RE: Ultra R/C Giles 202 UL 29%
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: Ultra R/C Giles 202 UL 29%
Page: <<   < prev  9 10 [11] 12 13 14 15 16 17 18   next >   >>
Login
RE: Ultra R/C Giles 202 UL 29% - 8/29/2005 7:32:06 AM
mr.scale
Status: offline
I got a dumb question about servos.
Where should I use two futaba S3010 (nylon gears 90oz torq @ 6v) or trede them for hitec's 645MG (133oz torq @6v)for elevators and ailerons and the use one hitec 705 for rudder. where the lesser the torq servos should go and where the higher torq servos should go!
thanks guys!
Fernando
_____________________________
GRAVITY WORKS IN MYSTERIOUS WAYS, SOME PEOPLE LIKE IT, SOME PEOPLE DONT.
(in reply to rcplaincrazy)
       Post #: 251
RE: Ultra R/C Giles 202 UL 29% - 8/29/2005 5:15:21 PM
STG
Status: offline
quote:
ORIGINAL: mr.scale
thanks guys!
Fernando
If you are going to set this bird up with 3D thows (35° to 50°) the servo's will see a large mechanical disadvantage. Even though your torque might be OK I would opt for a stronger gear train. It does not take much bumping of that control surface on the ground to damage the gear train, setting yourself up for a bad experience in the air.
Good Flying to you!
See Blog for RCU Video's
(in reply to mr.scale)
       Post #: 252
RE: Ultra R/C Giles 202 UL 29% - 8/29/2005 6:03:02 PM
JoeAirPort
Status: offline
Yeah go metal gear or you will have problems IMO. Try 5945's or less expensive and slower 5645's. The 5925's are VERY fast and would be ideal.
Joe AP
(in reply to STG)
       Post #: 253
RE: Ultra R/C Giles 202 UL 29% - 8/29/2005 7:36:30 PM
BoneDoc
Status: offline
I would personally NEVER put a nylon gear servos on bigger aircrafts 65" or larger... too much risk.
Josh
(in reply to JoeAirPort)
       Post #: 254
RE: Ultra R/C Giles 202 UL 29% - 8/29/2005 8:10:29 PM
ben beyer
Status: offline
get some 6635's at least. anything with karbonite gears.
Team DOD Member
www.downonthedeck.com
(in reply to BoneDoc)
       Post #: 255
RE: Ultra R/C Giles 202 UL 29% - 8/29/2005 8:27:07 PM
STG
Status: offline
quote:
ORIGINAL: ben beyer
Well, not quite anything with Karbonite gears--Skip the X475's on this plane. Even H.T. does not recommend them for anything over 8 pounds.
Good Flying to you!
(in reply to ben beyer)
       Post #: 256
RE: Ultra R/C Giles 202 UL 29% - 8/29/2005 8:49:26 PM
mr.scale
Status: offline
thanks guys, i'll discard the S3010 and get four HS645 and one HS705, this fits my budget better.
thanks.
Fernando
(in reply to STG)
       Post #: 257
RE: Ultra R/C Giles 202 UL 29% - 8/29/2005 9:13:38 PM
STG
Status: offline
quote:
ORIGINAL: mr.scale
thanks.
Fernando
Why not 5 of the 5625's? You can get them to your door from Servo City for $46.75ea right now.
Good Flying to you!
       Post #: 258
RE: Ultra R/C Giles 202 UL 29% - 8/30/2005 4:34:45 AM
BoneDoc
Status: offline
How about this, JR 125 mg SPORT. I have mine on my showtime. They are CHEAPER, FASTER and MORE POWERFUL than the HS 645... can't beat that
Josh
(in reply to STG)
       Post #: 259
RE: Ultra R/C Giles 202 UL 29% - 8/30/2005 11:36:28 AM
mr.scale
Status: offline
josh I could not find those servos(jr 125's).
Fernando
       Post #: 260
RE: Ultra R/C Giles 202 UL 29% - 8/30/2005 11:42:17 AM
mr.scale
Status: offline
STG, I checked servo city and found the servos,
you mean using the same type servo for elevators,ailerons and rudder? (5625)
Fernando
       Post #: 261
RE: Ultra R/C Giles 202 UL 29% - 8/30/2005 12:50:20 PM
BoneDoc
Status: offline
It's JR SPORT. My LHS has them if you want you can give him a call and he'll mail it to you.
The Hangar (George Knapple)... a really good guy
(316) 941 4540
(you know you're in trouble when you have memorized your LHS' number by heart
Josh
       Post #: 262
RE: Ultra R/C Giles 202 UL 29% - 8/30/2005 5:09:03 PM
STG
Status: offline
Sure. The 5625 is plenty at 6v for rudder on this plane. If you have any doubts get the 5645 for the rudder---same price.
--- Looks like JR is doing something right. 5 of these with a pack of Dubro HD servo arms would do nicely on this bird.--the servo arms that come standard with these servos are very wimpy
"What if you need a standard sized metal-geared servo? Well then the ST125MG is right for you, as the ST denotes a standard size case, MG denotes that it has metal gears, and the 125 refers to 125 oz/in of torque @ 4.8volts. All eight JR SPORT servos feature universal connectors that will plug into major brand receivers and they still feature JR’s industry leading 3-Year warranty"
http://www.jrradios.com/Articles/Article.aspx?ArticleID=1497&tag=hwn2008
My LHS (Portland) has these in stock--they are $33.99 ea Have to believe JR is setting the price on these as this shop has Sky high prices on everything else.
I still think the 5625/5645 @ $47.00 to your door is a bit better value.
< Message edited by STG -- 8/30/2005 5:17:59 PM >
Good Flying to you!
