Robert Groves
Joined: 5/1/2007 From: Johannesburg, SOUTH AFRICA Status: offline
Hi Jim Congrats on the maiden, great video and great looking plane, I like the strut btw! It looks like my maiden all over again, except you managed to put it down way better than I did. What expo are you using? I found my 15% works very well. A bit of advice I want to offer if I may, when you are flying this bird, it becomes very obvious that the nose is easier to raise when the fuel is lower, which is the reason I was "balooning" the plane on landing, which seems to be what you did as well. On landing keep elevator feed and play with throttle more, if you find yourself pulling back "hard" on the elevator when the plane drops, chances are your plane is going to gain height and loose momentum. My experience in jets is limited to this plane, but from what I see momentum is the name of the game here, without it you can get bitten badly! The only way I got this right was finding a suitable flight sim plane. Cheers Rob
