have iron on film?
(in reply to Pilot Chad)
       Post #: 6
RE: Phoenix models Super Decathalon - 7/11/2005 1:59:59 AM
Gido_22
Status: offline
Yea it does, and it didnt need any touch ups after i took it out of the box.
(in reply to dolsen)
       Post #: 7
RE: Phoenix models Super Decathalon - 7/26/2005 4:41:21 PM
PE2fan
Status: offline
How was the balancing with the larger engine? Too much power??
Club Saito #299
       Post #: 8
RE: Phoenix models Super Decathalon - 7/26/2005 5:00:29 PM
Gido_22
Status: offline
I had to add weight to the back of the airplane to compensate for the increased weight of the larger engine, it was way nose heavy. The power seemed just fine, its faster then the other decathalons at the field and it has increased the distance it will travel vertically, i tended to fly it with the throttle at about 75/80 percent open. i think it was a perfect match for the airplane, other then the fact i had to replace the engine mount.
(in reply to PE2fan)
       Post #: 9
RE: Phoenix models Super Decathalon - 8/3/2005 6:34:48 PM
dodge_cowboy84
Status: offline
I'm considering one of these. Is the stars and stripes on the wing stickers or are they printed into the covering? If I get one I'd like to remove them so I can do my own custom job.. Also, how's it fly with the 75? If I get one I'd pour the smoke to it, so I'd need a larger engine to pull the weight.
       Post #: 10
RE: Phoenix models Super Decathalon - 8/3/2005 10:06:38 PM
Gido_22
Status: offline
The stars and stripes are strickers which you can easily remove, as for the .75 engine i think its a perfect match, more then plenty of power to pull the airplane around. Plus the body of the plane is quite large and has plenty of exrta space left over inside for a smoke system after you've installed all the electronics.
(in reply to dodge_cowboy84)
       Post #: 11
RE: Phoenix models Super Decathalon - 8/3/2005 11:18:11 PM
dodge_cowboy84
Status: offline
What kind of pitts muffler do you have on the ST? I looked at Tower and all they have is a pitts muffler for the 2300.
       Post #: 12
RE: Phoenix models Super Decathalon - 8/4/2005 2:19:13 AM
j_oly1999
Status: offline
Hey, this is a great airplane, But definitely go with a .61 or bigger engine. I flew mine with a .46 AX and it tokk all that motor had to fly PERIOD. But a .70 Four stroke was very scale in that plane. I see yours had the white under-belly, mine was all red with the White Sunburst. Dodge, If you look on tower you can find a pitts muffler for a super tiger .75/.90, they use the same one. I have a Pitts muffler for a super tiger .75 that was on a Great planes matt chapman cap 580 for three flights(Note to all listening, that plane has a wicked snap when flying a slow knife edge. Third flight I was just getting used to it so I tried a Knife at about half throttle, it snapped all the way to the ground) If your interested in the muffler, I'll make you a good deal. it just needs one of the pipes brazed back on, the brazing gave out when it hit the ground. PM me if you want it CHEAP. If you want to put smoke on it, I'd go with a .91 Four stroke or a saito .82, four strokes smoke better I think, plus the bigger they are, the more smoke you can get.!!!
Just my $0.02 worth
What goes up, must come down. How hard is anyones guess!
       Post #: 13
RE: Phoenix models Super Decathalon - 8/4/2005 7:09:40 PM
dodge_cowboy84
Status: offline
*gears begin to work again*
Thanks!!
Will consider a 4 banger now
(in reply to j_oly1999)
       Post #: 14
RE: Phoenix models Super Decathalon - 10/4/2005 4:31:15 AM
markmeijer
Status: offline
Hi j_oly1999 and everyone,
I built this awesome decath with a Thunder Tiger .54s 4 stroke, and also found it to be under powered. I ordered a Thunder Tiger .91 4 stroke tonight and am hopeing for some good results. What do you guys think of this combination? I am worried that it will be too much engine for this plane. Please let me know what you think.
Thanks in advance,
-Mark
       Post #: 15
RE: Phoenix models Super Decathalon - 10/4/2005 7:17:14 AM
