What are fuel dots?
Tower Hobbies
Logged in as Guest
  Printable Version
3W 3W 28i - RTF
Seller:  Miata Man
Details:   $415.00   |  9/24/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> What are fuel dots?
Page: [1]
Login
What are fuel dots? - 10/9/2002 3:24:31 PM
coomarlin
Status: offline
I've been considering getting one of those DuBro quick-fill fuel valves to add to my next plane but I'm hearing that some of those have problems with leaking. Other people are talking about fuel dots. Haven't been able to find out anything about them. Can someone fill me in?
       Post #: 1
What are fuel dots? - 10/9/2002 3:59:05 PM
vinnie
Status: offline
Coomarlin, a fuel dot is a small fitting to which you can attach a fuel line, usually from the third line in your fuel tank, and screws or glues to the cowl or fuselage of your model.
Try [url]www.pspmfg.com[/url]
_____________________________
Regards,
vinnie
AMA 680367
(in reply to coomarlin)
       Post #: 2
What are fuel dots? - 10/10/2002 7:03:14 AM
GalenB
Status: offline
You can also use a fuel dot with the "Miracle Y" fueling system. The key item is that a fuel dot is not a valve and has a plug the closes the fill/drain line. This is critical for those engines that use a pressuruzed fuel system, e.g. YS.
Cheers!
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.234RCU1
