THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND FASTER!!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND FASTER!!!
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND FAS... - 6/15/2005 10:57 PM
jetpilotrich
Score: 100
Last Login: 2/24/2013
Status: offline
I just began working on my new CERMARK F-16. I figured we needed a good build thread for it.... there seems to be lots of interest in this plane! There is not to much to building it but, like any ARF, there always seem to be better ways of doing things or things to watch out for. I have already noted several really good and some not so great things that we can all compare notes and ideas on so we can get our planes to fly better!
It is nice to see that there seems to be a whole slew of next generation prop-jet type airplanes becoming available in both "KIT" and "ARF" formats that are of an excellent quality. The best part is they perform well and do not cost $10,000 per copy as a turbine model can cost!
I am looking foward to this ARF... I just finished my AKM SU-27 "FLANKER" prop-jet ( http://akmodels.bizland.com/ for those interested ) ... which is probably the nicest prop-jet kit around but, it is a kit... This F-16 should make for some good instant gratification! The quality looks fantastic!
All are welcome to get in on this thread especially all the prop-jet people out there!
To start things out I have posted a few pics of the layout of parts and a Flanker pic or two from the AKM SU-27 build thread.
Thats all for now!
Rich
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AN... - 6/15/2005 11:10 PM
vasek
Score: 147
Last Login: 5/23/2013
Status: offline
Rich, good choice! I plan on ordering one next week....
will follow your build with interest!
what engine you will put on the nose? mine will have a MVVS .91 with a short pipe (have to see the fit when I get the plane)
BTW, make sure you reed some comments on the supplied retracts! I won't be using those for sure, putting in a set of pneumatic B&D, others have used Spring Airs.
Anyway, lets build this jet!!!!!!!!!!!!!!!!!!!!
_____________________________
Remember: Speed is life!
Hide Signatures
(in reply to jetpilotrich)
       Post #: 2
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AN... - 6/15/2005 11:37 PM
lear31A
Score: 116
Last Login: 9/18/2012
Status: offline
I have had no problems so far. I am installing the gear (air) tonight. All of this with no instructions. I have heard several people getting one with the gear included. I received no gear with mine as it says on their website, the gear sold seperately. I posted some pics in my gallery.
Will fly for coffee
Hide Signatures
(in reply to vasek)
       Post #: 3
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 6/15/2005 11:55 PM
hattend
Score: 105
Last Login: 5/15/2013
Status: offline
Looks great, Rich.
Wish I still had money.
Don
Revver Brother #94
Hide Signatures
       Post #: 4
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AN... - 6/16/2005 1:35 AM
Blade47
Score: 105
Last Login: 5/21/2013
Status: offline
You do DON but it is all in box's in a garage in Redding right?
Pete
Revver Brother #93
Hide Signatures
(in reply to hattend)
       Post #: 5
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AN... - 6/16/2005 1:40 AM
hattend
Score: 105
Status: offline
quote:
ORIGINAL: Blade47
Nahh, it's all on my new wife's finger and in her closet...LOL!!!
(okay, yeah, it's in the garage too.)
Don
Revver Brother #94
Hide Signatures
(in reply to Blade47)
       Post #: 6
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 6/16/2005 5:03 PM
bob27s
Score: 105
Last Login: 5/7/2013
Status: offline
This should be a fun thread..... just signing up
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
Hide Signatures
       Post #: 7
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AN... - 6/16/2005 5:50 PM
Blade47
Score: 105
Status: offline
Bob27 a Q for you? Will one of your mufflers fit the Evo 1.00NX? The muffler bolt spacing is 42 and the bolts pass through the muffler and screw into the motor head case.
the weight is 5.3 oz and I would like to get a lighter one...along with any other benefits
Pete
Revver Brother #93
Hide Signatures
(in reply to bob27s)
       Post #: 8
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AN... - 6/16/2005 8:16 PM
bob27s
Score: 105
Status: offline
quote:
ORIGINAL: Blade47
Blade,
Sure...... the JS-90 muffler will work great. The 42 mm bolt-on is possible with the use of an adapter piece. Just specify the Evo100 and the JS-90 muffler when ordering. The ASP/Magnum .75 and 1.20 have the same bolt-on 42mm configuration.
Jett Stream JS-90 muffler weighs about 180 grams......... that's around 6oz. Not sure there is help in the weight department.
Bob
(note ..... the 90LX muffler weights about 1/2oz less, and is smaller, but you would have to prop the engine to run up at least 14K rpm on the ground)
< Message edited by bob27s -- 6/16/2005 8:25 PM >
Bob Brassell
Hide Signatures
       Post #: 9
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AN... - 6/16/2005 9:30 PM
Blade47
Score: 105
Status: offline
Thanks for the info Bob ...will think about trying one on the EVO
Pete
Revver Brother #93
Hide Signatures
       Post #: 10
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 6/17/2005 6:11 AM
Flyjets
Score: 100
Last Login: 3/21/2013
Status: offline
Rich
Nice photos of ur new F 16 from Cermark.
I had that green retract gear on my F20 it wiggled a bit more then I cared for. However I noticed they sell something called
Custom Aluminum Retracts anyone seen these?
What motor u going to put in her?
Will the Jet 90 fit and do u think the Airframe could handle 130mph?
She does look like a good speed-plane candidate.
Ian
RCU Moderator
Management is doing things right; leadership is doing the right things
Hide Signatures
       Post #: 11
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AN... - 6/17/2005 1:40 PM
LDM
Score: 174
Last Login: 5/22/2013
Status: offline
Can you please let me know where to get this plane , every time I try to find a website i get all the RCU or other RC webs but nothing on cermark , thanks .
LDM
Hide Signatures
(in reply to Flyjets)
       Post #: 12
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AN... - 6/17/2005 4:16 PM
hattend
Score: 105
Status: offline
quote:
ORIGINAL: LDM
http://www.cermark.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=C&Product_Code=CER-A108D&Category_Code=AAA
Don
Revver Brother #94
Hide Signatures
(in reply to LDM)
       Post #: 13
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AN... - 6/18/2005 4:07 AM
LDM
Score: 174
Status: offline
thanks Don
LDM
Hide Signatures
       Post #: 14
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AN... - 6/18/2005 6:30 AM
BRYAN01601
Score: 100
Last Login: 1/8/2012
Status: offline
what is the auw of this ?
Hide Signatures
(in reply to LDM)
       Post #: 15
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AN... - 6/18/2005 1:46 PM
LDM
Score: 174
Status: offline
Any reports on the retracts from Cermark ??? ARe they a brand , spring air ,Robart ect ?
Thanks , this plane looks very very nice . Quality seems high from the pics .
Rich , that SU27 alos looks fantastic , I was amazed that the kit only listed out around $125 , really cheap considering the looks of the lasor cutting and quality . I may just build one and Buy this F 16 , wifey and the kids are getting tired of seeing me fly all the ww2 planes
LDM
Hide Signatures
(in reply to BRYAN01601)
       Post #: 16
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND... - 6/18/2005 8:04 PM
jetpilotrich
Score: 100
Status: offline
I fly the old Cermark F-16 a lot. The gear is the same basic set EXCEPT.... it is completely re-designed..... all the parts that were plastic are now machined aluminum and the wires were upgraded to a 5mm or 3/16" wire! It appears to be a very soild gear set! Many people with the old style mechanical gear will want this set... I think Cermark may have an opportunity to sell this gear set independent of the F-16 kit for those tho are tired of working with the same old "Junky" mechanical systems of the past.
The new gear also comes with a nice set of aluminum hub wheels.
I will be working on a single-servo gear setup to see if I can make it work! I guess Cermark had problems with getting it to function properly.. they decided to use 3 servos instead which will work great... but adds alot of weight!
For anyone who wants that SU-27... just tell alex at AKM I sent you and he will give you a FREE set of the laser cut stickers that go with the kit if you order the SU-27!
For the F-16 here is the link: http://www.cermark.com/
I will be using A Jett 90L ... would not think of using anything else!
There is some drag from the front scoop but otherwise the plane is very clean... I could be potentially very fast.... the best part about it is the "flying Tail" or "Stabilator". Back in the 1940's when the sound barrier was broken the "Flying Tail" was the single design element which made supersonic flight possible... most turbine planes have them due to the speed. It should be way less prone to flutter. Most planes flutter in the tail... and this plane has a nice tail setup!
Also the rudder linkage is very direct and short.... thus also way less prone to flutter... I think this plane may really cook!
Will post some pictures of construction soon! fere are a few pics!
Rich
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 17
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AN... - 6/18/2005 11:39 PM
bob27s
Score: 105
Status: offline
quote:
ORIGINAL: LDM
LDM...
From what I have seen of the F-16 (one local built one, plus the one at the Toledo show) its a real nice plane. The mechanical gear (upgraded) are VERY nice looking. More like the MK pattern gear from a few years back than 'cheap' hobbico gear - VERY well constructed and appear to include 'real' steel struts. The 3-servo thing is probably the only concern - it is for the most part impossible to get them all to work from a common servo, or even just two servos. Spring-Airs or the new robart 'cloes' would be good alternates. All up weight of the bird ..... expect over 9 lbs. Its a big plane. But it has a lot of wing area - weight is not a big issue.
The AKM kits are outstanding. Well designed, cutting is real nice. Alex produces some good products. Some good thread info here in RCU to follow for the SU-27 and also for the Mig.
Bob
Bob Brassell
Hide Signatures
(in reply to LDM)
       Post #: 18
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AN... - 6/19/2005 12:14 AM
Capt G
Score: 100
Last Login: 5/24/2013
Status: offline
I may have to get one of these too. Rich - on the SU-27 - have you thought about using 2 rudder servos to get rid of the transverse connector rod and make the hook up more solid? G.
Hide Signatures
       Post #: 19
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AN... - 6/19/2005 2:27 AM
jetpilotrich
Score: 100
Status: offline
The rod is not the problem. I used a 4-40 commecting rod. All the play is in the flexing of the touque rod. A 2 thicker torque rods in the rudders or a more direct linkage system would solve the problem!
Rich
Hide Signatures
(in reply to Capt G)
       Post #: 20
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AN... - 6/19/2005 6:14 AM
lear31A
Score: 116
Status: offline
I have the main gear installed. The springairs are a nice fit. I am installing the Robart air kit (tank/valve) tonight. I am now racking my brain to figure out how to bend the wire legs. I will post more pics as well.
BTW: Anyone know where to buy some 3/16 wire struts only? Tower only has 5/32???
< Message edited by lear31A -- 6/19/2005 6:18 AM >
Will fly for coffee
Hide Signatures
       Post #: 21
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AN... - 6/19/2005 6:25 AM
lear31A
Score: 116
Status: offline
Never mind, I found it. Tower has it in 36" music wire catagory.
Will fly for coffee
Hide Signatures
(in reply to lear31A)
       Post #: 22
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AN... - 6/19/2005 9:39 AM
msweeten
Score: 100
Last Login: 10/1/2008
Status: offline
I built the new F-16 with the custom retracts. At first you think sure I can make this work with one servo. The Problem is that the gear retract forward against the air stream. I put three standard servos in( I thought if one retract servo at 94 oz will do it then two 46 oz servos should be fine). On the ground the gear went up and down with authority. Once in the air the plane picks up speed fast. I hit the retracts and only the nose wheel went up. You need to use two retract servos and a standard servo to make them work. The retracts themselves are pretty good. You do need to work them a little to make the work smoth. take a small file and get rid of any small burs. next I greased the friction points of the retracts. Lastly make sure all of the screws are tight and use lock-tite to make sure they stay that way. If you don't mind the three servos the custom retracts work well. On take off and landing the plane tracks well. I am useing the jet 90L and the upgrade retracts from Cermark and my plane is just at 10lbs. The plane floats in on landing. I set up mine to use flaperons but have not tried them yet. The only bummer is that my club informed me that they have a 100 db sound limit so I can't fly my plane with the standard tuned pipe from Jett I will have to use a MACs quiet pipe. I don't know how much HP i will lose? I do know it will make my wallet about $160 lighter. I think I will try over proping on the ground and hope it unloads in the air. I know this will not quite make the 100 db limit but should be closer and I will just have to fly on off days not to draw attention to myself. Any way good flying
Hide Signatures
       Post #: 23
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AN... - 6/19/2005 10:43 AM
jetpilotrich
Score: 100
Status: offline
To bad you cant use the JETT. It makes all the difference!
Rich
Hide Signatures
(in reply to msweeten)
       Post #: 24
RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AN... - 6/19/2005 2:43 PM
vasek
Score: 147
Status: offline
I do not understand the Cermark 3 servo retracts philosophy... with the cost +3 servos, one can buy air retracts with all the bells & whistles! I am sure it's lighter& easier to install...
Why do the hustle? it seems like a no-brainer to me!
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.859RCU1
