MadScientist
Joined: 6/16/2003 From: Kissimmee, FL, USA Status: offline
I just picked up this ARF and I am testing it out as a new possible plane for our formation team. I would like to put a Jett up front, but I have concerns about noise, as we will be flying 4 of them at once. I also have seen lots of fuel leaks out of the front bearings of this engine, can anyone who is using this engine confirm or deny this for me? Has anyone checked the engine noise DB level of a Jett 90 with the standard muffler, and the appropriate prop for this model plane? We also have concerns about fuel tank placement, as we plan to put a larger tank in so we can get longer flights, but it seems like putting a 18 oz tetra tank in the nose would make this a really nose heavy plane. Putting the tank at the CG will solve this, but it would require a pump. We're considering the Webra 120 pumped model, anyone ever try this engine out? Who has flown this off of grass, anyone? What's the takeoff length? We're considering flaperons as a short field takeoff option, but I was wondering what this plane does out of the box first before we go ahead with any modifications. Thanks for your help!
_____________________________
If you didn't build it, it's not really yours
