RE: Ultra R/C Giles 202 UL 29%
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> RE: Ultra R/C Giles 202 UL 29%
Page: <<   < prev  112 113 114 115 116 [117] 118 119 120 121   next >   >>
Login
RE: Ultra R/C ... - 3/18/2008 11:15:58 PM
RCWI
Status: offline
my elevators are fluttering using JR st126mg servos with 6V battery
(in reply to jstanton)
       Post #: 2901
RE: Ultra R/C... - 3/19/2008 12:42:44 AM
P-Diddy
Status: offline
Okay, not sure what the stats are on those servos, but you do need some decent torque servos in order to keep those big elevators from fluttering. Anything less than about 100 oz./in. is probably not going to be enough. Otherwise, I would check for slop. Move the elevator with the radio on and see if you can move it more than about 1/8" with light pressure. If you can, there may be a control linkage issue or perhaps your servos are too weak or have slop in them from use.
_____________________________
Currently:Aviation/SD Yak 54 33%(3W70),UltraRC GilesG202(BCMA 40cc),T-Rex600N(O.S. 50 Hyper), MSH Protos 500
(in reply to RCWI)
       Post #: 2902
RE: Ultra R/C... - 3/19/2008 2:52:03 AM
SU29
Status: offline
Dave, thanks for the reply, I put a straight edge on it and you can see the front of the hatch is warped. The location of the mounting lugs will not pull the aft end down and hold it in place.
I'm still looking into options!!
(in reply to P-Diddy)
       Post #: 2903
RE: Ultra R/C... - 3/19/2008 2:56:02 AM
SU29
Status: offline
Help with Graphics included in the kit.
It appears there is a carrier to be used to attached to the graphics sheets to lift them and place them on the plane. I could use to guidance, I have not used this type setup before. How do you attach the carrier to the graphics, is there a proceedure, I cannot find anything in the manuel.
thanks.
Jeff
(in reply to SU29)
       Post #: 2904
RE: Ultra R/C... - 3/19/2008 3:08:25 AM
RCWI
Status: offline
thanks P-Diddy for the reply, the servos are new and have 142oz @ 6V stardard metal gear. But they have slop so I am waiting for new digitals with more torq. Im hopin this will fix the flutter.
(in reply to SU29)
       Post #: 2905
RE: Ultra R/C... - 3/19/2008 7:04:30 AM
P-Diddy
Status: offline
RCWI - A little slop in the head of a new servo is normal, and I don't think getting digitals will fix the problem. Can you take a picture of your elevator linkages so that we can see how you have it all set up?
(in reply to RCWI)
       Post #: 2906
RE: Ultra R/C... - 3/19/2008 12:49:56 PM
RCWI
Status: offline
P-Diddy, This is a pic of my linkage.
Click to see fullsize image.
Click for fullsize
       Post #: 2907
RE: Ultra R/C... - 3/19/2008 2:38:19 PM
Rocketman_
Status: offline
quote:
ORIGINAL: SU29
... It appears there is a carrier to be used to attached to the graphics sheets to lift them and place them on the plane. I could use to guidance, I have not used this type setup before. ...
Unless you're an expert I'd suggest that you apply the graphics wet instead of dry. The use of a commercially available vinyl graphics application fluid or Windex will help to float the graphic on the plane's surface until it is properly positioned. I use my fingers first then a piece of balsa to squeegee the liquid from underneath the graphic.
That carrier that you mentioned is the clear transfer tape or application tape that you peel from it's backing and stick it on top of the graphic and use it to lift the graphic from it's own backing. You then apply the graphic to the wet surface of the model with the application tape. Next step is to squeegee it then peel off the application tape.
Caution, some of those application tapes are so excessively sticky that you may not be able to remove them from the model without lifting the graphic. I try to reduce the stickiness before applying it to the graphic by rubbing my hand on the sticky side or sticking it to a window and peeling it off again.
A commercially available application fluid called Rapidtac, http://www.rapidtac.com/ , has several videos that show how to apply graphics wet but none of them involve model planes. Note: I have never used this product.
(in reply to SU29)
       Post #: 2908
RE: Ultra R/C... - 3/19/2008 3:42:55 PM
72
Status: offline
RCWI ...Another 2 cent opinion, The servo arms may be flexing under load, as the top of the ball link is fairly high compared to the centerline of the rotation of the arm itself. And the other thing is that any time you get flutter on a surface, you should consider gap sealing the hinge lines.- both aileron and elevator. Again, just something to think about.
< Message edited by 72 -- 3/19/2008 3:45:39 PM >
(in reply to Rocketman_)
       Post #: 2909
RE: Ultra R/C... - 3/19/2008 8:32:43 PM
wagen017
Status: offline
It is just me, or are more people having problems opening this webpage:
http://www.ohiomodelplanes.com/giles/
Also some time ago I tried it, and it never fully loads the page.
Volkert
< Message edited by wagen017 -- 3/19/2008 8:33:01 PM >
Club Saito member #371
(in reply to 72)
       Post #: 2910
RE: Ultra R/C ... - 3/19/2008 8:47:23 PM
72
Status: offline
quote:
ORIGINAL: SU29
Canopy Issue: My canopy is warped to the point that when installed there is a little more than 1/8" of a gap between the aft end and where it meets up with the turtle deck. I'm curious if any one else has had this issue and how did you correct it?
My first thought is to put a screw through the Canopy into the turtle neck which means I will have to drill a hole into the Canopy to access the screw etc. Any other thoughts?
Jeff
Try gluing some small blocks to the bottom corners of the frame and then with the canopy pushed down flat where you want it, drill holes through the side and secure it with screws that way. Any pics?
(in reply to SU29)
       Post #: 2911
RE: Ultra R/C... - 3/19/2008 9:14:19 PM
Rocketman_
Status: offline
quote:
ORIGINAL: wagen017
That page is currently screwed up.
(in reply to wagen017)
       Post #: 2912
RE: Ultra R/C... - 3/20/2008 5:12:39 AM
chatorivera
Status: offline
You should try this link:
http://www.ohiomodelplanes.com/comersus/store/comersus_viewItem.asp?idProduct=272
Best regards.
