Stripe 1
NC, USA Status: offline
Hey navy,I have been running saito engines since I started flying and will not run anything else. I have a 1.50 that is ten years old and runs like new. About valve adjustment,it is very easy to do and saito comes with the required tools for doing this,I have seen guys run four strokes without adjusting the valves and it will cause wear on the lobes of the camshaft,my 1.50 has at least thirty gallons of fuel run thru it. What more could you ask for ? I also have two 1.80s would'nt trade any of them for anything. Only other engines I run are Desert Aircraft. Hope I have helped you make up your mind,try a saito,you will love it !
< Message edited by neal easter -- 8/13/2005 4:12:01 AM >
