P-Diddy
OR, USA Status: offline
Okay, not sure what the stats are on those servos, but you do need some decent torque servos in order to keep those big elevators from fluttering. Anything less than about 100 oz./in. is probably not going to be enough. Otherwise, I would check for slop. Move the elevator with the radio on and see if you can move it more than about 1/8" with light pressure. If you can, there may be a control linkage issue or perhaps your servos are too weak or have slop in them from use.
_____________________________
Currently:Aviation/SD Yak 54 33%(3W70),UltraRC GilesG202(BCMA 40cc),T-Rex600N(O.S. 50 Hyper), T-Rex 450SA (stock!)
