P-Diddy
OR, USA Status: offline
You haven't said what kind of flying you want to do. If you want to be able to do some sport flying but don't need a greater than a 1:1 power:weight ratio, then the 26cc will be fine. If you want to do 3D, hovering, strong climb-outs, etc., then you should go with the 40 cc. I have a 40cc BCMA SPE engine in mine, and the performance is outstanding. -Pat
_____________________________
Currently:Aviation/SD Yak 54 33%(3W70),UltraRC GilesG202(BCMA 40cc),T-Rex600N(O.S. 50 Hyper), MSH Protos 500
