credence
ON, CANADA Status: offline
Josh, Helicopters rarely if ever take off straight into the air. The helicopter will always naturally move to the left due to rotor torque and the tail rotor countering that torque. With the exception of your trims being off, the only way to take off straight is to learn how to fight the helicopters movements while on the ground. You will almost always require some right cyclic to keep the heli from skittering off to the left during take off. If the heli continues to veer to the left even once airborne (and out of ground effect) then mess around with your trims untill the heli stays in a general area without heavy stick movement. Even airborne the helicopter will still drift to the left, however, it should happen slowly (assuming you're in a steady hover to begin with). If you constantly need to give heavy right cyclic to keep the heli stationary then you've got a trim problem If there's anything i've noticed about FP birds, it's that they require enourmous ammounts of attention. You need to constantly keep your eye on the bird and watching and anticipating how it's going to move and react next. Typically speaking, the stick movements of your controller should be directly relative to the ammount the servos are moving on your heli. In other words, it takes very little stick movement to get the heli to move in any given direction. Over-correcting will end up in a crash. Quick, small stick movements in small ammounts of time work better than big stick movements over larger ammounts of time. Hope i've been of some help, as i've gone through the same thing you have learning to fly a fixed pitch heli, but after awhile you just "get it" and then flying becomes so much easier. I can hover in a tiny space in my room now without much problem using a hybrid GWS Dragonfly/Walkera #4 Dragonfly heli.
_____________________________
Daniel True Northern Hobbies, Inc.
