colco thunderbird II ( aka cyclone)
Tower Hobbies
Logged in as Guest
  Printable Version
E-Flite Blade CP Pro - RTF
Seller:  TheRealSuperDave
Details:   $350.00   |  10/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Electric RC Helis >> colco thunderbird II ( aka cyclone)
Page: [1]
Login
colco thunderbird II ( aka cyclone) - 6/13/2005 2:19:31 AM
paedbo
Status: offline
I was asked a question about this heli in another post and figured i would post a seperate topic,
I inherited this bird because a friend didnt have the patience with it and was wasting money on it.
Its an FP bird, the question i was asked was what parts or upgrades can it use from the get go.
I have a honey bee 2 cp bird that was my first heli, out of the two, the honey bee 2 flies better than the colco thunderbird, However when it comes to crashes the colco is a hell of alot better at surviving than the honey bee 2. I was actually able to learn more nose in hovering with the fp colco than with the honey bee, because i was always frightened of crashing the honey bee 2 and losing a main gear, blades and maybe rotor head pieces or popped apart swashplates. With the fp bird since i knew how resistant it was to crashes, i wasnt afraid to turn it around and actually do the nose in hover thing, it actually helped me alot faster in a few days than weeks with the other bird.
anyways, the colco thunderbird II will fly but its alittle harder than other micros. I have no experience with other fp birds and im sure there are others out there that are just as resistant to crashes but might fly better.
but anyone interested in the colco here is a small list of things i learned from it.
Most parts for this bird can be found here http://www.raidentech.com/cothbisppa.html
1. the paddles are under the main blades, i find that in crashes it is easy to break the fly bar. so i shortened the fly bar by about an inch because it is fairly long. I get less cyclic response out of it, but it helps for the first few flights of learning to hover. Anyhow if you buy the colco thunderbird make sure you buy plenty of spare flybars (#EH09) Stabilizing Wing Beam
2. my friends main motor died and he started to buy new motors from the reaidentech link i listed above. Most of the parts are fairly cheap, but the motor he was getting was not strong enough to lift the bird very high so when he gave it to me i started using the mabuchi 370 motors that come with the honey bee 2 cp, which you can find at heli-fever.com its 10 times better!
3. the landing gear is weak and you will often snap a leg off it so buy a few spares (#EH20 Foot Pole Support) i dont change them out right away sometimes i just tape it back to the skid to get more flights out of it, you could probably glue it also.
4. the battery pack it comes with is horrible. ( nimh) get a good lipo battery for it, now whether or not to use a 2 cell or 3 cell lipo im not sure, i have been running it on 11.1v 1200mah pack. i tried an 11.1 1800mah pack, it will fly but its too much weight. There might be some concern about flying the colco on such a high voltage but so far i havent had any problems with it ( about 15 flights)
5. Dont buy the tail motors like the one you see on the raidentech.com site, instead use ones like from heli-fever.com ( under the esky 3d parts list) they last alot longer. ( plus they already come with the capacitor soldered on)
6. Its hard to bust the main blades but it does happen occassionally. They will pop off under high force but every once in awhile you hit them just right and break them. I've hit steel poles with it before and i pick it up and straighten everything out and off i go again. I have found sometimes when changing blades that they are way out of tracking and cause the heli to shake violently and it has no power and will barely lift off, you basically have to find which blade is tracking lower, then give it a good twisting by the roots and retest it until you get them to track properly.
7. Ive never had much problems with any of the rotor head pieces, only the figure 8 shaped links that connect the flybars to the main paddles tend to wear out fast if you crash often ( they pop off the main blades to allow the main blades to be ejected from the heli in a serious crash) So here is a list of all the ball link parts of the head that tend to wear out that is good to keep spares of (#EH03) Single Hole Tie Bar , (#EH02) Rotor Head For Thunder bird, (#EH04) Rotary Sleeve Spindle For Thunder Bird, of course theres a few other ball link parts that connect to the swash plate but i havent had to change those yet. ( all the rotor head pieces even the swashplate cost no more than $2.50
other than that i cant think of anything else right now, the colco does use a pg-03 gyro and has a 3 in 1 box permanently attached to the front of the frame The honey bee fp2 seems very similar as far as the rotor head setup and all, but i think it uses a 4 in 1 box, i prefer having a seperate gyro like the colco thunderbird II has. oh yeah, one other thing i did have to do was pull the servo arms off and readjust them because i would have the trim all the way over to one side and the heli would still tip to one side.
anyways like i said i wouldnt suggest a micro for a beginner heli, they are just so hard to control, but if i had to do it all over again and my only two choices as a beginner was this colco thunderbird or my honey bee 2 cp, it would of been the colco, sure it dont fly as good, and cant do inverted flight etc, hell it cant even fly in light breezy winds. but it would of saved me alot of $$$$ in broken parts. The money i spent fixing the honey bee cp 2 could of easily gotten me a trex kit. or similar.
Just for a reference, in 3 weeks time with the honey bee 2 i had to buy $100 worth of parts ( blades ate up most of that cost) with the thunderbird in the 3 weeks i have had it, i spent $26 and some of that cost was to fix damage he had already done to it.
< Message edited by paedbo -- 6/13/2005 2:34:48 AM >
       Post #: 1
RE: colco thunderbird II ( aka cyclone) - 6/18/2005 3:38:14 AM
lardaz
Status: offline
I, like you, started with the honeybee, I got a wild hair and got the cyclone and I must say Ive had a lot better success with it. Ive been able to get a very stable hover. Very survivable to crashes. I even fly it without the training gear. Im trying to get the nerve up to do more than hover! I did try the lipo battery from my honeybee, it did fly better but it seemed to get a lot hotter and also would sometimes just shut down. So for the time being until I find out more about the lipos I guess I'll stick with the nimh. Im not ready to burn up a motor or something else. As for the honeybee, Ive been lucky not to break more than I have. Ive broken and glued the main gear a few times, Ive been useing the training gear which Im sure has save me a bunch of parts and money. My problem now is the main shaft has a very slight bend in it which puts out quite a bit of vibration. As far as the main blades I have been able to repair mine. The covering they use is crap. I was able to fill in the dings and dents with scrap balsa and super glue plus wipe the leading edge with super glue, sand smooth then cover them with monocote airplane covering. They are a lot more durable. Im working on making my own blades. Where are you getting your parts from? Dont want to have to order from Hong Kong and the places ive found in the US dont seem to have what I want in stock. Anyway I just have not been able to get the more stable hovering with the honeybee as with the cyclone. I would like to find out more about the lipo batteries with the cyclone.
(in reply to paedbo)
       Post #: 2
RE: colco thunderbird II ( aka cyclone) - 6/18/2005 4:05:28 AM
paedbo
Status: offline
try a 2s pack with the cyclone 3s might be too much for it. Though mine has been running fine on 3s, it did shut down one time on me from about 10 foot hover. the cyclone survived of course and it just launched the lipo like a torpedo across the pavement lol.
i used to get honey bee parts from hong kong everything except blades i got those $9.99 specials at century heli, and let me tell you those are some tough blades, those were the first set of blades i had for the honey bee that dont blow apart on the first crash or cause a major cracks. The leading edge is very strong and so is the covering.
ill take a video tomorrow of the cyclone hovering in case people want to see, i rarely see any videos of those dirt cheap fixed pitch micros. The landing skid is broken though, ill just put some tape on it and let it fly! ( no pun intended)
< Message edited by paedbo -- 6/18/2005 4:09:37 AM >
(in reply to lardaz)
       Post #: 3
RE: colco thunderbird II ( aka cyclone) - 4/6/2006 3:28:39 AM
serverslayer
Status: offline
Paedbo, I too have a honeybee, and am a supernoob. I actually go it from my dad who broke the flybar and rotor head. Anyhow I got the parts and am putting it back together and had a question. How do you get the flybar in without breaking it? It seems to fit in the paddle control frame and center hub VERY tightly. I am having a difficult time geting it in and have already broke a new one. Before I break the second one I have do you have any tips for getting it in easily. Any help would be appreciated.
**serverslayer**
       Post #: 4
RE: colco thunderbird II ( aka cyclone) - 4/9/2006 2:50:38 PM
bond1
Status: offline
I just bought a Cyclone Thunderbird 2. aka Colco.. the bird was easy to fly until i broke one main blade off when it hit the floor. I ordered new blades for it and put them on . Now the bird will not
lift at full throttle. It does viberate some on the hard floor. Are my main rotor blades not adjusted
correctly or is my Main rotor shaft bent causing the problem?
Please help ... bond
(in reply to serverslayer)
       Post #: 5
RE: colco thunderbird II ( aka cyclone) - 4/12/2006 9:05:23 PM
flew2high
Status: offline
I had the same problem after changing the blades the 1st time I broke them (wouldn't be the last, that's for sure). Turns out I installed one of them upside down. Might want to check that. I still haven't progressed much past a hover and some light cyclic work; this thing is SOOooo unstable. Shortening the flybar definitely damped down the response; I discovered this by accident after breaking one, then just recentering it. Also, I had the issue of having to rejigger the servo control horns in order to even come close to a stable liftoff. I ended up having to set the horn so the swashplate was forced quite far to the right; it's noticibly tilted when Tx trims are centered. Forget a nice, slow scale-looking liftoff - I found it's usually best to just zip the throttle up to about 3/4 of it's travel, and the bird jumps off the ground. Then, I back it off a little while trying to manage the inherent instability with cyclic inputs. Parts are mercifully cheap, and it is pretty tough. Latest crash (yesterday!) splintered the tail boom into 5 or 6 splits along it's length, but it's still technically in one piece. If I squeeze it together it looks solid and would probably hold with some reinforcement. What would y'all suggest is the best way to fix it? I was thinking of wrapping it spirally with light electrical tape, then placing a few micro zip ties spaced along the length to keep it nice and tight. Sound good?
(in reply to bond1)
       Post #: 6
RE: colco thunderbird II ( aka cyclone) - 4/13/2006 3:21:55 PM
gmmwicked
Status: offline
Make sure the paddles on the stabilizer bar a parallel to the floor, perfectly. I noticed if they were a little off, even one of them that the heli would not lift.
(in reply to flew2high)
       Post #: 7
RE: colco thunderbird II ( aka cyclone) - 5/22/2006 10:28:44 PM
ryanaugustine
Status: offline
Thanks for all the colco info it has been instrumental to my piloting experience!! I was just wondering, paedbo, did you have to put a new speed contoller on you thunderbird, when you put on your 11.1 v 1200 battery? I went to the local hobby store, and the guy wouldn't even sell me the battery and charger, he said that the battery would burn up the motor. I told him that I don't care, more motors don't matter to me, but more flight time does!!!
(in reply to gmmwicked)
       Post #: 8
RE: colco thunderbird II ( aka cyclone) - 6/12/2006 5:07:00 AM
TT120
Status: offline
I was wondering that myself. How well does the stock T-Bird electronics stand up to the 11.1 volts of a 3c LiPo?
(in reply to ryanaugustine)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
Photo Gallery | Member Video Posts |
