where did my batterie's full charge go???
Tower Hobbies
Logged in as Guest
  Printable Version
NEW TENERGY 30C 2200mah 3s Lipos - FREE SHIPPING
Seller:  punkindrublik
Details:   $55.00   |  8/25/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> where did my batterie's full charge go???
Page: [1]
Login
where did my batterie's full charge go??? - 10/9/2002 3:06:15 PM
lownslo
Status: offline
I have noticed that my "reliable..always watched closely" batteries in my TX and RX have shown abnormal volts compared to what I was always used to seeing. I charged the batteries.....checked them with my loaded digital voltmeter, but left them plugged into the charger. The charger is on a TIMER so the current WAS OFF. (in fact..I had pulled the timer out of the outlet this time) The batteries were at full charge. I checked them a little less than 24 hrs. later. They had dropped much more than I was used to seeing. EXAMPLE: My RX was at 5.35 volts and it had dropped to 4.90 volts. (about what I might see after 4 flights). My TX dropped to 85%+ on the meter, from it's "pegged" position!! My question is this..... Has
anyone out there experienced this problem with the Hobbico Muli-charger described above??
Is it possible for the current to "drain off, or back" through the charger due to design flaw, or a malfunction??? ... thanks ... lownslo
< Message edited by lownslo -- Oct 9 2002 10:57AM >
       Post #: 1
where did my batterie's full charge go??? - 10/9/2002 5:21:56 PM
Red Scholefield
Status: offline
There are a number of charger systems that when disconnected from their power source will allow the batteries, if still connected, to discharge back into the charger.
_____________________________
Red S.
AMA 951 Leader Member
(in reply to lownslo)
       Post #: 2
where did my batterie's full charge go??? - 10/10/2002 2:00:28 AM
sfaust
Status: offline
[QUOTE]Originally posted by redscho
There are a number of charger systems that when disconnected from their power source will allow the batteries, if still connected, to discharge back into the charger. [/QUOTE]
And the Hobbico Multicharger and AccuCycle were one of them. I actually tested this a while ago, and found that they do take out a significant amount over the couse of a week or so. [SIZE=1](Red, you might recall this, as I send you the findings in an e-mail about 2 or 3 years ago. [/SIZE]
I routinely unplug all my batteries from chargers now if they are to be disconnected from the power sources.
Stephen
http://www.StephenFaust.com/giantscalerc - my hangar, http://www.StephenFaust.com - commercial photography
       Post #: 3
A Big Thanks 1! - 10/10/2002 4:59:48 AM
lownslo
Status: offline
Thanks to you both !!! I sort of thought that might be happening. It sure would help people out if the manufacturers would mention unplugging the battery if the power source is shut off. ....lownslo
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.309RCU1
