dragon_no_fly
jctpro, your heli looks pretty cool. I checked out your pictures. It sounds like you are using the stock Esky transmitter, but with a new HiTec 6 channel receiver.......sounds like there are no more stock electronics in that thing, no wonder why it works so well! I just got in my brushless tail mod, the Feigao BL motor and Castle Creations brushless ESC, but I am still waiting on the continually backordered Futaba 7CHP computer helicopter transmitter. Once I get this in, I can then setup the new BL tail mod, till then, TREC will have to do its job. As far as the tail will be setup, I am going the direct drive route, better RPM, a bit less weight, the tail rotors are only about $1.00 as opposed to the stock geared ones at about $6.00 and the DD(Direct Drive) setup has better ground clearance than the stock geared setup does.
