RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND FASTER!!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND FASTER!!! Page: <<   < prev  67 68 69 70 71 72 73 74 [75] 76   next >   >>
Login
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 9/8/2012 7:06 PM
k8svrick
Score: 100
Last Login: 3/17/2013
Status: offline
Air retracts were optional ($100) at the time I bought mine about 3+ years ago.
_____________________________
Rick - Columbus, OH
www.ricktressler.com
Hide Signatures
(in reply to DougV)
       Post #: 1851
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 9/8/2012 7:31 PM
ftjets
Score: 100
Last Login: 4/8/2013
Status: offline
quote:
ORIGINAL: DougV
If i recall correctly, version 3 also came with air-up spring down retracts, version 2 had air-up air-down.
Let me know if you want me to take real close pics of my version 3 cockpit.
Doug.
While i failed to closely inspect the retracts i am fairly certain that they were air-up and air-down. The manual also shows that setup. I won't cut the box open again to verify that but i am quite sure they were au-ad. Also, while dry fitting the components i did notice that the front alignment post on the vertical stab (i think it was the front one, the one without the locking screw) was about an inch short of the hole it is supposed to fit into. That is no problem, i will simply have to drill another hole and maybe reinforce the area a little but that may help indicate which version it is. This kit was put together from spare parts and small issues like that are no problem. I was quite happy and grateful that i was even able to get it. Everything else appears to be a perfect match. Any pics of the cockpit assembly would be very much appreciated.
john
Hide Signatures
(in reply to DougV)
       Post #: 1852
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 9/9/2012 1:23 AM
DougV
Score: 110
Last Login: 5/22/2013
Status: offline
Here you go....hope that helps.
Doug.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to ftjets)
       Post #: 1853
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 9/9/2012 10:21 AM
ftjets
Score: 100
Status: offline
Perfect! Thanks Doug.
Hide Signatures
(in reply to DougV)
       Post #: 1854
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 9/9/2012 3:56 PM
LUDS96
Score: 100
Last Login: 5/12/2013
Status: offline
My Version two retracts are air up spring down.
Looking for a canopy. I'm thinking of trying to make them.
Hide Signatures
(in reply to DougV)
       Post #: 1855
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 9/9/2012 4:05 PM
ftjets
Score: 100
Status: offline
quote:
ORIGINAL: LUDS96
Actually, i have a canopy and the cockpit pan. I do not have the canopy frame. That is what i need. If you make some i would be happy to take one off your hands.
Hide Signatures
(in reply to LUDS96)
       Post #: 1856
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 9/9/2012 5:12 PM
LUDS96
Score: 100
Status: offline
The frame is painted on the inside. Mine had a cockpit and the Canopy. I'm looking for a Canopy for Version two. I'm thinking of taking the one I have and creating a mold of it.
Hide Signatures
       Post #: 1857
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 9/10/2012 5:29 PM
stevenchao
Score: 100
Last Login: 10/4/2012
Status: offline
The original retracts that CERMARK supplied and recommended were Air up & Spring down.
Peace,
Steven Chao,
CERMARK
Peace,
Steven Chao, CERMARK
Hide Signatures
       Post #: 1858
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 9/11/2012 11:11 AM
miklos
Score: 100
Status: offline
I've had a couple of version 3's and they were both air up and air down retracts...
Hide Signatures
(in reply to stevenchao)
       Post #: 1859
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 9/11/2012 12:28 PM
ftjets
Score: 100
Status: offline
I just had to cut the box open again and look, i have air up-air down units. They are sharp looking though! I used au-ad Robarts for years and don't remember ever doing a belly landing due to lg failure. They are nice looking retracts. I'm sure they will work just fine. All i need to do is come up with a canopy frame to get this thing built. I won't be starting on it for at least a couple of weeks so i have time to either find one or fabricate one by then.
Hide Signatures
(in reply to miklos)
       Post #: 1860
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 9/11/2012 1:09 PM
k8svrick
Score: 100
Status: offline
With regard to landing gear installation, be advised, the mounting plates are inherently weak. Reinforcement with additional plywood is strongly suggested. I published a build log and a detailed procedure I came up with to strengthen that part of the aircraft.
It is located at www.ricktressler.com.
Rick
Rick - Columbus, OH
Hide Signatures
       Post #: 1861
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 9/11/2012 1:14 PM
k8svrick
Score: 100
Status: offline
Follow up to my last...
Www.ricktressler.com without the period after the com works. On my previous posting, the message included the period which makes the URL appear invalid.
Rick
Rick - Columbus, OH
Hide Signatures
(in reply to k8svrick)
       Post #: 1862
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 9/11/2012 1:15 PM
ftjets
Score: 100
Status: offline
Thanks Rick, i already have your website saved. I'll be reading through it when i get ready to build.
John
Hide Signatures
       Post #: 1863
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 9/12/2012 2:44 AM
TXKflier
Score: 100
Last Login: 5/11/2013
Status: offline
My Cermark F-18 and F-16 V3 prop jets both came with air up/air down retracts.
Hide Signatures
       Post #: 1864
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 9/30/2012 11:00 AM
ftjets
Score: 100
Status: offline
Other project is complete and will be flying in a couple of hours, hopefully. Now i can start on the F-16. Looking forward to getting this thing built. I'll probably start on it today when i return from the field.
Hide Signatures
(in reply to TXKflier)
       Post #: 1865
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 10/2/2012 12:41 PM
ftjets
Score: 100
Status: offline
OK, the fun begins. Looking back in the thread Steven Chao noted that version 3 had a latch type canopy. That's mine so i will move on assuming that i have version 3.
Hide Signatures
       Post #: 1866
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 10/8/2012 1:53 PM
ftjets
Score: 100
Status: offline
OK, retract mounts beefed up and gear installed. I am working on the stabilators now. The aluminum tubes are quite tight in the bushings. I certainly will not do anything to bore them out so the only option i know of is to lubricate them a bit. Any suggestions here? I have no doubt that my servos will be growling if i don't do something to loosen them up a little. Also, anyone made the stabilators functional and was it worth it? My Futaba 10C can make them operational.
Hide Signatures
       Post #: 1867
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 10/8/2012 3:11 PM
vasek
Score: 147
Status: offline
Hi ft, I would use some lube spray designed for garage doors. Not the oil based ones the ones used on the rubber seals to slide better. Can't remember the name of it... v.
Remember: Speed is life!
Hide Signatures
       Post #: 1868
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 10/17/2012 10:42 AM
ftjets
Score: 100
Status: offline
The build is going fairly well, slow but well. Stabilators are nice and smooth now and installed. Vertical stab and rudder is installed. Retracts are installed and plumbed but when i mounted the engine i realized that the muffler was pointing directly at the right main wheel well and i didn't think to fuelproof the wood retract mounts and former. I assume that i can expect some exhaust mess getting in there. Have i assumed correctly? I hate to remove all those air lines and have to fish them back through the fuse but i guess i have no choice.
Hide Signatures
(in reply to vasek)
       Post #: 1869
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 10/17/2012 11:26 AM
k8svrick
Score: 100
Status: offline
Consider installing a diverter on the muffler as well.
Rick - Columbus, OH
Hide Signatures
       Post #: 1870
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 10/17/2012 11:36 AM
ftjets
Score: 100
Status: offline
quote:
ORIGINAL: k8svrick
I thought about that and probably will. I hate using them though.
Hide Signatures
       Post #: 1871
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 10/17/2012 11:51 AM
k8svrick
Score: 100
Status: offline
It's has effect, but not a lot.
Rick - Columbus, OH
Hide Signatures
       Post #: 1872
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 10/17/2012 12:00 PM
ftjets
Score: 100
Status: offline
quote:
ORIGINAL: k8svrick
OK, thanks.
Hide Signatures
       Post #: 1873
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 10/17/2012 5:25 PM
k8svrick
Score: 100
Status: offline
Sure, no problem. I flew mine about one season, then it has been a hangar queen ever since. I don't get enough time to fly and this summer was the worst for that. I need to be on top of the old game before I pull that out of the basement. I have a couple pylon planes and some other aerobatic ships, but the 16 is unique. It is also fast with a Dub Jett .90. It's a handful.
Rick
Rick - Columbus, OH
Hide Signatures
       Post #: 1874
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 11/3/2012 10:09 PM
ftjets
Score: 100
Status: offline
OK, took a little less that two months to build. I'm happy with that. Maiden scheduled for tomorrow morning and weather is looking beautiful in southwest Florida. Did a quick build on the canopy frame but i build to fly not to show. If i clock at 125 or better with my brand new Jett 90BSE tomorrow i'm happy. Got her all broken in and ready to fly. Video posted shortly. (if maiden is successful that is)
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1875
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.609RCU1
