2slow2matter
TX, USA Status: offline
As far as the spar goes--don't worry about it. one of three things has happened: A) The spar is supposed to stick up a little, because when you add sheeting later on, it will all be flush B) The slot in the rib for the spar was slightly smaller than the spar. It is fully seated, but isn't flush C) The spar didn't quite get all the way into the slot, and isn't flush on the top. In the case of B and C, just sand it of flush. You'd have to do some sanding on it anyway. This is where a long bar sander comes in handy! You might have to read further into the instructions to find out if the case is "A" Dont worry about sanding it until the manual tells you. It will say to sand off all parts flush with each other. At that point, you will know! If the case is "C", then when you can get to it, fill the gap between the spar and rib (where it didn't seat properly) with some thick CA. If you don't have thick, then fill it with medium, and hit it with some kicker. This will somewhat strengthen the joint. BTW, if done properly, the CA glue will be much stronger than the balsa that it's joining, so don't worry about using CA--it works. Some people prefer not to use it. You make up your own mind!
_____________________________
From a pile of sticks they are born, to a pile of sticks shall they return.
